Question about Viking Kitchen Ranges
The door to the larger side of the oven is locked even though it is not self cleaning. I have run a self clean cycle, hoping that it would unlock at the end with no luck.
  • 1 more comment
  • grimslely Sep 12, 2009
    Thank you. What lever and when you refer to a clear button, what do you mean? Sorry! I have no idea what I'm doing
    Thank you so much. I'm not aware of timers on it. Where would they be? I also tried to unplug it from a previous suggestion and did manage to pull the unit from the cabinets (and it might be staying pulled out, cause i can't get it back in:) ) but the connection is not by a plug or anything that I could get to. I'm sorry that I am such an idiot!
    yes thank you
  • 612 Answers
Please keep in mind that I am attempting to diagnose your appliance without being there and with very little information.
Turn your timers on and then off. Make sure they are off. If the lock does not unlock when you do this, find your fuse box and flip the breaker to the unit off for five min's. Then flip the power back on. This should reset the locks, if it does not, I would think that you have a bad lock mechanism.
Please rate solution.
Posted on Sep 12, 2009
    President:
  • 1,129 Answers
Try unplugging the range for one minute and work the lever all the way to one direction firmly then work to the other direction, plug it back in and repeat,also make sure you have pressed clear on the display a number of times, repeat this procedure and also the self cleaning cycle to release door.
Gas range oven door with not open
Your self cleaning cycle is running. When self cleaning is running the door is automatically locked and will not unlock until the self cleaning cycle completes or self cleaning is turned off. You should be able to just turn off the self cleaning cycle and the door will unlock. Do not try to pry open the oven door. You will just damage the door and/or the catch.
Oct 15, 2014 | Amana ARGS7650SS Gas Kitchen Range
Kenmore self cleaning oven 362.75471691
see to it the there was no stuck object or parts on the door parts...
Sep 30, 2008 | Ovens
Used self cleaning process on my oven yesterday and today the oven will not turn on, we keep getting message to unlock the oven door even though it is. What can we do?
The oven gets extremely hot during the self-cleaning mode... the door switch might have got stuck in locked position, or broken in locked position (to be replaced), let's hope it's just stuck...which you'll need to work the mechanical lock-unlock latching back and forth to hopefully unstick....and if that doesn't work just re-run self-cleaning process but this time let the oven cool completely before unlocking the door. Hope this helps.
May 11, 2014 | GE Ovens
After self-clean cycle oven door won't unlock
your lach might have given out on self clean. change it
Feb 12, 2010 | GE Profile JTP18 Electric Single Oven
Oven door is locked
the oven door should only unlock the door when it deems the temperature a safe temperature.. there are 2 other possible reasons.. the door lock motor could be bad.. or the control is bad.. you would need an electric volt meter to test to see which it is.. if you need further assistance please ask b4 rating
Apr 09, 2009 | Amana ACS7270AS Electric Kitchen Range
Crosley self cleaning oven manual
I have a crosley but don't know if it is the same model.
1. move door to locked position
2. Press self-clean pad.
3. press up or down to select clean time (it will flash 3:00)
4. if you wish to delay the start of cleaning press a. stop time b. press the up button on pad to select the time of day then press clock and time of day will reappear. Press stop time pad to recall the time you set.
5. When the oven turns on the oven on indicator will light. Internal lock will engage and door cannot be unlocked.
6. About one hour after the clean cycle ends, the lock indicator will turn off. The oven door can be unlocked and opened.
** to cancel press cancel.
Hope that helps! RC
Jun 21, 2008 | Crosley CE35111AA Electric Kitchen Range
Self-cleaning gas oven
Door lock motor has probably failed.....Self clean on many
ovens can be a self destruct mode. Door latch motors, sensor
probes and even the electronic controls can be destroyed by
this operation. On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. remove the motor and unhook the rod from the motor cam. Sometimes bending a coat hangar into a hook and sliding from the right side into the lock you can unlock the door.
Jun 02, 2008 | Frigidaire Ovens
Whirlpool RF367LXS Ceramic Glass Range not working
Almost every time I run the SELF CLEAN cycle on my Whirlpool Self Cleaning range, it fails to function after completing the self clean cycle, even though it completes the cycle of cleaning and unlocks the door. What I do to solve the problem, I power off the BREAKER for the range at the main electrical panel in the house and wait 30 seconds, then power on....and the whole system works just fine until the next time I clean it. This has been a problem from the beginning. My theory is that the electronics get heated up and, like a computer, the system stalls out and needs a complete hard reboot. Good luck!
Feb 02, 2008 | Ovens
GE Profile XL44 Spectra gas oven
My Spectra XL44 suddenly refuses to ignite the baking portion of the oven - broiler and top work just fine. The day before it was working fine. Wondered if it was an electrical egnition problem - gas feed or what??? Help!! Mregressor@aol.com
Nov 13, 2006 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
15 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
