Question about Olympus Stylus 710 Digital Camera
Olympus mu-mini error 5eo2, 5fo2
Im having olyumpus mu-mini .. some times i get a error msg 5eo2, 5fo2 .. i had a problem with my cam shutter .. since then i started getting this kinda error msg..
the simple solution to this error is.. hold the cam upright facing towards sky.. and it works .. when ever i get this error .. i had to on my cam facing it upright .. and it works fine ..!
if any body knows whats the tehnical issue behind this error ..! pls let me know .. thanking u .. nithinjadhav..!
Jeap
  • 114 Answers
SOURCE: Olympus 300 mju
well sometimes that happen, and can be two things 1st the camera got very wet, or the button inside got broken and needs to be replaced.
Posted on Feb 28, 2007
SOURCE: Back to normal setting
give that camera to your brother and make him buy you a new one. if he doesnt do that then read the manual. if you dont understand the manual what makes you think that we could even help you also try to see if theres a help line ..the techs at olympus might walk you though all your problems. or go online and read ..also just try to to put everything in auto mode as you flip through the menu on the camera. good luck CrazyLarry
Posted on Jun 30, 2007
  • 919 Answers
SOURCE: adjust shutter speed
On most indoor shots the shutter speed will normally be 1/30 if you need or want it to be faster than that the only way to do that with this camera is to set the ISO to a higher value. Page 29 of your user manual explains how to set the ISO value for the camera to allow for faster shutter speeds.
Posted on May 04, 2009
  • 11967 Answers
SOURCE: How can i set the shutter speed of olympus fe210 digital camera?
Is this a point and shoot camera? If so, you can't set the shutter speed.
Posted on Aug 13, 2009
virtualhost
  • 2185 Answers
SOURCE: Camera does not start up until after several
If you are sure that your battery if fully charged but still does not do any good, then do this little trick:
1. Hold the camera on your right hand with the lens facing the ground.
2. As you press the power on button, tap or hit the camera's base to your left palm. Do this several times.
Chances are, there could be a sand or granule of dust that got stuck on the sides of the lens, preventing it to retract properly.
Hope this helps.
Posted on Nov 11, 2009
Olympus om2 stuck shutter
I have seen this before, especially on OM2-SPs, the wind on mechanism cam seems to get out of register with the shutter curtain rollers. If you remove the baseplate from the camera (4 screws) and release the cam that drives the first shutter curtain roller, this can release the shutter. You then have to re synchronise the cam with the winding mechanism, tricky, but it does work and can be done with some patience! Good luck!
Mar 26, 2013 | Olympus OM2 SPOT/PROGRAM OM2SP SPARES OR...
When i turn on my fuji polaroid cam, there is an "E" error message. I can't take any polaroid pictures with it altho the polaroid cam is loaded with film. Please help. Thanks
First, remove the remaining films from the camera. (while your camera is switched off) Second, press on both the shutter button and the power button at the same time. (to reset) Third, reload a new set of polaroid films into the camera.
Hope it helps!
Dec 26, 2010 | Fuji instax mini 7S Film Camera
Olympus u-mini 5.0 megapixel - no picture
YES - I had the same problem, sent it to Olympus the repair would cost £128.89. I told them to STUFF it. My advice is buy NIKON. Olympus had the audacity to say "the electronic system requires attention" - as if I needed an engineer to tell me that!!!!!!!!!!!!!!!!!!!!!!!!!
Jul 27, 2009 | Cameras
Got the shutter and mirror clicks and err msg
bring it to your nearest nikon shop for a check up. i suggest a mirror lock up / shutter error.
Jul 26, 2009 | Nikon D90 Digital Camera with 18-105mm...
MEMORY CARD ERROR
Camera is not recognizing any memory card. The issue is with the camera electronics and not the cards.
Jun 20, 2017 | Sharp Viewcam VL-NZ150U Mini DV Digital...
I hve lost the serial no. of camedia c-350 zoom d-560 zoom x-250
To learn about the new and free version of Olympus Master 2 software go to: http://www.olympusamerica.com/cpg_section/oima_softwareMaster.asp Click on 'Free Download' to register your email address to receive an email containing a link to download either the Windows or Mac version. This software replaces all previous versions of Camedia Master 4.x and Olympus Master 1.x and is XP and Vista compatible.
Jan 09, 2009 | Olympus Camedia C-350 Digital Camera
Sony handycam DCR-DVD205: use new ac adapter or reinsert
Remove the battery insert your AC adaptor turn on your DVD CAM if it work fine reinstall the battery set CAM to off position the amber light should be on to indicate battery is charging
You got that msg depend what function you use if the CAM calculated the battery not enough to run or finish this task it display that msg for you to use AC adaptor to ensure no power corrupted such in formating the disc
Some time system control is faulty even you use AC adaptor it still display this msg I hope that is not in your case
Let me kown how you go with this problem
Nov 30, 2008 | Sony Handycam DCR-DVD205 DVD Camcorder
Olympus 760 error d;8234
http://www.fixya.com/support/t513228-olympus_760_error_d_8234
Jul 19, 2008 | Olympus Stylus 760 Digital Camera
Error with IM messengers
First you need the settings for WAP, WEB, INTERNET, PEPPERINTERNET, PEPPERWAP, PEPPERMMS, or similar (they may be called something else) from your service provider.
Call them and they will send you the settings via a txt msg.
You don't necessary need them all.
Then when you start Opera Mini for the first time, follow the instruction on the screen. The Opera Mini will determine the best service to use. Stick to that one, don't delete it from your Tools/Settings/Connection, even if you use another connection for accessing the net with the phone browser.
Jan 31, 2008 | Nokia 6233 Cellular Phone
Olympus Stylus 710 Digital Camera Logo
177 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
