I unpluged my fans and dont remember where they hook back up
I unpluged my fans and dont remember where they are suppose to hook back up where can I get a inside diagram to show me where everythingis suppose to go
  • 298 Answers
If they have a 3 pin hookup you can plug them into any matching connector on the motherboard.
If they are the larger 4pin then plug them into any matching connector off of the power supply. Make sure the computer is powered off while you do this. Also dont worry, they are all 12v and you can even get 3pin to 4 pin adapters to connect them straight to the powersupply also.
Posted on Sep 12, 2009
How to open tower fan to clean? brand EuropAce model ETF1025
The EuroAce ETF 1025 How to Remove Cover to Clean.
This is for the EuroAce ETF 1025 specifically but may apply to other models. There are two screws on the back near the top where you carry the unit. Remove those two screws.. Next: About half way down the back cover there are two small locking tabs, one on each side. you will need a flashlight to see them. Take a knife and pop them open. its not hard. just wedge the blade in there and gently pry. Next and last: Push the back cover downward towards the base. There are two locking tabs that hook at the bottom of the cover. The cover is now removed. To assemble. Simply do the opposite. Remember ALWAYS UNPLUG before working.
Sep 04, 2012 | Dryers
Hampton Bay Carlsbad 52 in. Brushed Nickel Ceiling Fan. I had an electrician install the unit with two different remots and transmitters (1 came with unit and different one) but none of the remotes operate...
either you have a problem with the transmitter or with the electrican this is an easy job not to much can go wroung.lrt me see if i remember hook black to black white to white and hook up ground. good luck
Aug 12, 2011 | Hunter Ceiling Fan Light Remote Control
When I see video of my radio dvd pd 733bt pyramid, the display says Frease the following: parking brake audio only! what should I do to get out of the sentence is the display?
That is because it has a safety on it to where you can only watch videos when in park. It doesnt want you watching movies while driving. Easy to bypass if you know what your doing. There is probably a wire on the back of the stereo that is in a bundle that you did not use? It should be relatively long. Maybe add a bit of length to it with some more wire and hook it to the ground on your battery if that doesnt work put it on the positive. Sorry i remember doing this in my camaro dont remember if its pos or neg but you are suppose to hook that wire to somthing on the parking break. Hooking it straight to the battery will bypass the parking break safety.
Jun 07, 2011 | Pyramid PDVD78 Car DVD Player
After doing a bios update, the computer will not start. Removed battery, unplugged, then hooked back up, pressed power, fan comes on, cd rom drive flashes, but nothing more. No display.
you might try to take the cmos battery out of the motherboard for couple hours if that dont work which it sound like you might have fried your bios chip, then you might have to have another bios chip installed
May 25, 2011 | Computers & Internet
Hi, My maytag bravos dryer is one year and 2 months old. Suddenly it has stopped drying the clothes, it takes forever to dry a load and clothes are very warm and wet, lots of steam in the dryer, also the...
Sounds like the exhaust fan is not working. There's an electric blower at the back of the unit that forces air out through the exhaust vent. Unplug the unit, pull the vent off the back, and see if you can reach in and touch the fan blades and make them move. If it won't move something is probably caught in there. You may need to take off the back of the unit and remove the housing cover to the fan assembly in order to really tell what's going on, but it sounds like your fan has an obstruction. It could also be that the fan motor is fried but that seems less likely. Remember to have the unit unplugged, there's some dangerous voltage inside.
Jan 03, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
I have a 2007 Yamaha wolverine 350 the oil cooling fan will not come on there was no ATV to pick from
Okay, here is a quick test for you to try.
Unplug the fan and hook a testlight to the plug in and see if you have power going to the fan.
If you do have power, then the fuse/relay for the fan is good.
If you dont have power, then the fuse/relay for the fan is bad. Replace fuse or relay.
To test the fan, unplug it and hook a wire from the negative battery post and a wire from the positive battery post and touch negative to negative and positive to positive for the fan.
The fan should come on instantly. If not then the fan is bad.
If it does come on, then your fan is good and you must not be getting power to the fan.
check the fuse or relay and replace.
Other than that it could only be a broken wire.
Nov 29, 2010 | Yamaha RD 350 Motorcycles
I HAVE A MAZDA 626 LX V-6 1998, HAVING TROUBLE WITH COOLING FAN MOTORS NOT OPERATING WHEN THEY ARE SUPPOSED TO.I HAVE CHANGED THE TEMP. SENSOR AND STILL DONT WORK, BUT IF I PULL THE TWO WIRE CONNECTION...
I know this may seem like a stupid answer but did you remember to check the coolant level? if the coolant dont reach the sensor it wont work properly.
Aug 25, 2010 | Mazda 626 Cars & Trucks
Car overheats. i unplugged temp sensor and fans suddenly came on and coolant started to flow. hoses werent backed up any longer. so i replaced fan relays and car is still running hot
If you unplug the coolant temp sensor the computer will turn on the fans because it doesn't know how warm the engine is. The computer is working like it is suppose to. I think you might have a bad coolant temp sender. If it was a problem with the fans or the relays, they wouldn't come on when you unplug the sensor, because the problem would still be there.
Mar 28, 2010 | 2005 Chevrolet Monte Carlo
Minka F719 Lavery Wired fan and fan works but light does not come
The light leg should be hooked to a power source. If you have a separate wire from a wall switch, that's where it should be hooked. Otherwise, you can hook it to the fan leg and operate the light from the switch on the fan.
Jan 31, 2010 | Minka F719-TSP Treville Tuscan Patina...
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
