I don't know how to use hotpoint washer dryer 1100 wd51 it is made in great briain i need a help in how to use this waching machine if it is possible can i get a catalog on this machine i need instruction
    President:
  • 1,776 Answers
You should be able to get the manual at the link I am providing. Sure hope it helped and best wishes.
http://www.hotpointservice.co.uk/hs/pages/manual/manualSearch.do
Posted on Sep 12, 2009
Hi, my hotpoint Aquarius 1100 washer dryer keeps leaving the soap from washes in the drawer. Any ideas why? Thanks
Try removing the draw and cleaning it thoroughly i would recommend running a few hot washers with no powder through the machine too.
Thankswww.TalkAppliance.co.uk
Apr 24, 2012 | Hotpoint Washing Machines
Hotpoint Aquirius 1100 - WM63 Hi, A leak has sprung from my washing machine and being fairly capable I've already had the sump off cleaned that out and re- attached it and checked the door seal for...
Hotpoint Aquirius 1100 - WM63 leaking This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
May 31, 2011 | Hotpoint Aquarius WD63 Front Load...
Aquarius 1100 - door won't open
lift lid of top reach to front and pull the wire cable up to the door latch make sure u unplug machine first
Sep 07, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint Aquarius WDD440 washer and dryer
Possibly Pump blocked. or impeller broken. without taking a proper look but sounds the obvious.
Jul 26, 2009 | Hotpoint Aquarius WD63 Front Load...
Door Locked. Cannot open. Washine inside.
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Mar 16, 2009 | Hotpoint Aquarius WD63 Front Load...
I have a hotpoint aquarius 1100 washer dryer wd51 was making a grinding noise we turned it off and a under wire from a bra was sticking through a hole in the drum pulled it out and it is complete but now...
The bra wire bears no relation to your present problem.
Remove top cover, screws at rear, and push top cover back.
See if the belt is still on, if it is, then select final spin and see if the motor and drum go round, if it does not, then the brushes in the motor probably need replacing.
Unplug washer, and disconnect the motor. you will find the brushes at the motor plug end, depress plastic lugs, and slide brushes out, if they are less than 5mm long, then replace them
If it is the belt that has come off, you will have to remove the rear panel to refit it.
Plz rate my solution.
Thanks.
Jan 29, 2009 | Hotpoint Aquarius WD63 Front Load...
E30 flashing when I try to start wash program on Hotpoint Aquariu
E30 indicates a motor problem, you will need to call an engineer.
Possible worn brushes which you can do if you know what you are doing.
Nov 24, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WD51 fuse issue
is it the motor that got hot?, if so then check the motor carbons for wear, as these heat up when worn, also if the carbons are fine check the pump and filters for blockages, this makes the motor spin while water is still in the machine causing the motor to overheat, and subsequently tripping and blowing the fuses etc hope i have helped a little
Sep 25, 2007 | Hotpoint WD52 Front Load Washer / Dryer
Hotpoint Aquarius 1100 - Grinding Noise From Drum
This sounds like the min bearings have gone, open the door and see if there is any play up and down on the drum. if so its the bearing if not it could be something that has fallen from a pocket and got stuck between the metal clothes drum and the oute drum casing. a take apart job i am afraid for both issues.
Oct 29, 2006 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
116 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
