Question about Garmin Nuvi 660 GPS Receiver
When you are charging the Garmin Nuvi 660 how do you know when its done charging?
When I charge my nuvi 660, I get a message on the screen that saying "switching to charging mode" or something like that and then the screen goes black. Unless I trun the unit on every now & then, how do I know when its fully charged?
  • 35 Answers
No way to know except you disconnect and watch your 4 baterry bars.
It take almost 4 hours to be full charge.
Posted on Jan 21, 2008
How do know when my Garmin 855 is done charging?
Turn it on without being connected to the charger and check out the battery indicator - that will give you a bearing on battery condition.
Sep 20, 2017 | Garmin Nuvi 660 GPS Receiver
How do i charge my garmin 750
Plug the charger into the mini-usb jack. The unit should turn on and when you come to the main menu, you should see a lightning bolt over the battery bar graph. This indicates that it is charging. If you don't plan on using it and want to charge it over night, if your Nuvi has a push down power switch on the top, press and hold it briefly until it goes to a black screen and says charging. If your Nuvi has a slide switch, slide it to the left until you get the same charging screen. A few seconds later, the screen will go dark but if you touch the screen, it will light up again and say its charging and go dark again. After several hours, when you go to touch the screen it will say Charging Complete". Yiu will also notice then when you go to use it, you will see ALL of the green bars on the battery bar graph will be lit.
- Jim
SHARCNET-USA
Dec 05, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 shutting off
It sounds like your battery is defective. They can be replaced. The Motorola phone cable is not wired exactly like the Garmin, and your Nuvi thinks it's connected to a PC. Radio Shack carries a charger for the Nuvi. I have one myself.
Let me know if you need additional help with your battery problem.
- Jim
Nov 15, 2008 | Garmin Nuvi 660 GPS Receiver
Garnin NUVI 680
Needed to change the fuse
Aug 08, 2008 | Garmin Nuvi 660 GPS Receiver
Problem with Garmin Nuvi 660
If there is a way to pull out the battery and put it right back in it will probably re set it.
May 16, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin 200w
Yes it can be charged on the computer, but the ac is the fastest with cig lighter second. They are much much faster ways to charge it. So it depends on how you charge it.
Apr 20, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 660 frozen
I did connect it to the computer via my USB cord - a Garmin menu came up and after opening a couple of the choices the Garmin was workable again. I don't really know why. But all is good here.
Feb 16, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi won't turn on
folks, the garmins have an on-board battery that needs to be powered up (at least occasionally) via the usb port - like from your computer. just using the dc car power cord does nothing for this battery. i've had this exact same problem on both my 760 and 780 nuvi units. fixed it using the usb charge. seems to run down differently for all the various nuvi models. my regular charge will hold for 7 hours on my old 660, my 760 and 780 work about 5 hours. my 'power up' failed on the 660 after 10 months with no internal battery charge, but the 7xx models only took about 5-6 months to 'fail.' hope this helps. jack b :-) in midland, tx usa
Jan 13, 2008 | Garmin Nuvi 660 GPS Receiver
Getting started with new Garmin nuvi660
Plug your 660 with usb into the usb port, computer must not set on sleeping mode (screensaver).
It will take 3-4 hours to be full charge
Dec 18, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 660 personal travel asistant
Are you running this unit while it is charging? Does the Nuvi 660 have a sufficient charge?
Try to do a hard reset on the unit.
Dec 13, 2007 | Garmin iQue 3600 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
1,720 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
