Question about Toshiba Satellite A105 Notebook
Power saver error 0x5
Hi, every time I start up my Toshiba satellite M105 I get a message saying "Power saver failure" Code 0x5, "program will be terminated" computer runs fine, but would like to know how to fix!!
  • 1 more comment
  • KC Smith Dec 18, 2007
    error code 0x5 shows up on my tobisha, also "power options" will not allow me to choose Toshiba. This has been doing this since Best Buy worked on it.
    errorcode 0x5
  • G112 Mar 26, 2008
    I Have a Toshiba M500 portege notebook and my power saver keeps coming up with Toshiba power has encountered a fatal error code: 0x15a even when I reinstall it it still comes up with the same message and I would like to fix it
  • 4 Answers
Download the hotkey utility from the toshiba web site. I got this errorafter installing service pack 2 for xp. The hotkey utility fixed it.error appeared every time I started windows xp. Go to:http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
and go to downloads, select model and download:
Toshiba Hotkey Utility
Install and restart, problem solved. thank you, thank you...
Posted on May 27, 2009
Power saver failure code 0x0
Posted on Aug 09, 2009
  • Mattia Wiccio
    Mattia Wiccio Sep 27, 2013
    Of course! Trying to fix the 0x5 error with the solution of Trevort Talbert, the installation of the power saver driver fails and now I have a new error: 0x0! Ouch!
    Scholar:
  • 181 Answers
You simply need to download the Power Saver utility and reinstall it. You can find it on Toshiba's support site:
http://support.toshiba.com
Posted on Dec 11, 2007
Toshiba Power Saver. Fatal error Code 0x7E
uninstall Power Saver while in Safe Mode, reboot into Safe Mode again, and reinstalled Power Saver
Jul 05, 2012 | Toshiba Computers & Internet
Booting problem, screen message: Intel (R) Boot Agent FE v4.1.18 Copyright (C) 1997-2005, Intel Corporation PXE-E61: Media test failure, check cable PXE-MOF: Exiting Intel Boot Agent. Operating...
HI there,
The "Error" texts saying:
Are completely normal. This simply states that there is no external cables plugged into the specialty inputs on your toshiba laptop.
The "operating system not found" is stating that your existing hard drive is either A) dead or B) been erased.
Try to re-install your operating system, if it finds no hard drive, you'll need a new one!
May 04, 2011 | Toshiba Satellite M105-S3041Notebook
My Toshiba Satellite Laptop M105-s3004 Crash and fan not running
Because the fan doesn't work, your laptop is overheating and going into thermal shutdown. have the fan replaced and the area where it is screwed to cleaned as it harbours dust over time preventing adequate cooling.
Jan 25, 2010 | Toshiba Satellite M105-S3004 Notebook
I recently discovered that Anytime I start my Toshiba Saetelite A105-S3611 laptop/notebook with windows Xp SP2, there is a message: ?Toshiba Power Saver?, A fatal error has occurred, this program will be...
May 05, 2009 | Computers & Internet
Toshiba power saver fatal error code 0x57
try to reinstall your operating system..or restore the system..go to control panel and click the back up or restore files so that all the errors in your computer will fixed..even a fatal error..hopefully this will help your problem..
Aug 28, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite M105-S3004 says no operating system found. tried to insert restore disc but it runs for about 20 seconds then turns off.
it sounds like your HDD has suffered a critical error. Go here and download this torrent. This will need to be burned to a disk. now it comes with FreeDos installed. Put the disk in the drive and bootup. use option 5 to repair your HDD. after this finishes try booting your system up.
Jul 17, 2008 | Toshiba Satellite M105-S3004 Notebook
Toshiba satellite pro l40 boot up problem
If you run a repair with the recovery disc you won't lose any info. The only time you'll lose the info is if you run a complete reload. Run the system disc until it gets to the point of finding installed operating systems, at this point instead of deleting the partition, press R and it will reinstall the operating system files only leaving other installed files and programs intact. Keep in mind that many times when this happens, it's a hard drive failure. If it is a hard drive failure, then you will have to replace the hard drive and you will lose the info, sorry.
Jul 02, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Power Saver
It sounds like the built in powersaver utility is crashing. Assuming you can log into the OS after the error, go to Control Panel - Power Options and change to some other (or none at all) setting. And/or uninstall the application completely.
If you can not even get into windows you could try changing the power settings within to bios to disable power saving at all, and that might allow you to boot properly and then turn off/uninstall as described above.
Jan 16, 2008 | Computers & Internet
Toshiba Satellite A105 Notebook Logo
1,973 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
