Question about Dewalt Heavy Duty 2 Brad Nailer Compressor Combo Kit
CAN WE MEASURE IN VACUM IN MM - Dewalt Heavy Duty 2 Brad Nailer Compressor Combo Kit
  • infallible May 11, 2010
    The metric unit of measurement for a vacuum is the Pascal; learn more at Wikipedia.org. How does this pertain to your nailer?
  • 100 Answers
Yes, you could. Usually it is measured in inches and there is 25.6 MM in one inch.
Posted on Apr 19, 2010
Pushrods do long ones go towards exhaust or short ones?
The intake valve pushrods measure 144 mm (5.75 in) long.
Exhaust valve pushrods measure 152.5 mm (6.0 in) long
Mar 11, 2016 | Buick Cars & Trucks
How do I work out the storage capacity in liters?
measure the internal dimensions
length X width X height in millimeters if a box or surface are X height if a cylinder
for example( 50 mm X 20mm X 40 mm)divided by 1000 =40 litres
( 1000 cubic mm = 1 litre)
Mar 13, 2015 | Cars & Trucks
How many MM in an inch
I assume you mean millimeters (mm)? MM would be a million somethings, but not a measure of length.
One inch is exactly 25.4 mm.
Mar 18, 2014 | Cameras
Can you tell me what size the cv axle nut is on a 2001 Chevy Blazer ZR2 4X4?
36 mm is my guess
If wrong 32 mm
Measure nut -- divide by .0395
to get mm
Mar 26, 2011 | Chevrolet Blazer Cars & Trucks
I am looking for drive belts for Sony Model TC-WR801ES stereo casette deck
All you need to do is measure the diameter of each belt in MM. Then put "Cassette drive belt ??mm" into Google and you should find a supplier. Belts are not generally specific to any maker. Also you don't need to be precise on the MM. If you are removing them to measure, make a note of how they fit first.
Oct 05, 2010 | Sony CASSETTE DECK Single Dual Cassette...
I need a leather band for my male cartier roadster
mcdevito75 here, Ebay is your best bet for the Leather band for your Cartier watch, but! you:ll need to know the MM size of the band. Measure the width of the band just as it hooks onto your watch, use a ruler, most rulers have both the MM scale and American, if your ruler has only the American mmeasurement use the online Standard to MM calculator for the MM size from the American or standard measurement. Carefully measure the width of the band just as it hooks onto the watch, count the segments in the ruler either each MM or each 16 th of an inch, convert to MM then look on ebay for the strap.
Aug 28, 2010 | Cartier Roadster W62016V3 Wrist Watch
My hp lazer jet 1600 is making big black horozonal
Measure your marks and replace whatever is indicated by this chart.
Measurement Component
24.7 mm (0.97 inch) Developer sleeve
26.7 mm (1.05 inches) Charge roller
32.9 mm (1.3 inches) RS roller
37.7 mm (1.48 inches) Transfer roller
54.5 mm (2.15 inches) ETB rollers
56.6 mm (2.22 inches) Fuser sleeve
62.8 mm (2.47 inches) Pressure roller
75.4 mm (2.97 inches) OPC
Nov 09, 2009 | Office Equipment & Supplies
I'm looking for the 2000 isuzu rodeo 3.2L v6 connecting rod bearings torque specs.
1. Check the connecting rod alignment If either the bend or the twist exceeds the specified limit,the connecting rod must be replaced. Bend per 100 mm (3.937 inch) Limit: 0.15 (0.0059) Twist per 100 mm (3.937 inch) Limit: 0.20 (0.0078)
2. Measure the connecting rod thrust clearance. Use a feeler gauge to measure the thrust clearance at the large end of the connecting rod If the clearance exceeds the specified limit, the connecting rod must be replaced. Standard: 0.16 mm - 0.35 mm (0.0063 inch - 0.0138 inch) Limit: 0.40 mm (0.0157 inch)
3. Measure the oil clearance between the connecting rod and the crankshaft.
    1. Remove the connecting rod cap nuts and the rod caps (12). Arrange the removed rod caps in the cylinder number order.
    2. Clean the rod bearings and the crankshaft pins.
      1. Carefully check the rod bearings. If even one bearing is found to be damaged or badly worn, the entire bearing assembly must be replaced as a set. Reinstall the bearings in their original positions. Apply plastigage to the crank pin.
      2. Reinstall the rod caps (12) to their original positions. Tighten the rod cap nuts. Torque: 54 Nm (40 ft. lbs.) Note: Do not allow the crankshaft to rotate.
      3. Remove the rod caps.
        1. Measure the width of the plastigage and determine the oil clearance. If the oil clearance exceeds the limit, replace the rod bearing as a set. Standard: 0.019 mm - 0.043 mm (0.0007 inch - 0.0017 inch) Limit: 0.08 mm (0.003 inch)
        2. Clean the plastigage from the bearings and the crankshaft pins.
May 21, 2009 | 2000 Isuzu Rodeo
Which is longer intake or exhast buick3.1
Important: Place the valve train parts in a rack in order to ensure that they are installed in the same location from which they were removed. Intake pushrods measure 144.18 mm (5.68 in) long. Exhaust pushrods measure 152.51 mm (6.0 in) long
Mar 28, 2009 | 1999 Oldsmobile Cutlass
Dewalt Heavy Duty 2 Brad Nailer Compressor Combo Kit Logo
63 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
