Question about Brandt WTC0815F Top Load Washer
The rubber cupling that connects the motor to the gear box appear
Brandt wm 600 washing machine The rubber cupling that connects the motor to the (pulley) gear box
comes off all the time. how does it get tighter .
2 Suggested Answers
SOURCE: my kleenmaid brandt 5kg washing machine has had a
hi dyan, are you based in australia? whome did you get to fix your machine? have you solved the issue now?
my mum has the same machine (which she loves) and hers has just stopped working and she was interested to know more about your post and issues you have experienced.
cheers
kelly
Posted on Apr 22, 2010
Brandt WFK1458FE ERROR CODE F08
go to http://www.brandt.com/ and get the support via ONLINE via chat or phone.
God bless you
Sep 25, 2012 | Washing Machines
I want to change place of my Brandt WM 550, but it is quite a feat for me...
you must get help from some friend or relative,and use some carrier for to move easy and without problem.See if the power, and connection for hoses is o.k before.with the same specification do you have.
God bless you
Sep 22, 2012 | Washing Machines
How to move around brandt wm 550
see this causes and fix it. God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
How to empty filter on Brandt 600 WM
Hi, please see your other posting! Thanks, John C
Jul 07, 2011 | Washing Machines
HI, I have Brandt WM. I tried to clean the filter and I managed to breake it. Please let me know where I can order a knew filter. I tried some local shope but they do not have it. I live in Greece, do you...
Hi you could try Espares.co.uk....I live in scotland coming to Kassiopi Corfu in 5 weeks if you are near I will order and give to you, Need model number thanks......
Jun 14, 2011 | Brandt Washing Machines
Won't spin. makes loud noise when draining and won't spin the basin.
If this is a top loader there is a cupling that is made of rubber and a set of plastic parts that are between the motor and the transmission drive. The plastic has fingers that go into the rubber piece and the fingers shear off , the other end of the motor has the water pump on it so it will pump water out but do nothing else. you have to pull the motor out and replace the set and reasemble.
Oct 24, 2009 | Whirlpool Washing Machines
Wont spin
I had this same problem once and it was pretty simple, I removed the agitator asembly, not 100% sure on your model. and there is a cupling between the moror and the agitotor. the guy at the appliance store saidit was a sacraficial part that brakes when a large load is put on the motor to protect it. usually like a 13.00 piece
Feb 18, 2009 | Whirlpool LSR8233J
Washing machine - Need to replace motor cupling on the kenmore 90 series
you have to access the coupling by removing the housing of the machine,
you can tilt it a little bit to the back so that the motor is in your front.
remove the water pump clamps so that you can remove the pump.
unscrew the screws holding the clamps of the motor.( hold the motor tight, it is heavy)
remove the clamps, the motor will fell..
remove the motor and you can see that the coupling is attached to its shaft.
one coupling goes to the shaft of the motor, the other coupling goes to gear box shafting, and the rubber ring is in between the two coupling.
normally, only one coupling is damaged and you can just replace that coupling. you have the other two parts as spare.
i hope this would solve your problem.
tnx 4using fixya,
drcool
Sep 11, 2008 | Kenmore 23822 Top Load Washer
Kenmore 90 Series Washing Machine
the coupling does go bad, Often, very often
one of the two spiders is attached to the motor shaft, one is attached to the gearbox input shaft and the rubber ring mates them together, the motor shaft coupling collapses often,
the coupling is ~$16-$25 depending on the parts sales place.
If you can see the coupling, you probably already have the body off,
If not remove the body
from there its easy to replace
undo 2 spring clips that hold the pump on the outer of the motor,
pull pump forward and off the motor shaft and swing aside,
remove screw from head of spring clip between motor and gearbox, remove this spring clip (remember position)
swing motor against coupling to loosen other spring clip, remove spring clip
pull motor forward and away from gearbox
break couplings off shaft of motor and gearbox.
  • NOTE: new coupling sets have a metal center hub to combat this very common failure,
    ask the parts supplier if they have one with metal hubs,
    if they offer to sell you one identical to the picture, all plastic, old style
Fit new couplings to motor and gearbox shaft using wooden dowel between the teeth, on the hub centers, hit the dowel, not the gear, with a hammer.
fit new rubber ring to gearbox,
install in reverse order
rotate motor to align the teeth
Aug 03, 2008 | Kenmore 15864/15862 Top Load Washer
Rubber Cupling
You must have a whirlpool or kenmore washer.. the hardest part is to get the machine open. let me know what model you have and I can help you...also check to make sure the transmission is not locked up.
Sep 06, 2007 | Washing Machines
Brandt WTC0815F Top Load Washer Logo
Top Brandt Washing Machines Experts
Gerry Harvey
Gerry Harvey
Harjeet Singh
Are you a Brandt Washing Machine Expert? Answer questions, earn points and help others
