Question about Westinghouse LCM-19v1 Monitor
I have a westinghouse monitor and the screen flickers.
    President:
  • 1,884 Answers
Ty, two causes. One, there is a loose connection. Two, there could be some strong electrcal inpulses being produced close by. Like a TV or a big speaker or some such thing. Even a UPS too close to the monitor could do it. So, now you know what to do.
Posted on Sep 12, 2009
No power Westinghouse LD4655BX
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 04, 2014 | Westinghouse Televison & Video
Dotted lines across the top of the screen and flicker in other video ports.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 05, 2017 | Westinghouse LVM-42w2 Television
Goes blinky
Hey there.
I have recently written a tip on the Flickering/unstable LCD/CRT monitor screen problem. I suggest you give it a read and let me know how it goes.
You can see my tip here: http://www.fixya.com/support/r9423506-flickering_lcd_crt_monitor_screen_or
Enjoy my tip.
Slasher_X
Sep 23, 2011 | Westinghouse L2046NV Monitor
Westinghouse L2210NW Monitor Problem My screen is very bright and i believe it to be a hardware issue.(I've tried other monitors on my computer) I have the brightness set to the absolute min and its...
The black splotch your describing sounds very much like something failed on the board and burned the board so now that is a carbon patch that can conduct electric current. With that in mind, I would suggest replacing the board definately
Apr 18, 2017 | Westinghouse Electric L2210NW Monitor
Screen Flickers and won"t stay on. what is causing
Please read here:
http://www.instructables.com/id/How-to-repair-a-Westinghouse-L1975NW-19quot-LCD-/
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 16, 2011 | Westinghouse L1975NW Monitor
When i turn on my westinghouse 17" LCD monitor it will have a sharp white bar appear through the screen in various sections then blotch out to completely white, after i let it warm up for about 20 minutes...
Hi
Well that's the age old question. Is it worth repair? The problem is probably 6 capacitors in the power supply that have aged significantly. In my shop those caps would run approx $2.00 each with a total labor charge of $50.00. Now whats the charge where you live? Then you can decide if it's worth a $62.00 repair or a new monitor for $150.00. Good luck
Mar 13, 2010 | Westinghouse Electric LCM-17v2 17"...
Screen goes black with power on. It also flickers and power flickers. Does both randomly. New computer. All new drivers. Windows 7. Video card and monitor set with same display settings.
This sounds like a power issue. Check the power cord going to the monitor. Make sure it is fully plugged in. Make sure the receptacle is good and the wiring at that receptacle is tight and secure. Try another receptacle to be sure. Make sure the cord going from the computer to the monitor is secure and tight. You say this is a new computer. If so, then take it back where you bought it if you cannot find the problem.
Dec 12, 2009 | Westinghouse 19" Widescreen Flat Panel LCD...
Flickering white bars scrolling down my lcd monitor screen
Have you tryed unpluging then pluging your video cables? or something?
Aug 28, 2009 | Westinghouse 19" Widescreen Flat Panel LCD...
Westinghouse LCD monitor
flicker to which side, horizontaly or verticaly. does it compress from both side or all side. only flicker from sides or from the center also??????????
provide proper information for solution
Feb 08, 2008 | Gateway FPD2275W LCD Monitor
Westinghouse LCM-19v1 Monitor Logo
116 people viewed this question
Top Westinghouse Computers & Internet Experts
Matthew Spark
Matthew Spark
Iqbal Husain
Iqbal Husain
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
