Question about Fisher Ovens
Fisher and Paykel oven alarm reads ''AO''
Fisher and paykel stove/oven alarm keeps going off and display reads ''AO''. What does this mean and how do I stop the alarm?
  • 412 Answers
SOURCE: Fisher Paykel electric oven doesn't heat in Bake mode
Check the Heating Element of your Oven.......
Posted on Mar 20, 2009
SOURCE: fisher and paykel B1600E multifunction stove manual
I have a PDF copy of the Fisher & Paykel B1600E user manual
Posted on Jul 08, 2009
  • 205 Answers
SOURCE: Our Fisher Paykel OS302 completly overheated
The thermostats have probably blown. There is a rebuild kit for this problem, it is not cheap nor is the labor to do it. Try shutting off the breaker for a few minutes... sometimes it will reset, but not heat. In any event you should have the new thermostat kit installed. F/P should at least be able to give you the tele. of a Tech., keep in mind that depending on where you live there are very few technicians that are certified to fix these.
Posted on Jul 21, 2009
  • 6 Answers
SOURCE: Hi my Fisher & Paykel Paprika stove (Model
Yes the regulators/simmerstats are stuffed but are not hard to replace...but please turn off the power 1st when removeing the backing plate as you will kill yourself....yes you will.
Use a multimeter set on volts ac or a volt detector stick, test tester on a known live sourse 1st like a power point....switched on
Posted on Sep 13, 2009
tbirdfan1
  • 3051 Answers
SOURCE: F3 fault code on fisher & paykel wall oven.
hELLO THERE:
on these ovens the f-3 can sometime be incorporated with the f-4 error code also so here is the code and the things to look for both ok ?
F3 - F4 Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control. · Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
If all above is ok replace control.
Posted on Jul 14, 2010
How do you start the clock on Fisher & Paykel
Fisher and Paykel does not know that model number. Could you recheck it please and advise us?
May 09, 2016 | Fisher Ovens
Fisher paykel problem
sounds like you have a problem with the thermostat it may need to be replaced. \you can goole appliance parts and you will see a number of dealers you can get parts from
May 04, 2014 | Ovens
Fisher and Paykel Paprika Oven Top Elements Full hot!!
No controller. The switch for each element (called a simmerstat) is what controls the heat. It is a common fault and will be fixed if you instal new simmerstat for each faulty element.
Mar 17, 2012 | Fisher and Paykel Ovens
I have a fisher & paykel paprika and i cant get
Hi - Are you able to provide model number of the oven - or describe the front controls as they have about 6 different types of controls regardless of the brand name 'paprika'
cheers
Jul 01, 2011 | Fisher and Paykel Ovens
hELLO THERE:
Jul 14, 2010 | Fisher and Paykel Ovens
Our Fisher Paykel OS302 completly overheated during its cleaning cycle. Oven door is locked, nothing comes on and Fisher Paykel will not help, it is only 4 years old, we have made many calls, and certified...
Jul 08, 2009 | Fisher and Paykel AeroTech Double OD302...
Fisher and paykel B1600E multifunction stove manual
Nov 12, 2008 | Fisher and Paykel AeroTech - OS302M...
Ovens Logo
55 people viewed this question
Top Fisher Ovens Experts
Dennis Boxerman
Richard
Richard
ray gallant
Are you a Fisher Oven Expert? Answer questions, earn points and help others
