Question about Lexmark X6650 4-In-One Wireless InkJet Printer
X6650 Cannot Scan or Copy
Whenever I try to to copy it just prints a page with large black lines on it, and Scanning won't work because the download application list will not work
SOURCE: scanning with my printer
Funny you just posted this yesterday and I had the same problem at the same time. (driver timb bomb?) Any way, the solution that worked for me was to: 1. Unplug the printer. 2. Uninstall the drivers. 3. Reboot the machine. 4. Go to the lexmark site and download the drivers. 5. Install the new drivers. Everything is working great now. It is nice to have simple solutions once in a while. :)
Posted on Aug 21, 2007
Ajkill
  • 2035 Answers
SOURCE: two black vertical lines appear on copy, pdf, and scan results
  1. Unplug the power cord and the phone line from the wall.
  2. Open the control panel.
  3. Pull the roller lever forward, and then lift the white roller out of the All-In-One.
  4. Note: The scan lens is located under the white roller.
  5. Use a clean, lint-free cloth dampened with water to wipe the white roller and the scan lens.
  6. Reinstall the white roller.
  7. Reconnect the power cord and the phone line.
  8. And then try to copy if get the dame line then its the hardware problem in the printer you must need to replace the scanner unit in the printer ..
Good luck..
Posted on Nov 11, 2008
  • 2692 Answers
SOURCE: Can t scan
Reinstall it(the software and driver) with the updated stuff.
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_652569478_0_en,00.html
Posted on Jan 01, 2009
SteveLXK
  • 109 Answers
SOURCE: thick black line through page when copying or scanning
Sounds like part of your scanner is not functioning and reading black all the time. Probably best to return it for a replacement.
Steve
Posted on Feb 25, 2009
SOURCE: my brother mfc 210c won,t scan or copy
I just called Brothers product support and found out that these machines WILL NOT scan or copy or do anything until the ink cartridges have been replaced. So there is no other solution.
Posted on Jul 28, 2009
Copy Output all black
Janson; does this problem only occur if you're doing copying via the auto feeder, or also if you lay the paper in manually? The auto feeder uses a small glass opening to the front (or left) of the main flatbed scan area; if there is an issue with that area letting in light, an all black page would result. If you get all black with either type of scan, but regular printing still works, then you may have a dead scan element. Try scanning something to your computer or to an email account to see if normal scanning still works.
Apr 04, 2014 | Dell 2135cn All-In-One Laser Printer
My HP laserjet 3050 when i copy a page the paper prints black
Symptom: Black or Blank image while copying or scanning.
Part suspect rating: Scan head..70%
Scan head cable...25%
Formatter...5%
For tech guys only: Remove ADF unit from the printer, remove both side covers of adf, remove & replace scan head, check...
Replace scan head
Jul 21, 2012 | HP LaserJet 3050 All-In-One Printer
My officejet pro 8500A prints black vertical lines down the page when I make a copy. I have cleaned and aligned the printheads. What else can I do?
Happened with me too. Turned out to be a small sticky smudge on the ADF glass. That is the smaller glass scan area to the left of the large glass scanning area.
When using the ADF to scan or copy, make sure the smaller glass area is clean along with the rollers.
Oct 05, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
Scanning/copying problem (Lexmark 6500 series x6575)
please just you scan the object to resuleasion in and dp is 600 to 12oo select and you scane object and aply print is dark is ok.
Sep 17, 2009 | Lexmark X5150 All-In-One InkJet Printer
HP OfficeJet J5780 Vertical Black Line Prints when copying or scaning only. Cleaned rollers and changed black ink cartrigde. Still problem.
Have you tried cleaning the document feeders Scan Glass? (small glass under doc feeder ~ 1" by 9") Most times there is dirt spot on this glass, causing a shadow on scans and copies.
Try copying from the large glass by lifting doc feeder / platen cover and manually placing original. If no line copying or scanning manually from large glass, then small scan glass is deffenitely the culprit. Hope this helps.
Sep 07, 2009 | HP Officejet 5780 Printer
When I put a doc on the glass to copy -the print has a black vertical line down the page. When I print from computer to print - it works fine - there is no line of ink. Can I fix this myself? What would u...
A long black line on scanned images is usually caused by a piece of trash on the scanning mechanism.
Look at the scanning arm (the thing that moves when you scan something) and then see if it has any trash on it. If it looks good then you may have a mechanical malfunction in that part.
Let us know hat you find.
May 21, 2009 | HP Office Equipment & Supplies
Whenever I scan a picture or document I get a line going down the middle of the page. When I print the same document the line prints down the page. THIS only happens on the scan not when I print from the...
first of all try to make a copy..when you make a copy if you get lines..then clean the scanner glass and the rollers..if its still the same..connect the printer directlu to the wall outlet and then check
Mar 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Scanned documents are very light
I have found that when scanning b/w documents, its helpful to start with a black and white copy, not a grayscale, pen written, or printed form a printer in grayscale mode copy, but a true black and white on the copier or fax copy. The scanner doesnt read shades of black so well and when scanning multiple page documents, my pixma tends to scan in lightly. I havent found a piece of software to do just this, batch darken what has been scanned (at least not for free). Copying before scanning is the work around. Hope this helps everyone who's had this problem. It also doesnt hurt to darken what your scanning down a notch when copying
Mar 21, 2008 | HP PSC1510 Printer/Scanner/Copier...
Black Line when scanning or copying
This appears to be a scan head problem either not completeing a full travel or a ccd problem Could even be a piece of some thing come adrift and masking the ccd- can you see anything like that. What ever it is it wont be a repair[unless you can fix it your self] Replacement is only answer I think
Aug 27, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark X6650 4-In-One Wireless InkJet Printer Logo
41 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
