Question about Fisher and Paykel IWL12 Top Load Washer
Fisher & Paykel Smart Drive 9 Pride
Help!!!!! My top loader is approx 4 yrs old and won't drain water from the rinse cycle. It starts and will rinse for 3 seconds then stop, followed by a rinse of around a second. It will do this for 2 more attempts then starts it's alarm and won't stop beeping until the machine is turned off. Any help would be greatly appreciated
  • Anonymous Jan 20, 2008
    same problem during rinse cycle...attempts to pump out water, stops, starts up again, stops, then beeps....
  • Anonymous Mar 30, 2014
    smells and stops
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it (4 to 6 inches maximum). Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on Mar 13, 2008
Smart drive 085
It won't spin until all the water is drained out. The drain pump may be blocked or faulty. Fix the drain pump fault first then deal with the filling issue. They will not be related.
Jun 21, 2017 | Fisher and Paykel (IWL12)
My fisher and paykel smart drive 9 5.5kg won't power up
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If there is no power it can be due to a failure of the power supply.
Jan 15, 2013 | Fisher and Paykel Washing Machines
Our Fisher and Paykel excellence 5.5 smart drive 9, washes fine but when it comes on rinse cycle it wont drain the water and makes a humming sound.
Check your pump with a multimeter for correct reading
230V AC Pump 50Hz 33Ohms +/- 8% @ 20oC
110V AC Pump 60Hz 7Ohms +/- 8% @ 20oC
Also check for blockages that may stop pump from turning.
Disconnect from power & Bail out all the water you can before removing pump.
Jul 07, 2012 | Fisher and Paykel Washing Machines
Machine stops when gets to the spin cycle- last time was a hair clip stuck in pump. How do I get into the pump to get it out myself? Is a fisher and paykel smart drive about 9 yrs old.
Hi just read your posting.Is the machine draining any of the water?If it is not draining then bail some of the water out with a small bucket or pot, just enough so you can look under the machine without it leaking everywhere.Now when you are looking under the machine look to the front right and you will see a red or black fan.This is your pump.Turn the fan clockwise and anticlockwise a few times to loosen it if it is jammed.The fan should turn freely.If the pump turns freely then put the machine back on its feet and select a spin cycle and push start.The machine should now drain the water and then it will spin.Please reply on how you got on or if the machine still does not drain.Looking forward to your reply.
Jul 29, 2010 | Fisher and Paykel Fisher & Paykel Washer
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
Water not coming with force in Fisher & Paykel SmartDrive Top-loa
Try taking the cold hose of at the tap and check to see if has a little mesh filter in there. This could be blocked up with gunk.
Jan 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel Pride 5.5 Smartdrive 8 not spining
There is a transmission clutch that engages for the spin cycle. A gear has worn or broken a tooth. Replacement of the transmission hispeed spin cycle assembly is required.
The other comments are of no use. You must get parts from an Authorized Fisher & Paykel dealer, or have an authorized repairman service the machine.
Aug 04, 2008 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel IWL12 Top Load Washer Logo
434 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
