Question about Monitor Audio Bronze B2 Main / Stereo Speaker
I think my speakers have blown they sound quite bad and no base to them can they be repaired or would it be cheaper to buy new they are monitor bronze br2 they are only 1 and half years old perhaps i didnt run them in for long enough
    Problem Solver:
  • 18 Answers
If a speaker goes "bad" it usually can not be fixed. Speaker systems use different speakers for different tones. This sounds like the speaker used for bass is not working. Check if there is a fuse in the speaker cabinet somewhere. Also, is there bass gone on both speakers?
Posted on Sep 12, 2009
Very low sound on Element 32 inch model no ELCHW321
A couple of possibilities, both will require repairs to the tv. Either the speakers are blown, or more likely the speaker amplifier on the main board is bad. Both are repairable if you want to spend the money. It is probably cheaper to buy a new 32" tv than to have your tv fixed.
Aug 02, 2016 | Element Televison & Video
One of my MR8's has only its tweeter working, im guessing the bass driver might be blown? How can i test this though and be sure it is the bass driver and not just a simple electrical fault?
Open the unit and remove one wire from one of the woofer terminals and using an ohmmeter check the resistance between the terminals. It probably should be between 6 and 16 ohms... they don't give the specs on the speaker... if it is very high or infinite resistance, the voice coil is blown and you be re-coning or buying new speaker. These are close in speakers and intended for a small room for studio listening while mixing. If the speaker is OK, then the bass amp in the cabinet has a failure... pray, as that is cheaper to repair than a speaker.
Sep 22, 2011 | Mackie MR8 150W 8 Active Two-Way Studio...
Hi I ve had the cd10 for a year and it's been used twice . The problem is the amp powers on with out the popping speaker sound the led is showing red which is the powers on but get no sound what so...
Hi there.You may have a blown fuse.Unplug the amp then undo the screws that hold it all together.Remove the wires off the speaker and put an AA battery across the speaker connections(of the speaker).You will hear a clicking sound if the speaker is ok.If not then the speaker is blown.This could also damage the circuitry.Check the fuse(s) and replace with exactly the same rating.Assemble and test if still no go then the circuitry is faulty.You could then take it to a repair shop and ask for a quote to repair it.
It might be cheaper to buy a new unit.
Jul 16, 2011 | Marshall MG10CD 10 Watt Combo Amplifier
Brand New Ampeg Ba 600 210. Only Used durin 2 shows. Sound is awesome. Go to use it this weekend and absolutely no sound at all coming through the speakers. Compression, eq and Everything else working when...
Another person posting on here I suggested opening his unit and he had blown speakers. I think these that are DOA after previous use may be blown during the previous shutdown of the amp driving them and those with built in amps are blown when mixer is powered down putting out a large pulse. Hopefull the amp is blown rather than the speakers... cheaper to repair. Open and check for a fuse, but dont' replace it until you find out the cause of it blowing as additional damage can occur.
May 15, 2011 | Ampeg BA600-210 Bass Combo (with )
The sound coming from my right bose on-ear headphones
i think ur headphone wires or its pin at end will be defective..
99%there is no chance of failures in speakers ..
try to replace ur headphone cable with new cable.
just solder the cable with speaker inline pins..
May 25, 2010 | Bose On-Ear Headphones
Viewsonic VX2255wm - worked this morning - dead this afternoon?
The problem you have sounds like the inverter board has failed it can be repaired by replacing the inverter board which may be a cheaper option than buying a whole new monitor, you can do a search online for lcd repairs and spares to find the part you looking just state your make and model and price one up.
But before you do do that, and you feel confident that you could take the back cover off the monitor, you could have a look for blown capacitors, they are quite a comman fault in lcd monitors, once the back cover is off check the power supply board, it will be where the power cord plugs into the monitor, The capaciters are barrel like in shape with silver tops, check for any leakage from them or on the board surrounding the capacitors, also make sure they are fully flat at the top, if they are slightly domed or pretruded they will need to changed. post back your findings if you do find any bad caps ill will try to explain how to get the right ones and what do to. cheers.
Feb 01, 2010 | ViewSonic VX2255wmh LCD Monitor
Panasonis sa-ht 880
sounds as if you have blown the amp all you need to do is by a amp which would be cheaper than a new system
Jan 28, 2008 | Panasonic SC-HT520 System
Blown subwoofers
If the voice coil is blown the cheaper and the only thing to do is too replace the sub. And if it was a new sub see if under warranty and see if they replace the sub
Probably audible distortion make them blow.
Check the crossover for correct settings. Also if you have them in the wrong size box
Jan 12, 2008 | Dryers
Monitor Audio Bronze B2 Main / Stereo Speaker Logo
153 people viewed this question
Top Monitor Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Monitor Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
