Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Have a model ED5JHEXTQ00. It makes ice but no water in the door dispenser. Just replaced the filter. When you depress the water dispenser, there is a soft hum but not a drop. Please advise.
  • 22 Answers
Water valve is defective, if when you push to paddle back very slowly and hear a click sound then a hum.
Posted on Sep 12, 2009
Testimonial: "Thanks very much"
Water not dispensing/ice not making, replaced water valve with oem,
Check the water supply line to see if it is kinked. Check the saddle valve to be sure it is ok.
Sep 16, 2015 | Refrigerators
No water from dispenser Matag New filter solenoid valve working, tube to dispenser seems to be blocked
Hello Hans;
My name is Peter. I am a retired field service refrigeration technician.
There could be several areas that would effect your water dispenser not working:
1.) When you depress the water dispenser do you hear a 'Click'? If not you have a bad water dispenser contact switch.
I would send you a diagram but I do not have your model number.
2.) In the lower back of your fresh food section is your water dispenser water tank. At times this can freeze near the freezer section. Look in the lower corner of the freezer & your fresh food section for ice build-up.
3.) You could have a bad water filter. This does happen often. Remove the water filter and test you water dispenser.
4.) Do you have water leaking out of the bottom of your dispenser door? If so you have a split in the tubing in your water dispenser door.
5.) Is your ice maker working? Often the water valve to your refrigerator becomes plugged up and you do not get sufficient water pressure 60 PSI to operate your water dispenser solenoid valve.
Nov 15, 2014 | Maytag MFD2561HE Stainless Steel Bottom...
It's not making ice. Not sending water to the ice maker. I replaced the filter this morning. Water is dispensed for drinking , but not for the ice maker.
I just replaced the water valve because my water dispenser in the door kept dripping. Google parts for your model and put in water valve. It will cost around $80 for the part. My sic year old did most of thr reacement after watching an online video.
Aug 22, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
It's a Kenmore Model 106-56712500 , can't shut off alarm after changing filter, and now won't make ice or dispense water! How do I do a proper re-set code?
The 106.xxxxoooo Models are made by Whirlpool.
  • Whirlpool and KitchenAid - press the light switch 5 times within 10 seconds.
  • NOTE: If the fridge has a filter button, press and hold it for 5-10 seconds.
  • Changing the water filter should not cause the water and ice in door to not work. The actual freezer door switch will cause this problem. When the door is open ice and water in door are disabled. The door switch is a 3 contact switch. One contact is common, one turns the light on / off and one disables / enables ice and water in door. Manually depressing the door switch in the door fold hinge area should enable the water in door function. Do NOT test the ice function. If after you depress the light / door switch the light does not go out and the water in door does not work then the door switch has failed. The door switch is released from the cabinet by sliding either a putty knife or a knife blade along one side to unlock the locking tab. If the switch only has 2 terminals you have removed the wrong door switch. Check the other door.
    If your refrigerator has the wiring harness on the bottom of the door hinge there is the possibility that during the water filter change the connection of the door wiring connectors was loosened or broken. Just check to make sure that there is not a harness on the bottom of the door hinge. If there is a harness on the bottom of the door hinge make sure the connectors are connected.
    If you need more assistance just respond here and I will gladly help you.
    Thanks for choosing FixYa,
    Kelly
    Jan 11, 2011 | Kenmore Refrigerators
    I just replaced the water filter in my Maytag French door refrigerator (2 yrs old) and now the water/ice dispenser will not operate. All other functions on panel are fine (alarm, light, etc.). I tried to...
    Hi, there is a micro-switch at the filter which shuts off the supply and operation while the filter is out of the unit. That switch is still open, so the dispenser thinks you are still replacing the filter. Try taking the filter out and putting it back in. Make sure any locking mechanism is fully engaged. In the meantime, I will see if I can find the service manual for your unit.
    Jan 09, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
    Can't get Ice/Water to dispense, I hooked-up the water hose from the water source to the refrigerator, turned-on the water, left the freezer bar in the "On" position, and unlocked the dispense. I verifed...
    If this is a new purchase, you will have to depress the water dispenser lever long enough for the water to make it all the way through the system, including the water tank located inside the fresh food compartment.
    Aug 13, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
    Ice maker doesn't make ice anymore. The water works and dispenser levers on the door work for both ice (use store bought ice dumped into tray) and water. I replaced the filter after it quit making ice. Not...
    you've already done the first thing i suggest, and that is to change the water filter. But if you still cant get ice made, you have a problem with either your ice maker or your water valve, or an electrical issue in the ice maker system.
    Apr 02, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
    GE Fridge - model gss25tgma ww - will not dispense water. Ice
    solution part # wr49x10173. door heater. comes with instruction. install in 15 min. good luck.
    Jan 19, 2010 | GE GSS25TGMCC / GSS25TGMWW Side by Side...
    Frigidaire PLHS267ZCB4 side by side, no ice or water, not cooling
    I have the same problem. The repair people replaced the control board, but it did not fix the problem.
    Mar 17, 2009 | Frigidaire Refrigerators
    Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
    361 people viewed this question
    Top Whirlpool Refrigerators Experts
    John Tripp
    John Tripp
    Charles T Nevin
    Charles T Nevin
    Dan Webster
    Dan Webster
    Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
