Question about Pyle PLVW20T 20 in. Car Monitor
Pyle pldr106 Help! I need to add rca outputs to a pyle pldr106. Where on the board can I tie into? Does anyone have schematics?
Just buy a convertor and tap into your speaker levels and presto.
Posted on Dec 31, 2007
I have a pyle pre amplifer home receiver model pt270aiu and need help hooking up my wired subwoofer and receiver has rca plugs ive tried connecting by wiring to plugs but hardly ant sound
I had a brief look at the spec and it says the speaker outputs are banana sockets/plugs.
Once the four speakers are connected, or two with the fader control adjusted, it should produce good sound and if it does the next stage will be to connect the subwoofer with RCA plugs into the dedicated outputs.
I suggest you reread the manual.
Apr 28, 2018 | RCA Audio Players & Recorders
WILL IT WORK ON A TV THATS NOT BLUETOOTH CAPABLE
Hi Mike,
The TV requires an audio output jack. Either an Optical, a stereo "RCA phono" type or a stereo 3.5mm "headphone" type jack with the appropriate cable to mate with the speaker's optical or RCA input jacks are needed.
Download the manual from the page linked below under "Manuals and Downloads" and read page 7 where the details of these connection can be seen.
Pyle PSBV600BT Home and Office SoundBars Home Theater Sound and Recording...
Jul 14, 2015 | Pyle PSBV600BT Sound Base Bluetooth...
Free schematic diagram
You may not be able to get a schematic. You need to be able to troubleshoot electronics without a schematic. Check where the AC cord connects to the circuit board. In general there should be a fuse and a transient suppressor. Next will be the transformer if there is one or rectifier diodes. These usually fail in a lightning strike. There is also the probability of other component failures, but you won'y know that until you repair these components.
Sep 01, 2014 | Sound Around Pyle Home PTCDS2UI AM/FM...
Pyle troubleshooting
The projector has built in speakers.
Aug 06, 2014 | Pyle Home PRJHD66 1080i Front Projector
How to daisy-chain my Pyle amplifier with my KLH amplifier
as u do not state models here goes:
one or both amplifiers could have a stereo rca output, connect the output of the amplifier that gets signal from the head unit to the input of the other amplifier.
DO NOT share ground cables or power from one to the other (these cables should both run separate from a distribution block AND not from one amp to the other,
........do not connect both amplifiers to only one driver.........
hope this helps, let me know if you need more assistance.
....andy...
Jan 06, 2014 | Pyle Car Audio & Video
How do i wire up my amp to the pld70bt there are so many pre outs and do i need a crossover not getting the bass that i should be getting
The specific unit has a mono sub woofer output. It is the Grey coulerd RCA output. Buy a male to female Y-Splitter( it is a RCA connector that has one male RCA plug on one side and two female RCAs' on the other side.Now just connect that to the rca that is going to the amplifier. As this is the dedicated sub woofer output use it.
dreamsystems.
Feb 11, 2011 | Pyle PLD70BT Car DVD Player
I want to reuse my Honda Odyssey video monitor
I have this same question. Did you get any answer?
Jul 19, 2009 | Nokia LD-1W GPS Receiver
Trouble connecting marine amp to stereo
Hello lizskates814,
You can use either the high level (speaker) or the low-level (RCA's) inputs to the amp, but not both. Choose whichever one sounds the best or is more convenient to install and leave the other disconnected.
Hope this helps.
May 23, 2009 | Pyle PLMRA400 Car Amp
Can the Pyle PLCD-42
Yes there is a couple possible ways.
1. Get 2 RCA Y adapters and split your Preamp Output you will not have any type of fader control this way because you are using a single output.
2. Run one amp from the radio with a set of RCA Cables.
Hook up amp #2 using a Line converter connected to the output of your stereo which will convert you to RCA the just run a cable to the amp..
3. If one of the amps has a High Level Input Run a set of speaker wires from the stereo outputs to the High level Input.
I personally prefer the above 2 methods I find Low Level input sounds better.
Hope this gives you some Ideas and helps
Aug 31, 2008 | Pyle PLCD-42 CD Player
Pyle PLVW20T 20 in. Car Monitor Logo
117 people viewed this question
Top Pyle Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
