Question about Irons
I have a steamglide 2200 iron with water tank, it won't heat up. I have tried with the tank full to max and halfwy but it still won't heat up. There is a green flashing light on the side of the base with a guage on- what does tis mean?
    Sergeant:
    Champion:
  • 214 Answers
Sir, this is the rare problem. you need to replace your iron's heating coil. due to this these type of problem arisses.
thanks for contacting fixya
Posted on Sep 12, 2009
My steamglide model 20393 remains in constant steam mode.
Shot mode? My suggestion is to never use tap water. It will cause your Iron to stain your khakis. Use distilled.water. Water evaporates it develops calcium.
Sep 11, 2016 | Top Irons
Steamglide 2200 not heating up fuse ok
The internal element may have shorted out and thus the sole plate with heating elements will not operate any longer. The cost of repair exceeds the cost of replacement.
Dec 09, 2014 | Irons
Russell hobbs steamglide 2400 iron water solenoid
So am I. Did you manage to source one?
Jan 26, 2010 | Irons
I have a Russell Hobbs Steam Generator iron - less than two years old. It has started to leak water - not really sure where it's coming from - it just pours out and eventually fuses the plug.
My Russel Hobbs Steamglide iron has stopped pumping steam , iron itself heats up but no steam...has the pump gone and can it be reapired
Oct 08, 2009 | Irons
Russell Hobbs Steamglide 2200.Iron and steam station seem to be heating correctly, but will not dispense steam when trigger on iron pressed.
is the water in your area heavy? it may have clogged your iron with stone. soak plate in something like clr .
Aug 10, 2009 | Irons
How to use the calc-clean button
Calc-Clean function
The Calc-Clean function removes scale and impurities.
To do so, set the steam control to position '0', set the temperature dial to 'MAX', and fill water tank up to the 'MAX' level. Then heat up the iron until the pilot light on the handgrip goes out.
Remove the mains plug from the wall socket and hold the iron horizontally over the sink. Then press and hold down the 'CALC CLEAN' button.
Move the iron forwards and backwards while boiling water/steam squirt from the holes in the soleplate to wash away impurities/scales.
When the water tank is empty, heat up the iron to dry it.
Finally move the iron to and fro on a piece of cloth to dry the soleplate. Repeat the process if necessary
May 05, 2009 | Philips HI-296 Iron
Russell Hobbs Steamglide 2200 - no steam
Same with mine! What you have to do is keep taking the water cannister off and pushing back on until its lined up correctley. Also have the whole unit at the same height as the ironing board, that should do it! Can you help with filters? I cant find them anywhere.
Mar 23, 2009 | Irons
My husband threw away the opereating instructions for our iron.
SELF CLEANINGIt is important to “Self Clean” the iron at least every two weeksto remove scale, calcium, etc. The harder the water, the more often the iron should be self cleaned.1. Set the variable steam control dial to any steam position.2. Fill the water tank up to the “MAX” level.3. Stand the iron on its heel. Plug the iron into the electrical outlet.4.Press the electronic temperature control button until you get the “MAX” temperature setting on the display panel and wait until the iron heats up and temperature setting light stops flashing.5. Turn the variable steam control dial all the way to the right to the self-cleaning position and hold the iron horizontally over the sink (Fig. 8).6. Boiling water and steam will now be ejected from the holes in the soleplate. The impurities and scale are washed away with it. 7. Move the iron back and forth as this happens.8. If there is any water left in the water tank after the iron stops steaming, just empty the remaining water in a sink following the instructions for emptying the iron. 9.Turn the variable steam control dial to the “0” position when the water tank is empty.10.Place the iron back upright on its heel to cool down before storing.
Nov 23, 2008 | Euro-Pro Shark GI490 Iron
Irons Logo
168 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
