Question about Toshiba 37HL67 37 in. LCD HDTV
Toshiba 37 inch TV
Hooked up to satelitte feed , good reception but..
the screen is wavvy, numbers and words are slightly blurred , not crystal clear. Is this interference?
  • knightydaz Aug 19, 2008
    i have i toshiba 3787db with the same problem its not the input ie the dvd because in normal analog mode like bbc1 2 itv its worse its like interference from something and when you pick menu it swirls and when i turn up brightness there is i pink line across the top of the screen
    Sergeant:
    Champion:
  • 362 Answers
Do you have the satellite hooked up through the coax cable if so that could be the problem you will have to manually set the settings with the remote. always make sure you have only one thing hooked up at a time. if you have cable and satellite dont hook up both it makes the picture lousy see the owners manual i think its page 58 or somewhere close to there.some times if both are hooked up it will not work at all.
Posted on Dec 14, 2007
I'm hooked to cable tv on my dynex 37 inch tv but cannot change the screen size or time. Why
This may be time to find and read the user manual. Please don't be insulted. If you have lost yours, you may likely find one in a PDF format online. In a search engine type quotes, like (below using your info...)
"Toshiba TVDC567" "Owners Manual" +download
Dec 02, 2016 | Dynex Televison & Video
Screen has gone to blue screen.....
OK A Blue screen, indicate that there is, or the TV "Thinks" there is NO SIGNAL. Please Check your Antenna Connection. Unplug the TV, for 5 mins or so. You MUST prove either the TV or it's "Signal Source" the Antenna. Try the antenna on another TV, if possible, try another antenna,on the TV, Try feeding in a signal via the EXTERNAL inputs. IF ALL Inputs are proved OK, and the TV, still will NOT display any signal, then it would appear that you may have a "Tuner" fault, or some other underlying condition, that affects the reception. In my professional opinion, in that case is to get the unit looked at by a Toshiba, recommended service center, VERY IMPORTANT to do that. Ask for a "Quote" from that service center, and go from there.
Apr 16, 2010 | Toshiba 37AV500U 37 in. LCD TV
My reception is not crisp clear. I want to know
Are you on antenna or cable?
Some tuners do not work all that well on the TVs, if your old TV worked alot better with the same antenna then it may be a matter of using a VCR or external tuner then feeding the video into the new TV.
Cheers,
Jan 06, 2010 | Televison & Video
Olevia 37" Hd flat screen, picture does not fit screen. Sporting event scores are off the screen.
You need to check the aspect or screen size settings on the TV as well as your signal scorce IE: cable box, satelitte if they are HD?
Sep 10, 2009 | Olevia LT37HVS 37 in. LCD HDTV
My RCA TV guide words is blurred but the
There are 2 things you try. go into menu to picture setup scroll down to sharpness,back this setting all the off. If this doesn't do it, go to back of the set on right hand side, if you can see focus slot adjust it slightly.
Sep 06, 2009 | RCA F25654BC 25" TV
Blue Screen
Problem with the screen driver circuitry. Possibly the blue driver is shorted or being overdriven. This may be on an IC that handles them all.
Jun 17, 2009 | Toshiba 32AF43 32" TV
1999 toshiba rear projection tv blinking red light after moving
this might be a tube leak check for fluid on the necks of the tubes with your hand. if none you might have a faulty protect chip- common-
forgot the exact location but it's on the main board, it's a 16 pin chip as i remember and it is a quad op amp. if you hold your finger across the pins underside it will turn on and stay on as long as your finger is there, if so replace the chip
Dec 25, 2008 | Toshiba 50H81 50" Rear Projection...
Troubles with phillips projection tv. It is showing about a 6 Inch blurring color at the bottom of the screen and blurred color streaks throughout the screen, what could be the problem?
you need the DPTV305 - Dptv345 Convergence repair kit available at the following link. Its listed under the convergence repair kits category, comes with all parts and step by step instructions with pictures so you can do the repair yourself.
Here is the link.
http://servicemanuals.vstore.ca/
Oct 03, 2008 | Philips Magnavox 51MP392H Rear Projection...
Audio reception change
I will speak genericaly about TV sets in general.
There is more than simple frequency involved. There is bandwidth, de-emphasis characteristics for detection, and depth of modulation.
This cannot be feasiby accomplished. The audio decoding in your set uses phase lock loop circuitry that is crystal stabelized and firmware controled. This is factory burned in to the functioning of the IF module's devices.
You can try changing the IF module to start, but there may be a conflict with the main uPC on the motherboard of the set.
When people change countries we always tell them to leave their TV behind and get one for the local broadcasts.
What you can do is get a separate tuner unit for your set, and feed it with that. This way you will be using your set as if it is a monitor. This is the most feasible and reliable solution for you.
Personaly, I would buy a local TV set, and send the old one to a friend as a gift back from where it came from.
Jerry G.
Dec 23, 2007 | Toshiba 27A44 27" TV
Toshiba 37HL67 37 in. LCD HDTV Logo
106 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
