Question about Singer 7462 Mechanical Sewing Machine
Have a new singer7463 machine can i wind a bobbin on top without useing machine to sew also when useing machine to sew can i wind a spare bobbin
    Scholar:
  • 35 Answers
To learn how to wind the bobbin on top and select the correct needle, I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional step-by-step repair guide written by an expert. Besides Singer sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learned the repair skills!
Good luck.
Posted on Sep 08, 2010
I can't remember how to wind a new bobbin
there should be a spare thread holder on the machine and a bobbin mount near the drive wheel of the machine. The bobbin goes on the bobbin mount which is pushed onto the drive wheel in order that it is rotated. the thread should be wound onto the bobbin and the the motor should be actuated. This should wind the bobbin. This is usually done with the thread out of the needle.
May 25, 2015 | Sewing Machines
Where can I find the Mandal for an old portable Elna Sewing machine?
you could start at sewingpartsonline.com, they have a list of Elna models with manuals and spare parts. You will need to find the model number however, it should be on the right side panel, a little plate with Tavaro SA and a two digit code number. If its a Lotus code might be 15, 25, 35 or 36. Also, if you do have a Lotus, please go to my solutions and find mine regarding winding a bobbin. The Lotus has no tensioner on the bobbin winding so it is critical that you tension the thread by applying your hand or scissors to the top of the thread spool as the thread winds off it and use your finger to nudge the thread so it feeds onto the bobbin nice and evenly. If you bobbin has wound without tension then the thread will be loose and uneven and you will never get a good stitch from it. Also, check that you are clicking the bobbin thread into the tension spring on the bobbin case. I'll attach an image to assist.
Apr 18, 2014 | Elna Sewing Machines
Wind bobbin frister rossman 420
Hi - if I understand your questions you're trying to wind a bobbin on the top, and haven't got as far as sewing yet.
To do this you usually have to put the bobbin on the top spool for it, and move that into position so that it turns.
To disengage the needle so it doesn't go up and down whilst you wind the bobbin up, on most machines you have part of the main drive wheel (on the far right) which turns against the rest of it, disengaging the part of the drive which powers the needle going up and down.
Or at least that's how it works on most machines.
Jan 28, 2013 | Sewing Machines
I only want to know if the wheel must be loosened to wind the bobbin and if so with direction, to the front or backwards and press and turn or pull and turn.thanks
Which make and model sewing machine do you have?
None of my sewing machines need the wheel to be loosened for bobbin winding. The Singer Touch & Sew bobbins are filled in place. Use the handwheel to get the needle into the highest position (just turn the wheel). Wrap the top thread around the screw that holds the presser foot; open the slide plate part way and press the bobbin wind button. Hold the top thread and then begin winding by stepping on the foot pedal.. The thread should break after a few winds.
The Kenmore and the Husqvarna Vikings both get wound at the top. Place bobbin on winding pin. With the needle up and metal presser foot in place thread the top thread up to the bobbin (through the guides) and up through the hole in the bobbin. Slide the bobbin winding switch over towards the bobbin. Hold the thread tightly and begin winding (step on the foot control). After a few winds are on the bobbin, cut the thread that you were holding flush with the top of the bobbin. Continue winding the bobbin. (The newest Viking in the group has a computer screen; on that one, do not press OK until done winding the bobbin.)
However, if the handwheel is not turning and the needle is down, first find out why it isn't turning properly. This could indicate a tangle of thread somewhere in the system. (The older Husqvarna sewing machine in my home has a non-functional handwheel. The machine will still sew but you have to use the needle up/down switch that forces the needle to stop in the up position before you run out of bobbin.)
Please add a comment with the specifics of your sewing machine and I'll be glad to add additional information.
I hope this helps.
Feb 28, 2012 | Sewing Machines
Broken bobbin winder
For $29 at Hancock, Jo Ann's or Wal Mart you can get a thing called a Side Winder that will wind your bobbins without using the winder on your sewing machine. It has the additional advantage that you can wind while sewing. I use it even with machines that will wind bobbins.
Feb 25, 2012 | Brother XL-2230 Mechanical Sewing Machine
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
Clear bobbin out of thread
Memory Craft has a bobbin winder on top of the machine.  It works beautifully, but wind it on slowly for better sewing function.
Jan 08, 2009 | Janome Memory Craft 9000 Computerized...
Can't wind bobbin kenmore 16221 sewing machine, no manual
On the right side of the machine there is a large knob at the top. Pull that out and you can wind your bobbin. Don't forget to push it back in so you can sew :)
Dec 22, 2008 | Kenmore Drop-In Bobbin 16231 Mechanical...
Kenmore Sewing Machine model # c877.15
I have a Kenmore as well ,I hope that this will work for you ,too bad that I don't live close to you otherwise I would give a hand. This is the way I fill the bobbin on mine. Mine is located on the top right ,I put the thread into the bobbin hole leaving a small piece of thread hanging for me to hold when I begin the winding, I pull the wheele out to stop the needle from moving while winding, when I am done just push it back in .I run the thread from the spool into the top left it looks like a U turn with a screw go around that without winding just pull it into the bobbin hole. press the foot control and it will begin winding .
Jul 17, 2007 | Kenmore 15208 Mechanical Sewing Machine
Singer 7462 Mechanical Sewing Machine Logo
94 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
