Question about Vacuums
Hoover cuts out after 5 minutes and will not restart until its cooled down.
  • Chemist1961 May 11, 2010
    Need to know model and description, ie canister or upright cuts out on rug, on bare floor or all surfaces.Are any indicators on, does it have suction before cutting out? Vacs can cut out for several reasons
    President:
  • 389 Answers
OK - so it cuts out because it's overheating. The cause of this is almost always a blockage. You don't say what model of vacuum this is, so I can't guide you where to look. If you've got flexible hoses, check them. Also check all filters and any other airways you can get at. If you are 100 percent sure that everything is clear, but the problem persists, then the motor's at the end of its useful life.
Posted on Sep 12, 2009
Light keeps blinking
http://www.searspartsdirect.com/partsdirect/user-manuals/uh30010com-hoover-parts-vacuum-manual
WARNING: TO REDUCE RISK OF PERSONAL INJURY - UNPLUG CLEANER BEFORE SERVICING
PROBLEM POSSIBLE REASON POSSIBLE SOLUTION
2. Blown fuse or tripped breaker.
4. Thermal protector activated. (power
light is flashing)
1. Disposable bag is full. ("Check Bag"
indicator illumJnated red)
1. Disposable bag not installed correctly.
3. Brushroll is worn out.
2. Check fuse or breaker in home. Replace fuse/reset breaker.
4. Turn the cleaner off and disconnect it from the electrical
outlet. Then allow cleaner to cool for 30 minutes. If the
thermal protector continues to activate see Needs Service
solution #5.
1. Replace disposable bag - Pg. 9.
1. Review disposable bag removal and replacement - Pg. 9.
3. Replace brushroll - Pg. 10.
Mar 11, 2014 | Hoover UH30010COM Bagged Vacuum
My new Hoover 2100 Model number PU 2110-001 stops for 20 minutes every 4-5 minutes of use. It seems to get too hot. It has done this since new, I have changed the dust bag & all filters, but it makes...
AS new return to shop, Not fit for purpose, they should replace it. sounds as if thermal fuse is tripping in the motor, resets itself when cooled down.
Mar 14, 2013 | Hoover Vacuums
Vaccume shuts off after 5 minutes of using. will only start after sitting for hours.
This sounds like an overheat condition. You must have plugged air flow, so rather than cause a fire, the unit shuts down until cooled. Find and remove the blockage << Not always an easy task.
May 21, 2011 | Hoover U5753-900 WindTunnel Bagless...
Why doe my hoover mach3 stop during operation? I have to wait until the moter cools down.Then i turn on the switch normal way.Then a few minutes latter it stops again.
Your Hoover is stopping because it is overheating. This is a sure sign that there is a blockage somewhere. Find the blockage and clear it, and that should solve the problem.
Mar 20, 2010 | Hoover U6630-900 WindTunnel Bagless...
Stops after a few minutes
Its overheating, so the TOC (thermal overload cutout device) is cutting the power to the motor to protect it.
Thats why it works when it has cooled down.
Check for blockages and make sure the filters are clean, if it still happens take to an approved engineer to check the TOC
Sep 20, 2009 | Hoover U6630-900 WindTunnel Bagless...
Shuts down after 10 min use
I would clean or replace filters on it check the hose to make sure it is not blocked . It sound like it is over heating and making the breaker kick off and after it cools down it resets this is caused by dirty filters or blocked hoses.
Feb 22, 2009 | Hoover U5753-900 WindTunnel Bagless...
No pwer
Our Hoover U5780-900 stopped working while using the attachment. We let it cool down for about 5 minutes and it fired back up. It appears to shut down when it overheats.
Nov 14, 2008 | Hoover U5780-900 Windtunnel Cyclonic...
Hoover wind tunnel
Did you check down by the brush roll for a clog in the dirt inlet. And is the brush roll turning freely, if it is being lugged down, it can cause the motor to overheat and the thermo protector will caught it off, until the motor cools down. But if both are ok, then maybe the motor protector needs to replaced, it is prematurely tripping.
Jun 19, 2008 | Vacuums
Hoover wind tunnel
A clog or partial clog is what causes the motor to overheat, then a thermo protector will cut off and the motor will stop until it cools down. So either you do have a clog, in the hose or down by the brush roll. If they are clear, and the filters are clean, then maybe the thermo protector is bad and needs to be replaced.
Mar 08, 2008 | Hoover 5416-900 WindTunnel Bagged Upright...
MY CLEANER CUTS OFF
My Hoover S3639 on/off switch stopped working. I don't hear the 'click' any more. I removed the top of the vacuum but can't determine how to replace the switch.
Aug 18, 2007 | Hoover S3639 WindTunnel Bagged Canister...
Vacuums Logo
312 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
