Question about Acer AL1916B 19" LCD Monitor
Acer Monitor My 19" wide screen Acer monitor blanks black for two seconds.
  • Otsowalo Jan 16, 2008
    I have the same problem. Just bought an Acer 64-bit Vista Computer with 4 GB RAM) with a 24" Acer X243W LCD monitor.
    After setting up the PC and started working on it, the screen display would go blank for second or two. It is sporadic. It happens either someone is using the computer or not.
    Please help before I send this away for repair or replacement. I'm just afraid that this is typical of Acer monitors.
I've had the same issue with my AL1916 for a couple of months. Now, one morning it decided to call it quits altogether and won't turn on at all.
Posted on Feb 25, 2008
I have this same Issue also. Some days worse than others. I'll just be reading/typing on my computer (not really working the computer at all) and the screen will go blank for 2 sec then back on again. Sometimes its every few seconds for a few minutes. sometimes it lasts hours... any suggestions?
Posted on Dec 26, 2007
    Sergeant:
    Novelist:
  • 143 Answers
You're going to have to provide more info than that.
What were you doing when it happened? What are you typically doing when it happens? Have you checked your cables? Power connection?
As it stands, your inquiry will not receive much of a useful solution for you unless you let us know these things.
And don't rate me poorly for letting you know this. I'm here to help you. You have to HELP US help you.
Cyryl
Posted on Dec 10, 2007
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
I have changed to an Acer 19in wide screen monitor, my photo albums appear as wide screen pics
You need to set the PC video resolution to 1440 x900 @60Hz which is the native resolution of this monitor.
Mar 17, 2010 | Acer AL1916W 19" WideScreen LCD Monitor
Turn on computer and Acer Monitor ( AL1913) and nothing but black screen. Know the computer is good as I hooked another monitor to it and worked fine. Frank
fbwhite, Was your screen also BLANK, along with it being BLACK? The flashlight test would have told you! Yes, it could be both, or just BLACK. Read my FIXYA profile and that of other FIXYA tech's (budmrtn and buddymc) and it will become crystal clear to you the problem your monitor has and the options you have open to you. Good luck with the repair. 12fixlouie
Jan 30, 2010 | Acer AL1913 19" LCD Monitor
It switches on for just a second and then the screen stays blank
yetimonsta, Are you sure that the monitor is BLANK?? Or is it just BLACK? Or is it both BLANK and BLACK? Connect a known good monitor to your pc to prove that your pc is working correctly. What does your L90D+ do when connected to good pc. Have you done the flashlight test to evaluate the state of the "switch-mode-power-supply" when lcd panel goes black /blank?? View more of my profile on fixya and you will discover all the options you have open to you. 12fixlouie
Jan 17, 2010 | Hyundai L90D+ 19" LCD Monitor
Monitor Acer Al 1914, no signal
Check your connections to the PC. Make sure that they are nice and secure. If there is a resolution problem setting it should display the boot process and then go blank after starting the operating system.
Oct 28, 2009 | Acer AL1914 19" LCD Monitor
Power supply on 17" acer monitor
franh, Typical of a lcd/fpd monitor! There is nothing you or hundreds of others can do to repair it all by yourself. I have repaired 3 monitors and helped tutor 2 others on fixya with their monitors. All had same exact symptom as your monitor. I need you to do a simple test for me. With failed Acer monitor near to your Fully Booted PC with a known good desktop being displayed on back-up monitor, quickly swap out the monitor cables from the back of the PC. Keep touching the CTRL key on you keyboarb every 30-50 seconds to keep the PC from sending out sleep mode command to monitor while doing the reconnect of acer to your PC monitor output port. Make sure the Acer also is connected to a live wall outlet/power strip. Turn on the Acer and note what happens. If screen shows a sharp clear image for a second, then goes black, do the following. Get a bright flashlight and shine it on the screen from a distance of 1 or 2 inches and tell me if you can see the desktop display. get back to me with your observations. I'm louie12fix on fixya or lmistyrel@ aol.com.
Apr 05, 2009 | Acer AL1916W 19" LCD Monitor
Black screen
Your backlight is starting to go bad! These backlights are little tiny florecent bulbs, these can be replaced and they do burn out. Sounds like your back light is bad! Could be costly to replace as there are not too many places out there that will replace the bulbs.
Oct 15, 2007 | Acer AL1916W 19" LCD Monitor
Graphics Make Screen go black
Yess...Go DISPLAY PROPERTIES - SETTINGS - ADVANCED CHECK GENERAL AND MONITOR!
Also go to your bios and make sure that PLUG ANG PLAY IS ON ( YESS )
Oct 14, 2007 | Acer AL1916W 19" LCD Monitor
Monitor has a bad sector
I suggest you tackle logic board.
Oct 04, 2007 | Acer AL1913 19" LCD Monitor
Acer AL1916B 19" LCD Monitor Logo
103 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
