Question about Frigidaire GLEQ2152ES Electric Dryer
DRYER WORKS 1 MIN. THEN SAYS PAUSE ON IT AND WON'T DRY THE CLOTHES
  • 986 Answers
This is probably the motor going bad. The sensors wont cause this to happen. The start switch either, replacing all the sensors in the world wont make the motor be good again. But their is something you can do to try and make the motor last a while longer,their isn't any holes to oil the dryer motor so you must make some,using a 1/8th inch drill bit make a hole in either end of the motor where the bearings are (taking care not to hit the shaft), then add some hi temp oil such as zoom-oil, (dont use WD-40) and work the motor free as you can by hand. If this frees up the motor it may go a while longer. Also oil the rollers and check the slides to make sure they are not pinching and stalling the motor. If the motor can't reach top speed it will get hot,overload and stop.
Posted on Sep 12, 2009
4 Suggested Answers
  • 744 Answers
SOURCE: Dryer taking longer to dry clothes
For a gas dryer:
Assuming the dryer is working properly and the control cycles are ok, look for things like a restricted venting system which inclides the exhaust, lint screen, etc. This would be the large pipe connected to the dryer exhaust that vents outside.
If it's an electric dryer, there could be issues with heating elements, thermostats, a control board, the timer, etc. Also check for any excessive lint build-up.
Posted on Apr 12, 2009
  • 40 Answers
SOURCE: i set my dryer at 40 minutes. after 1 hr the dryer
Your timer motor is bad. The motor is located behind the dial, and if the dial is not turning, then then the motor required to drive it is bad.
To replace timer motor, kill power to dryer and remove panel behind the timer knob. This should provide you access to the motor. Two screws hold motor in place-remove these and disconnect at push on terminals. Make sure you mark your wires so you reconnect to new mototr in proper place!
Posted on Jan 10, 2010
Testimonial: "Very helpful thanks very much"
  • 389 Answers
SOURCE: my dryer won't dry my clothes
clean out lint filter check the vent hose make sure you are getting a air flow out your vent hose if not its blocked inside no air no dry it need air to dry cloths heat only will not dry plenty of air heat quicker drying
Posted on Nov 27, 2011
The dryer does not pass 6 min mark and does not shut off. How would I test a humidity sensor? Thank you for help.
A dryer moisture sensor can stop working without notice, until you notice your clothes being over dried or still wet at the end of the cycle. It is a good practice to test the dryer moisture sensor periodically. There are two types of moisture-detecting sensors for dryers. Once you understand how they work you will see how to test each one.
1. Sensor BarThese sensors contain digits that protrude outwardly. They work on an electrical current and the moisture from the clothing.
The first step to test is to place completely dry clothes in the dryer and turn on the dryer; it should run for a few moments and then shut down right away.
Secondly, place damp clothes into the dryer, turn on the dryer and watch the timer. As the clothes begin to dry the timer will move and shut off.
2. ThermostatThe timer is regulated by the thermostat. The thermostat rests in a closed position. To test this type of moisture sensor, place damp clothes in the dryer. Watch the timer; as the clothes begin to dry, the thermostat should open and the timer will move forward ,eventually shutting off.
Sep 08, 2013 | Dryers
My dryer won't dry my clothes
Nov 27, 2011 | Whirlpool Dryers
My drier was on the sensor cycle and was supposed to run for 54 mins. It was still drying over 2 hours later and the display showed there were 42 mins remaining in the cycle. The clothes were completely...
More than likely the temperature sensor has gone bad. If the unit is under warranty I would contact the dealer...otherwise you need to replace the sensor.
Sep 01, 2011 | Samsung 7.3 Cu. Ft. Super Capacity...
Dryer won't complete dry cycle. Defaults to pause.
disconnect vent tube run a load of clothes, if it works then the vent is restricted if not the sensor below the lint screen needs cleaned, gently. Tim
May 22, 2011 | Dryers
Won't dry clothes completely. They are still damp after a 60 min cycle
check you vent hose- if plugged/crimped air can't get out with moisture- also go to HOME DEPOT or LOWES- get dryer lint brush- goes in hole where lint screen is - clean out good
May 10, 2011 | Dryers
I have a Whirlpool Gas Dryer LGR6646BI-12 the clothes feel warm but not hot and they are still damp
The Dryness Level allows adjustment of how damp or dry the clothes are at the end of the cycle.
  1. Make sure the correct Cycle has been selected for the type of fabric being dried.
  2. If the correct cycle is selected and the clothes are still coming out too damp, use the Auto Dry Level button (Kenmore) or Dryness Level button to increase the Dryness level.
  1. If the highest Dryness Level setting was selected and the clothes are still damp, the Customer Focused Drying Mode settings that are built into the machine can be adjusted.
Dryers come from the factory set to Drying Mode 1 (default). Drying Modes 2 and 3, include additional drying time.
Note: This change will affect ALL Auto Dry cycles.
  1. Machine MUST be in Standby mode before beginning. (Standby mode = Plugged in, Power off)
  1. To select drying modes, momentarily press the Auto Dry Level button (Kenmore) or Dryness Level button (Whirlpool) again. The dryer will beep, and the display will flash and show the next drying mode number.
  1. With the door open and the display flashing the desired drying mode number, press the Start button to save the drying mode and exit diagnostics.
  1. Press the Pause/Cancel key at any time to cancel changes and exit from this mode.
Hope this works............
May 01, 2010 | Dryers
Amana model LGA30AW automatic setting doesn't shut the dryer off
You can make adjustments to your Automatic Cycles by adjusting the Factory Dryness Level:
Changing the Automatic Cycle settings to increase or decrease drying time:
If all your loads on all Automatic Cycles are consistently less dry or more dry than you would like, you may change the default settings to increase or decrease the default dryness
level.
Your automatic drying settings can be adjusted to adapt to different installations, environmental conditions, or personal preference. This change is retained and will affect all of your
Automatic Cycles, not just the current cycle/load. There are 5 drying settings, which are displayed using the time display:
0 Much wetter clothes, 30% less drying time.
1 Slightly wetter clothes, 15% less drying time.
2 Factory preset dryness level.
3 Slightly drier clothes, 15% more drying time.
4 Much drier clothes, 30% more drying time.
TO CHANGE THE DRYING SETTINGS: NOTE: The settings cannot be changed while the dryer is running or paused. The dryer must be in standby mode (power is off) to adjust the default settings.
  1. Before starting a cycle, touch and hold DRYNESS for 6 seconds.
  2. Touch DRYNESS to select the dryness level shown in the time display: 0, 1, 2, 3, or 4.
  3. Touch START/PAUSE to save the new dryness level setting.
Oct 05, 2017 | Amana ALG331RAW Gas Dryer
For a gas dryer:
Apr 12, 2009 | Dryers
LG DLEo332W electric dryer not drying full time
you have to change out the timer motor...
http://www.partselect.com/repair.aspx?appliance=dryer&part=dryer-wont-heat
Jun 08, 2008 | Dryers
Frigidaire GLEQ2152ES Electric Dryer Logo
64 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
