Question about Jandy Aqualink Rs4 One Touch Control System Control System
M rs wall unit barley lights up.can the light be
M rs wall control unit does not light up any more.can the light be fixed
I have the same problem. The LED seems to glow only about 10 percent of maximum. Is there a solution to this? I've tried turning off and on through menu, but brightness is almost non existant.
Posted on Feb 01, 2013
    Champion:
  • 246 Answers
Go to menu/display light/on off leave at 2 min delay if this doesnot fix let me know
Posted on Sep 13, 2009
  • TomRoadster Feb 09, 2013
    This did not fix it. Any sugestions?
Fan on the ceiling fan works, light does not, it is an Emerson unit wall switch only not remote control
Try pulling the chain once and then try the wall control. Is it a wall REMOTE or dual control? Do you have the number of the wall control?
Aug 31, 2013 | Hunter 52" Ceiling Fan With Light And...
I have a Jandy Aqualink RS OneTouch Wired Control Panel. The units light is on but there is no LED display. The unit continues to operate and turn the pool pump on and off at the scheduled times,...
It sounds like the unit itself may be out. The acid test would to be to get hold of a new one and switch them out. See if you can find a local pool company to work on that for you.
Dec 26, 2012 | Jandy AquaLink RS OneTouch Wired White...
To switch a Robert Shaw RS 3110 from farenheit to celcius?
First open the unit, as if to remove it from the wall by pressing the release button at the bottom of the unit and tilting it upwards. You should see a bank of 4 dip switches. On my unit these were red. Switch 4 selects temperature units. The circuit board is labelled Fahrenheit. Change this then close your unit and press the reset button.
Jun 22, 2012 | Shaw Electrical Supplies
My neighbors garage door opener opens my garage door. How do I fix this.
Look at the LED light next to the SMART/LEARN button on rear of the motor unit. You may need to remove a light lens cover in order to see it. If the light is flashing rapidly this means you have a stuck button on one of your remote controls. Take the batteries out of each remote control. When you remove the batteries from the bad remote, the light will stop flashing. This remote needs to be replaced.
If one of your neighbors remote controls is inadvertently programmed into your receiver, you door will open when their remote is activated. If this happens you will need to clear out your receiver and reprogram your remote controls. Press and hold the smart/learn button for 6 seconds or until you see the small LED light near the button turn itself off. If the above steps have been followed and the symptoms continue, there may be an electronic short in either the wall control button or the receiver logic board. In this case, remove the wall control wires from terminals 1 and 2 on the motor unit. Should the symptoms persist after the wires are removed, replace the receiver logic board. If the symptoms stop with the wall control wires removed from the motor unit, replace the wall control button, and the wires leading to the wall control button.
Jul 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
The panel back light on myh Aqualink RS All
I don't think so but go through your menu to see if the backlight is enabled. I have never heard of one burning out unless a surge or something fried the whole unit.
Nov 03, 2009 | Jandy Aqualink Rs4 One Touch Control...
AquaLink RS 4 top lights flashing red bottom lights flash yellow
I don't have the "one-touch", but on the "all-button" there's a hole on the left side of the unit. A paperclip inserted in this hole will reset the unit. I had a problem with the display on mine and this fixed it.
Apr 19, 2009 | Jandy Aqualink Rs4 One Touch Control...
Garage door only opens with wall unit
a component in the wall unit is failing , that makes the conection happen when the remote signal is recieved , ( it is recieving the remote signal but not sending it out to the control circuit for the motor )
Dec 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Jandy Aqualink Rs4 One Touch Control System Control System Logo
101 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
