Question about Panasonic DBVSQ-W0044 Remote Control
Panasonic DMR E85H - 48 bit IR transmission Remote Control "TIMER" Button
Hi I have searched for a long time and can't find the code I need.
It is the 48 bit IR code transmitted from the Remote Control when the TIMER button is pressed.
The unit is a Panasonic DMR E85H DVD Recorder.
The number will be something like:
01000000000001000000110100000000 0000 1000 0000 0101
The number above is transmitted from the DMR EX85 remote, when the button "1" is pressed.
Thankyou to anybody who can help. Neill
  • 298 Answers
SOURCE: DVD Remote
You can find the remote for DVD-F87 in the link below.
DVD-F87 Original Replacement Remote
Posted on Mar 28, 2008
SOURCE: Panasonic DMR- EA18 DVD player/recorder - Remote control Problem
I figured out, unlike all the other posts, you don't have an enter button. But Instead, you would hit the 2 and OK button at the same time for a few seconds. I had the RC1 message and I did the 1 with OK and it worked. so if you have RC2, you should hit the 2 and OK. Should work!!
Posted on Jan 31, 2009
nandosnut
  • 112 Answers
SOURCE: Panasonic DVD Recorder DMR-ES10 Remote Control
Your player and recorder are, most likely, on different codes. Press and hold ENTER and 2 on the remote for at least two seconds and you should be home and dry!
Posted on Apr 18, 2009
SOURCE: panasonic dvd recorder "set 1"
The best solution is pressing number 1 and ENTER button in the same time. That's the solution.
Posted on Jul 01, 2009
Hi My Panasonic DMR-E85H Won't let me record to the Hard Drive it is displaying NO REC message on the Display ? Any ideas are most welcome .
it's the same problem with panasonic dmr-e55 recorder ; must we slack them for another one !!! we need help seriously
Jan 13, 2013 | Panasonic DMR-E85H DVD Recorder
My Panasonic DMR-E85H DVD Recorder's hard drive has failed, can I replace it with one from the computer store?
yes thy are usually just common 2.5 standard drives.
dont exceed the storage capcity without checking the unit can address that value via its cmos.
Please rate my help ++++Thanks for using FIXYA
May 13, 2010 | Panasonic DMR-E85H DVD Recorder
Panasonic dmr-e85 locked up. I finally got it to
To setup your IR Blaster (transmitter), hold down the channel up and down button at the same time on you the unit for more than 5 second until the unit says bye and 12:00 flashes, then power on unit and the setup screen will come on your TV.
Sep 15, 2009 | Panasonic DMR-E85H DVD Recorder
Universal Remote says ''RC2'' for DMR-EZ27
Question (s): The remote control for my DVD recorder has stopped working. Every time I press a button, the display says "CHK REMOTE 1", "RC1" or "SET1". What is wrong? Answer/Comments: Your DVD recorder remote control can be programmed (with different codes), so it can be used with multiple Panasonic DVD players. When you press a button and the display shows [CHK REMOTE #] or [RC#] or [SET#] it means that the DVD recorder and the remote control are not set to the same code.To set the remote control code to that of the DVD recorder, press and hold [ENTER] as well as the corresponding code number on the display (1, 2 or 3) at the same time for more than 2 seconds.
Mar 14, 2009 | Panasonic DMR-EZ27K
DMR-E85H Remote is malfunctioning
i can supply you with one if you are intrested?
Dec 02, 2008 | Panasonic DMR-E85H DVD Recorder
Faulty Panasonic DMR-E85H
My dvd DMR-E85H frequently displays self check, then goes blank
for long periods before eventually starting.
May 25, 2008 | Panasonic DMR-E85H DVD Recorder
Zone Free Code for Panasonic DMR E85H
A special remote is used to change the region code. However, to my knowing, it is not availble for the normal consumer.
Mar 25, 2008 | Panasonic DMR-EH50 DVD Recorder
You must replace the inside "str" sheet feeding and condenser close. Everything back to normal. :-)
Nov 25, 2007 | Panasonic DMR-E85H DVD Recorder
Panasonic DBVSQ-W0044 Remote Control Logo
220 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
