Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Borrowed a Hoover Steamvac to clean my sofa, but my freind lost the operating instructions. How do I hook the hose to the tank?
    President:
  • 389 Answers
Operating instructions can be downloaded free from the Hoover website
Posted on Sep 12, 2009
I want to use upholstery cleaning tool and do not know how to hook it up
Hi There,
I'll be happy to walk you through step by step how you can attach the hose to your Hoover SteamVac.
Here are step by step instructions for you:
Step 1. To prevent possible leaking, remove
clean solution tank by pressing down on
tank handle (D) and pulling forward; set
tank aside (do not set tank on furniture2_bing.gif).
Remove hose from storage rack.
Step 2: Step on handle release pedal (E) and
lower carpet cleaner handle until it rests
on the floor.
Unlatch back part of recovery tank and
remove lid.
Step 3: Remove recovery tank front panel (F)
by sliding it straight up.
Step 4. Replace panel with converter (G).
Slide converter halfway down opening
until it is firmly in place.
Step 5. Before connecting tube (H) to
cleaner, make sure black tabs are
extended by pulling tan collar toward
tube.
Open door on hood labeled “Stair/
upholstery Cleaning Connection”. Press
round solution tube connector onto
round projection inside door. Press connector
collar down firmly to ensure
that it is fully connected.
Step 6. The tank replaces in a hinge-like
manner. Position front of lid under tabs
(I) on front of tank. Rotate lid down onto
tank.
Make sure lid is secure on all sides
before cleaning.
For full suction, it is important that
the recovery tank lid is properly
secured before cleaning.
Reverse procedure to remove hose
and solution tube.
Raise carpet cleaner2_bing.gif handle to upright
position.
I hope that this was helpful to you in hooking up your Hoover SteamVac hose. If you found this helpful, please be so kind and rate my repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair, this is really appreciated.
Thanks again,
Chris J.
GoVacuum.com
Jun 15, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Where do i plug the hose into the vacuum
Hi There,
on the floor.
remove lid.
tube.
tank.
before cleaning.
and solution tube.
position.
Thanks again,
Chris J.
GoVacuum.com
Jun 15, 2010 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
I have lost my owners manual and need to find out how to hookup upholstery cleaning tool
Hi There,
on the floor.
remove lid.
tube.
tank.
before cleaning.
and solution tube.
position.
Thanks again,
Chris J.
GoVacuum.com
May 01, 2010 | Hoover SteamVac F5914-900 SpinScrub...
How do i hook up my stair cleaner part to my hoover steamvac to clean my carpeted stairs? f5909=900 model
Hi There,
on the floor.
remove lid.
tube.
tank.
before cleaning.
and solution tube.
position.
Thanks again,
Chris J.
GoVacuum.com
Apr 25, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Replace accessory hose
i There,
on the floor.
remove lid.
tube.
tank.
before cleaning.
and solution tube.
Raise carpet cleaner handle to upright
position.
Thanks again,
Chris J.
GoVacuum.com
Apr 15, 2010 | Hoover SteamVac F5914-900 SpinScrub...
I lost my instruction manual to my hooversteamvac and need to know how to hook up the upholstery tool
Hi There,
tank aside (do not set tank on furniture).
on the floor.
remove lid.
tube.
tank.
before cleaning.
and solution tube.
position.
Thanks again,
Chris J.
GoVacuum.com
Apr 12, 2010 | Hoover SteamVac F5914-900 SpinScrub...
I lost power.?
Check all filters, hoses, and the bottom. One or all maybe clogged, so you will need to clean it out. Also check the small areas where the hose attaches to the vacuum. Good Luck!
Nov 29, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
I want to clean my sofa. How do you use the upholstery tool?
This operation mauel can be download at Hoover. com. You have a very good machine. The top lid tank is removed, small fron 4 x 4 -inch panel is removed. The hose is put in its place. The solution hose is attached through the front cover. Look for a small door.
May 24, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Cleaning uphoustry
Furniture cleaning isn't a science: try out a few techniques before choosing the one that is right for your belongings. This step-by-step guide explains how to clean a sofa:
  1. Before using any upholstery cleaning products, vacuum the sofa or chair first to remove as much surface dirt and dust as possible. Be sure to use the correct attachments to avoid damage to the material - a soft brush attachment is ideal.
  1. Spot Clean. Using baby wipes or vinegar poured onto a strong microfiber cloth, apply to any obvious stains, wiping gently as you go. Remember to test the upholstery cleaning products on an inconspicuous area first.
  1. Overall Clean. Using soapy water and a microfibre cloth, gently wipe your sofa with the solution, allowing it to soak into the fabric and tackle the dirt beneath the surface. You only want to use a very small amount of water - don't saturate the material.
  1. Dry. Some people use a hairdryer to quickly dry a sofa, but allowing it to dry naturally is always the better option, if you have the time. To speed things up, open windows and allow the breeze to help with the drying process.
House Office Carpet Residential Commercial Cleaning Geelong Commercial...
Apr 23, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover F5807 Steamvac Wet/Dry
how do u hook up the hose to clean the sofa
Oct 25, 2007 | Hoover F5807 SteamVac Wet/Dry Vacuum
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
378 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
