Question about Hoover Dishwashers
HED6612-80 the rinse aid light wont go off
I have a HED6612-80 and the rinse aid light wont go off even though it is full. What's Wrong?
SOURCE: Rinse Aid does not dispense
http://www.partselect.com/ModelFrames.aspx?ModelID=149370&ModelNum=PDB2600AWX&mfgModelNum=&ManufactureID=1&Selected=54869&Position=1&mfg=Maytag&Type=&Mark=3
From diagram RINSE AID & SOAP DISPENSER, replace 138912t.jpg PS138912
Wax Motor for Detergent Cup Actuation.
Posted on Apr 27, 2008
SOURCE: put rinse liquid detergent in dishwasher rinse aid compartment.
I did the same thing with my Maytag dishwasher, several times actually, before realizing I was putting blue dish soap in the rinse aid compartment which then wouldn't empty. Then my Maytag started making ominous noises during the rinse cycle (appliance guy said it was "cavitation" noise).
Appliance guy wanted to replace the whole detergent/rinse aid compartment but since he told me the noise was probably caused by the dish soap stuck in the rinse aid compartment, I decided to try to get rid of it first. Here is the method that worked for me; it took most of a day but saved me parts & labor:
1. Get some white vinegar--I used nearly a quart.
2. Fill the rinse aid compartment to brim with the vinegar (overfill) but don't put cap on
3. Raise the dishwasher door slowly until the vinegar drains into the lower part of the chamber (at least this is how my Maytag worked)
4. Agitate the contents as best you can by rapidly shaking the dishwasher door up & down.
5. I also used a small plastic medicine dropper jammed into small openings on each side of the rinse aid compartment to agitate the vinegar by squeezing air into them.
6. Drain the compartment by closing the dishwasher door (move it to full vertical)--vinegar will drain into the bottom of the dishwasher.
7. Repeat above steps a couple times, then fill again w/vinegar, put the cap on and let it stand for awhile. Then drain and repeat the whole routine several times.
8. Blue-colored vinegar will come out which is a good sign (or whatever color your dish soap was).
9. After awhile, I started pouring generous amts of very hot tap water thru the rinse aid compartment, alternating with white vinegar. (No reason you can't use hot vinegar also.)
10. Eventually, all the blue stuff came out & the see-thru levels of the rinse aid compartment were completely clear/empty.
11. Run the dishwasher (I decided to not put any rinse aid in). I got some overfoaming (from the washed out soap) the first time I ran it which I probably could have remedied by adding more vinegar & possibly salt, but the noises were gone!
I just ran the cleaned out dishwasher a 2nd time & it was back to its quiet self with no overfoaming.
Takes some patience but hey, beats a big repair bill!!
Posted on Apr 30, 2009
SOURCE: blooming on everything in the machine changed from
solved the problem by rechecking all the pipes in/out,filter,rinse aid dispenser and salt cellar. Hey ho the salt cellar was empty!!!! obviously had an elderly moment, thanks for checking back, dont laugh it comes to us all eventually Gary
Posted on Aug 20, 2009
  • 5 Answers
SOURCE: Hoover hed6612 dishwasher wont work
We have had the same problem but have found a fix.
1. If any of the wheels have come off the top sliding basket/rack you need to make sure they are all back on for each wash ( ours are very loose! )
2. Push the top rack in FIRMLY before you wash - make sure it engages at the back.
That's it - solved it for us after months of problems.
I think that as the wheels get worn the top rack does not fully engage at the back and this is when the problem starts manifesting itself. We have some new wheels on order but they are taking ages to arrive.
Posted on Mar 30, 2010
SOURCE: I have a Bosch dishwasher with a rinse indicator
Phone Bosch 08448 928 979 for a step by step solution. Program select at 12 o'clock. Press ON/OFF and Time Delay button together. Press time delay button, display should change from 1 to 0, indicating warning light is inactive.
Posted on Jul 14, 2010
My Miele dishwasher rinse aid light stays on all the time and it is full. Doesn't seam to be emptying when washing?
Sounds like a faulty sensor in the rinse aid compartment. You could try putting warm water in to displace the rinse aid. This might help to free up the sensor if it is either stuck or blocked with residue. You might need to do this several times over a few hours before you notice any change. Don't put boiling water in though, this could destroy the seal
Jan 08, 2018 | Miele Dishwashers
The rinse aid light on my Miele dishwasher won't turn off even though the dispenser is full
There are two ways of dealing with this:
1. Leave it alone, checking the rinse aid every month.
2. Find the fault.
The fault is likely with either the level detector, which will probably mean a replacement rinse aid dispenser or with the cabling. Try disconnecting the detector cables and seeing if the light turns off (make sure it's the detector cables, not the doser). If the light turns off, the likelihood is that the detector has failed. If not, then the fault will lie elsewhere, possibly with the logic board.
Jan 28, 2015 | Miele Dishwashers
My dishwashers rinse aid compartment red light is always on even after fillinf it us with rinse aid
That just means that your dispenser isn't sensing that the ring agent is full. You'll need to order and replace the dispenser to fix the issue.
Good luck
www.ApplianceRepairLesson.com
Mar 04, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have a Bosch dishwasher with a rinse indicator light. When the light is on it's supposed to be indicating that the rinse aid is emptybut my rinse aid container is not empty even though the light is on....
Jun 25, 2010 | Dishwashers
My dishwasher does not always dry the dishes completely - even though I use the same cascade with each use.
The most important thing to getting the best drying from this energy efficient, water conserving dishwasher is keeping the rinse aid dispenser filled. In my part of the US, I only see a rinse aid called Jet Dry.
The Cascade is the detergent powder and will not help the dishes to get dry.
Note: Even with the rinse aid full, some plastics will still be wet.
Aug 14, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
I don't know where to put the Rinse Aid
It might seem silly, but you open the front load fully, so that's it's lying flat and then you pour the rinse aid over the holes in the near left hand corner (where you might otherwise think you have to open the trap door for the rinse). The rinse aid will flow quite neatly into the reservoir and hey presto, once it's full (you'll know it's full because it'll start to back up and overflow) you're back in business. No more annoying rinse aid light!
May 22, 2009 | Bosch Exxcel WFO 2465 Front Load Washer
Rins aid and salt light wont cone on
They are alerts that only come on when you DON'T have enough rinse or salt.
Aug 31, 2006 | Beko 24 in. D3731F Free-standing...
Dishwashers Logo
85 people viewed this question
Top Hoover Dishwashers Experts
Owen Barnes
Are you a Hoover Dishwasher Expert? Answer questions, earn points and help others
