I purchased a stack washerdryer at a garage sale. I have it wored and hooked up to the water supply. I strted it through a cycle with no clothes in it to be sure that it waas working. It filled with water and I then urned the dial in order to put it through the cycle. It drained and spun but then when I started it again it would not fill. What is wrong?
  • 601 Answers
Hi
Did you get any error message or any humming noise? If not check whether tap becoming faulty whereby you switch it on but the valve inside doesn't turn. Another common cause is the tap getting accidentally switched off and people not realising. Check any wiring faults, and water valve faults .
Thanks
Smith.
Posted on Sep 12, 2009
Washer will spin to dry but water comes back after short time
how far down is the drain hose pushed in to the drain pipe?should only be like 3 to 4 inches,also the drain hose should be up higher than the water level in the tub.if you can pull out the drain hose try this,fill up the washer on small,after it fills,pull the hose out of the pipe and then stick the hose a few inches into the drain pipe and then turn the timer to the spin cycle and let it drain,after it stops,pull the drain hose out of the pipe,if no water enters back into washer you know that it has something to do with the way the drain hose is in the pipe or another problem.if you're saying that the drain hose is sealed to the drain pipe in the wall you will have to get in there and separate it,pull out the hose and check it,it sounds like this is where the problem is,you had the pump changed and i don't know why the guy would do this if the washer was draining so you know that's not the problem and if they changed the water valve on the washer you know water isn't leaking into the washer from the valve so i would check the drain hose.hope this helps
Apr 25, 2013 | Maytag LSE7806A Top Load Stacked...
Help! I live in a foreign country and my washer just started to do this. The water doesn't come into the machine to wash the clothes. The pipes are hooked up correctly because I had just put a load in 30...
Check the two water hoses on the back of your washer. Turn off water supply and unscrew one hose at a time and check the small filter screen inside the connection on the washer. Also check and make sure the electric water control valve is working properly. ( this is the plastic fittings your two water lines screw into. Remember this valve is controlled by the washing machine timer and (on off ) control.
Hope this is helpful
Feb 11, 2011 | Frigidaire FEX831CS Top Load Stacked...
We just purchased a stack unit and the space is confined so during instalation into a cove we will have to stack the units hook them up to electrical water and exhaust and slide them in.How long is the...
I think you have to but them separate from a hardware store. They come in dirrerent lengths. If you purchased one it seems that you would know that by reading the instructions.
Jan 12, 2011 | Whirlpool LTE6234D Top Load Stacked...
My Maytag washer has no spinning mode while in rinsing cycle. I checked the voltage-it's about 118 to 130 volt consistantly. Please advise.
Our Maytag Atlantis strted having some unusual operation problems and failure to produce clean clothes about 3 - 4 yeras after purchase. The transmission was replaced, no parts costs, reasonable service call labor costs. Has worked good ever since, another 3 years or so.
Call Maytag and they will discuss with you.
Jun 06, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag stack unit Model LSE7806ACE leaks
It is most likely the tub seal. Take the two phillips head screws out of the front cover located low on the cover lift forward and remove. Set the machine two low level and fill with water only no soap or clothes when unit starts agitating look at the bottom center of the clothes tub if water is leaking here then you will need to replace the tub seal and tub bearing assembly.
Apr 06, 2009 | Maytag LSE7806A Top Load Stacked...
My washer will not go to spin cycle,.
Hi my name is joyce,
first lets try to get the water out of washer, put on drain cycle, after it drains water out take clothes out of washer, then lets see if it will run on spin cycle, it may have to many clothes, if this does not help then you have a transmission problem, this will defenently need a technichan to look at it. if you need I can look in you area and see if I can find you some assistance.
Joyce
Feb 06, 2009 | Kenmore 98702 Stacked Washer/Dryer
Detergent goes where?
MLG2000A - Maytag Neptune Super Stack SL-3
1 - Select Wash/Rinse Water Temperature
2 - Select Options (Max Extract, Extra Rinse, Signa)
3 - Select Cycle
4 - Load the Clothes Washer (add detergent on top of the load in the tub, and additives [fabric softener, bleach] in their dispensers).
5 - Start the washer.
This is according to the owner's manual I have. Has worked for 9 years for me.
Jun 28, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
