Kitchen Ranges Logo
D
David Kavitz Posted on Jul 27, 2019
Viking downdraft VIPR162ss downdraft stopped working 3 months ago
The downdraft completely does not work. It does not turn on, nor comes up.
Robbie
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 06, 2020
Robbie
Contributor
Level 1:
Answers
Questions
0
Helped
461
Points
Probably due to the up/down switch (part # PV300182 - about $80 on most Viking parts websites) on the top right end of the unit having failed which, I understand, is common (also just happened to me). Others have said it is relatively easy to replace, but I would certainly like a detailed procedure to remove/replace this part.
5 Related Answers
yalmer
Hjalmer Lamminen
  • 552 Answers
  • Posted on Mar 17, 2008
SOURCE: Jenn Air Range SVD48600W (Circa 1998?)
ja_question.gif Why are the oven indicator lights flashing? Answer: When power is first supplied to the appliance, a flashing time will appear on the display.
If a flashing time appears at any other time, a power failure has occurred. Press Cancel, and reset the clock if needed.
When the oven is not in use, the display shows the time of day.
If the indicator lights keep flashing after you have tried to reset the controls, then you may need to contact service person.
This is from the Jenn-Air website.
Anonymous
  • 27 Answers
  • Posted on Aug 04, 2009
SOURCE: downdraft comes on when front left burner is
Typically the Jenn-Air has a grill on the left hand side and the fan is suppose to come on when that burner is turned on.
Anonymous
  • 5 Answers
  • Posted on Jan 31, 2010
SOURCE: Viking downdraft ventilator electrical problem.
Folks,
I just took mine a part due to the same problem. I am an EE, so I have some experience in this matter. The problem was indeed the membrane ON/OFF switch. This switch is basically just stuck on the panel like a sticker. You can literally just pull it off and stick it back on. Underneath it is 3 metal "buttons". When you press it, one of these buttons presses on a flex circuit to complete continuity. This send AC line current down to the lift motor under the gear box cover. The lift motor starts moving. After it starts, a cam hits a relay switch, which completes the circuit thru the relay. This is what keeps the vent moving up after you let go of the On/Off Switch.
At first, I through I could just clean the switch up. I figured crud got down in there. But it did not work. I looked at the switch under a microscope, and the problem is the flex circuit was actually burned thru. This is usually caused by a weak spot in the flex combined with too much current. My best guess is this switch is undersized for this application. The switch will also allow current to flow even when the relay takes over, based on how it is wired. I'm not sure I like this, as if one tends to hold the button is all the way up or down, then that just more current thru the switch for a longer time which means more heat and better change of burning thru. Of course if the switch was better quality or design, it wouldn't matter in he first place.
Anyway, I'm going to take the switch to my lab and try and put a jumper wire across the burned area. This probably will not work or it will just burn in another place in the future. So I'll probably have to get another switch. The problem will be finding a good looking one. All one needs is a Single Pole Momentarily ON switch for the application. From it, run the 2 wires the control board connector (polarity does not matter). It is all pretty apparent once you take the top cover of the vent off (4 screws, 2 each side). The cable that runs from the control pad to the unit below uses a S-Video type connector and is keyed, so you can't get it back on incorrectly. Total cost in parts will be very minimal
For you DIY, remember there is AC voltage levels running thru this switch. Make sure YOU TURN POWER OFF when working on it and know what you are doing. You can get shocked.
Mark
Anonymous
  • 5 Answers
You seem to have a slightly different model, but see a solution at:
http://www.fixya.com/support/t410261-viking_downdraft_ventilator_electrical
it is probably the same thing
Anonymous
  • Posted on Feb 08, 2010
SOURCE: my viking downdraft vent isn't working. I didn't
The halogen light have all gone out (3) is there a fuse and is it hard to find or replace
1helpful
2answers
Downdraft ventilator has stopped working
We have a Viking VIPR101 30" downdraft ventilator. We've learned that the ON-OFF switch on the side of the ventilator can overheat and burn out when it is held down continuously (poor design). Best to push and quickly release it. First time we had the switch professionally replaced--it's modular and very simple to swap out. Next time we fixed it ourselves with switch part # PV300182 from allvikingparts.com. They had replacement guidance on-line. Hope this is useful.
I have a wolf dd36i downdraft cook top ventilator just stopped working it has power and the switch is conected to the remot e
WOLF DD36I USER MANUAL Pdf Download. - ManualsLib
www.manualslib.com > Brands > Wolf Manuals > Cooktop > DD36I
View and Download Wolf DD36I user manual online. ... cooktop. Wolf downdraft ventilation systems are recommended. for use with Wolf electric ... The downdraft will operate most efficiently when ductwork does not exceed 40' (12 m) in length.
No gas on viking professional. ignitor works downdraft does not
There are solenoids that turn the gas on to a burner. If they're bad it won't supply gas to the burner. There is also a mother board on that model that could also be the problem. When it comes to this brand it's difficult to diagnose without being there. If the downdraft is not working then I would guess that the mother board could be the problem...sorry I couldn't help more.
30" viking downdraft goes up & down fan runs and will not responed when pushing on touch panel
After 11 years of use, the same problem just happen a few days ago - fan keeps running, doesn't respond to the on/off switch. Also cannot reset filter alert. As far as I can tell the entire switch panel isn't working. Or worse, shorted out. Might have to replace the ribbon and some switches.
For example the switches can be found at AllVikingParts.com For example --> http://www.allvikingparts.com/Button_Switch_Assy_p/pv300182.htm
There's a another thread on this forum: http://www.fixya.com/support/t410261-viking_downdraft_ventilator_electrical
I'll post the exact solution as soon as I have it figured out completely.
My viking downdraft vent isn't working. I didn't
My computer stopped working!!!!
ok call us at our tollfree no 18884276640
GE Profile Telescopic Downdraft JVB37HBB
mine just did this this morning..a few months ago the button to make it pop up stopped woring so i just started using the wires to operate it...this morning it got stuck uo...i took off the electrical cover and found a burnmark on my circut board...it seems a diode fried or something...im still looking for a replacement
Top Viking Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
