Question about True GDM-26 Refrigerator
I have a question on charging a reachin cooler r134a
I am unable to way the charge in so i need to know what the suction pressure should be when the box temp is 50deg,f. and the ambiant air temp is 80deg,f. the cooler is a r134a type
Followed instructions, but coolant wont deploy.
You need to be on suction side of pump check gauge for pressure or suction no suction wrong side with can off
Jul 12, 2014 | Interdynamics AFK-12: Arctic Freeze R134a...
I have a breez aire wkce 1060 r134a.. what should the low side pressure be at/
the low side pressure is defend on the size of your ref.but if it is use in home appliance not in commercial it its range 12 psi more or less but yuo consider the cooling temp. of your suction line but if it look sweating it means your suction pressure is ok if not add refrigerant charge until it sweat.
Mar 12, 2011 | Refrigerators
I am not exactly sure which ac port, High or low side (or both), to put R134a refrigerant into my 1984 LTD Crown Victoria. The ac hasn't worked in about 6 years. Not sure if ac stays charged while...
If the compressor really has sat that long, the seals will be dry and you will not likely be able to keep R134 in it. Always fill on the low pressure side. The fittings are a different size, so your fill hose should not fit on the high pressure side. The low pressure side is along the return from the cooler.
Aug 24, 2010 | 1984 Ford Crown Victoria
Kenmore wine cooler 13485 spill wine in the top not cooling
if suction line is warm and pressure line hot . sounds like comp is trying to do its job / ck the fans and they may be slow or not going . spilling of the wine did not cause problem . .. but now is the time to correct the problem .. mm / ps if unit is running like you state the you might look at the ref charge . as it may be low . mm . hope this hs helped . feed back pls .. mm
Jul 22, 2010 | Kenmore 13485 Wine Cooler
How do you connect a/c charger to make your central air cooler
The 1998 Dodge Caravan ac should be charged at the low pressure service port. This port is located on the suction line near the compressor. The suction line can be identified by it's size, it being the larger of the two line connected to the compressor. You must purchase a recharge kit at your local part store, which should include charging hose with pressure gauge and a can of R134a freon. Gloves and eye protection should be worn during servicing.(freon can freeze your eyes and cause frost bite to your hands). Connect freon to charging hose, connect charging hose to low pressure service port, open valves and start engine, turn on ac. If compressor won't start it may be required to disconnect the low pressure switch and jump out the connector.
Jul 16, 2010 | 1998 Dodge Caravan
Air is not very cold on a rv roof top ac what tools are needed in recharge
You should have the manual for this unit handy and as far as recharging tools go. You only need a can of R134a *(if the unit is R12 you need to buy upgrade adapters since R12 is no longer sold) Run the unit and put the R134a filler line on the low pressure side of the compressor *(from manual...dont guess as trying to charge the high pressure side is VERY dangerous). Get the charge just into the Green zone on your charger and that is it! Try not to fill too high in the green zone....I know it sounds funny...but AC's usually work better when they have the low end of their optimum fill. R134a doesnt work as well as R12 so be sure you buy the R134a with cooling enhancers. Your local Autozone can guide you to the right filler/product combination.
Good luck and be careful!
Jun 30, 2010 | Dometic Rooftop RV Air Conditioner
Head pressure high; suction pressure low. Unit not cooling
Good day,
It's a restriction.
It could be in the liquid line dryer, cap tube as well as the condenser. If it's a R134A system, it's a common problem.
In either case, the repairs can become extensive, with the factory when under warranty, authorizing, replacing the dryer, cap tube,
condenser, and many times the compressor.
Feb 03, 2010 | Beverage-Air DW64 Beverage Cooler...
I have a upright deep freezer modrl u13w/p60335-7w .i lost r12 so i would like to fiil it up so need alocation of the filing point as well as i would like to know that can i fill R134a.also i would like to...
DO NOT PUT 134 IN IT. If it was an original R-12 system, 134 will not work. Most all domestic refrigeration systems are sealed and have no service ports for attaching hoses for service and charging purposes. You need to find the I.D. tag. It should have all the specs on it, including how much refrigerant goes into the system. You may be able to get R-12 from an auto parts place. I've heard rumor that automotive R-12 is of lesser quality than refrigeration grade but I've found no proof. Just rumor.
Good Luck
Feb 22, 2009 | Whirlpool Freezers
True GDM-26 Refrigerator Logo
304 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
