Question about Bosch Dryers
Bosch tumble dryer, model wta 4100 , no heat, otherwise all OK
    President:
  • 1,776 Answers
If the dryer isn't heating, check for a blown thermal fuse or a faulty heating element. Both components can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty component. Both components are located in the rear of the dryer. The thermal fuse is about an inch long and is usually attached to or near the exhaust duct. Hope this helped and best wishes.
Posted on Sep 12, 2009
How to reconnect the wiring on the bosch wta 2000 tumble dryer?
And why did you not tag the wires when disconnecting them as a good repairman always does .
Sep 16, 2015 | Bosch Tumble Dryer Fluff Lint Filter...
I replaced the heating element on my Bosh WTA 2000 tumble dryer , but it still doesn't heat up? Is there other components that could be damaged?
There are multiple thermal protectors on the circuit. Make sure they are all ok. Double check your connections
Aug 08, 2013 | Bosch Dryers
How do you change the drive belt on a Bosch Classixx tumble dryer WTA3003GB/17?
Its a fairly simple process depending on your machine. Most Bosch machine belts are simple to replace. Here is a good resource: http://www.videojug.com/film/how-to-replace-the-belt-on-a-tumble-dryer-bosch
Dec 03, 2010 | Bosch Axxis WTA 3003 Electric Dryer
Looking for manual for the bosch wta 2000 tumble dryer. thank you.
I've made a PDF of the Bosch WTA2000 Tumble Dryer User Manual and (hopefully) it will be available on this link in case anyone else still needs a copy, as the original request above is a bit old now.
It's a leeeettle blurry as I should have used a higher dpi when scanning the pages, but I can't be bothered doing it all again. I think it should be sufficient for purpose anyway.
https://onedrive.live.com/?cid=5D5DECF4115C2175&id=5D5DECF4115C2175!189
Nov 21, 2010 | Dryers
Bosch wta 3100 no heat
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 03, 2010 | Bosch Axxis WTA 3003 Electric Dryer
The tumble dryer drum turns but there's no heat on either low heat or full heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Mar 13, 2010 | Bosch Axxis WTA 3003 Electric Dryer
Bosch wta3510us tumbling NOT heating. Reset button?
Remove your back cover ,and then you see the heating element.On one side or on top there is a termostat(Small Black)there is a red button which you should press down until you hear a click.Start machine and element should work.You can start it for a little while but be careful.Put cover back after cleaning loose lint etc. Jan
Jan 09, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
Nov 23, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Dryers Logo
965 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
