Question about LG Secret ? KF750 Cellular Phone
My lg secret on's but wont go to the menu
My lg secret.. it on but it wont go to the menu. and it just stays with the lg sign on..and i cant even off the phone, i have to take out the battery just to off it....
Tip
All codes Secrets for LG Cell phone
<span> <span>LG all models test mode: Type 2945#*# on the main screen.<br />2945*#01*# Secret menu for LG<br />IMEI (ALL): *#06#<br />IMEI and SW (LG 510): *#07#<br />Software version (LG B1200): *8375#<br />Recount cheksum (LG B1200): *6861#<br />Factory test (B1200): #PWR 668<br />Simlock menu (LG B1200): 1945#*5101#<br />Simlock menu (LG 510W, 5200): 2945#*5101#<br />Simlock menu (LG 7020, 7010): 2945#*70001#<br />Simlock menu (LG 500, 600): 2947#*<br />LG-U81XX SPECIAL CODES</span> <span></span>Code to read phone version :<br /><span><span>- Phone without SIM<br />- Enter 277634#*# or 47328545454#<br />- Select 'SW Ver.info'<br /> Code to reset phone :- Phone without SIM<br />- Enter 277634#*# or 47328545454#<br />- Select 'Factory Reset'<br /> Code to enter UNLOCK MENU :- Phone wit SIM inside<br />- Enter 2945#*88110#<br />Test Menu 8330 : 637664#*#<br />Test Menu 8180 V10a: 49857465454#<br />Test Menu 8180 V11a: 492662464663#<br />Test Menu 8130-8138: 47328545454#<br />Test Menu 8110-8120: 277634#*#</span> <p><br /></span></span> <span><span><span><br /></span></span></span>
on Jan 11, 2011 | Cell Phones
Tip
LG mobiles Test Menu, secret codes and tricks
Here are some common codes for LG cellular phones and there use. Use these codes at your own risk and note that these codes may or may not work depending on your phone model.
Following are the codes:
IMEI (ALL): *#06#
Sim lock menu (LG B1200): 1945#*5101#
Sim lock menu (LG 510W, 5200): 2945#*5101#
Sim lock menu (LG 7020, 7010): 2945#*70001#
Sim lock menu (LG 500, 600): 2947#*
- Phone without SIM
- Select ‘SW Ver.info’
- Phone without SIM
- Select ‘Factory Reset’
on Aug 05, 2010 | Cell Phones
Je veux le code de formatage de lg kc910
LG Secret Unlock code LG Cell Phones Blog
Here is a method to unlock the LG Secret easily and safely. LG Phone Problem and solution
1. insert original sim card and turn your LG Secret on. LG-Secret info
2. Enter 2945#*750#
3. A menu will pop up, select sim unlock
4. Enter your unlock code and press ok
5. The LG Secret will then reboot and the unlock is complete.
Oct 05, 2012 | LG KC910 Renoir Cell Phone
What is the default securety code for the lg ks360 vodafone
Other secret tricks for LG mobile or cellphone
- Phone without SIM
- Phone without SIM
View our Mobile tips and Guidelines for better Handling of Mobile phone.
[AD]
SECRET PRANK
Change closed caller group (settings >security settings>user groups) to 00000 and your phone will sound the message tone when you are near a radar speed trap.
Setting it to 500 will cause your phone 2 set off security alarms at shop exits.
Try this secret trick if you can handle the unexpected.
Note: This secret trick wont work with all phones Models.
THE DETECTIVE TRICK (Mobile Spying)
Now you can spy on anyone using your cellphone. Just do the following.
1. Activate the "Automatic Answer" in the headset profile of your cellphone and set the ringing volume to "Mute"
2. Short-circuit the left middle and right pins on the bottom of the mobile phone with all connections touching each other this will activate profile "Headset".
If you cant do this just keep your earphone connected to mobile.
3. Now place it under a table in a room and call it. Now you can use your phone for checking out what people are talking about in a room. Just call on your phone.
4. The phone receives the call without ringing and you can listen to what people are saying.
Hope this helps.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Jan 20, 2011 | Cell Phones
Tip
Lg secret tricks
- Phone without SIM
- Phone without SIM
on Mar 08, 2010 | Cell Phones
My LG kf750 secret wont start up, wont turn on. It
You could try to hard reset your device, in an attempt to sort your problems out. Be warned that a hard reset will set everything on your phone to their factory defaults, for what you'll loose all the programs you have installed, as well as your personal data. Anyway, to perform a hard reset, turn your phone off completely, by pressing and holding the power button, and, then, answering to the power off prompt. Then, press and hold the Volume Down, the Call, and the Power buttons, until the LED (at the side of the camera) flashes. Release the buttons. That LED should flash in green/red/blue now. When your device powers up, it should be completely cleared.
Hope it works for you, since this is completely theoretical. I have never done it myself.
Regards,
Carlos
May 15, 2010 | LG Secret ? KF750 Cellular Phone
Free unlock codes for LG KS360
you can get your unlock code for your mobile by consultingservice provider ............
this is quite obvious easy way
if you cant do so.........
then you can get it from third party ..........
let me give you the best site i known in this site the presales was excellent even after the purchase there customer support was a+, youcan check them here..
Click Here to get code
Apr 24, 2010 | LG KS360 QWERTY Keyboard Phone BRAND...
Didgivox cant get into secret menu
Its easy press the menu button, the scroll down to system information press ok till the system data comes up, then press 1004 while you are keying in 1004 the will be no signs to say your entering it, but when you press 4 the menu will pop up read what i just wrote carefully an it should work if it doesn't then something is up i got a digivox xl black Good luck.
Sep 15, 2009 | StarTech.com StarView SV431USB 4-port KVM...
I downlaoded a bunch of java games on my computer and put them on my LG secret but I cant get them to work I have them stored in a data file because my games file wont pop up when I plug my phone to my...
More than likely your games were write protected or copywrite material, so that when you moved them from your computer to the phone, they essentially were rendered useless.
Jul 29, 2009 | LG Secret ? KF750 Cellular Phone
LG Secret ? KF750 Cellular Phone Logo
142 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
