Question about Brother MFC-9440CN Laser Printer
I have a Brother 9440cn. It will not allow printing as it says that one of the colour toner catridges needs replacing. This is in spite of the fact that I have opened up the Printer control panel in Safari and changed the output colour to B and W. Your assistance would be appreciated. Ben Milecki
SOURCE: Replacing Toner
How to tell on brother mfc-8440 or mfc-9440cn , the total copies printed so far
Posted on Sep 26, 2008
  • 15 Answers
SOURCE: brother 9440cn replace toner message override
well you could shake the toner cartridge, to make sure that the remaining toner has uniform coverage to the developer roller, which is the black magentic roller in the toner, which applies the toner onto the drum.
Only way to fix, if the printer uses a electronic sensor, is to actually change the toner, it can not be overridden.
Posted on Nov 28, 2008
Testimonial: "THANKS FOR THE TIP"
  • 7993 Answers
SOURCE: How to check ink level on brother MFC-9440CN?
Run the Brother Control Center. Click Device settings. Click where it says Inklevel.
A simpler way is Start-->All Programs-->Brother--> ...-->Status Monitor.
An icon will lodge itself on the tray (a printer). When icon is clicked on, the inklevels will show.
Hope it helps.
Posted on Sep 03, 2009
  • 11 Answers
SOURCE: Remove toner catridge from Brother 2170W
Open the front of the face. Pull out the catridge and drum assembly carefully. Thier should be a yellow tab on the toner catridge press down and the lift the toner catridge out. Replace and reseat in printer.
Posted on Sep 09, 2009
rajdeepdutta
  • 2517 Answers
SOURCE: Put in a brand new
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Posted on Aug 22, 2010
My mfc-9440cn prints a black line on the rigth side do you know what could that be? maybe needs new drum?
Hi there !
If you are self refilling the toner cartridge, the roller drum can be damage due to wear and tear. I need to replace new toner cartridge other i will getting wider and wider on both left and right of the paper.
Jan 13, 2011 | Brother MFC-9440CN Laser Printer
Can't get the same colour on my printing page as I see on the screen How can I fix it?
If the toner cartridges have enough toner, there could be dust/ Toner Dust accumulated on the mirrors and lenses inside the printer, which partially blocks laser beams and requires cleaning/ servicing by a professional. Also, make sure that the toners and the print settings on your PC are ok.
Let me know if any further clarification/ assistance is required.
Good Luck!
CreativeTECH
Jan 05, 2011 | Brother MFC-9440CN Laser Printer
How do I set Brother 9440 MFC to print using black cartridge only?
You can set the MFC-9440CN to print with the black toner cartridge only through the printer drivers.
If you are using Mac, this needs to be changed before you print or set a preset.
If you are using windows, follow the below steps.
1. Go to Start menu \ Control Panel \ Printers (devices and printers for windows 7)
2. Right click on the MFC-9440CN and select "printing preferences"
3. Under the "basic" tab, you will see "color mode"; simply select "mono"
Thank you,
Mar 28, 2010 | Brother MFC-9440CN Laser Printer
Toner problems
You have already changes the toner so you have fill the catarage .
Nov 17, 2009 | Brother MFC-9440CN Laser Printer
Red colour toner replaced Cartridge with a new onebut still no print coreect. Replaced the Yellow colour toner Cartridge with a new one but printing is not clear.
this problem regards the head of the catridge. u have to do clean due to dust it may happenlike that. u clean inside with the cotton cloth on the print head and refix the all color catridges. when u remove ur catridge u have to close all the sides due to avoiding dry.
the second reason when u purchase ur catridges, check whether the catridges are valid date.
Apr 16, 2009 | HP LaserJet 1600 Printer
Printer is not printing clear and nice pictures
Dear Cubohr,
You need to check the other colour toners, if the other toners are running low, than you will find that the black tone becomes more prominant in your prints. Alternately, there may be an environmental condition with your unit. If it is in direct sunlight, then it is possable that you are getting light interference on all your prints. There are also a number of other reasons.
Check your toners first, check if there is light interference, if both are ok, your unit may still be under brother warranty and you may need to get it to a brother service centre.
Gremlin11
Dec 10, 2008 | Brother MFC-9420CN All-In-One Laser...
Replacing Toner
Sep 07, 2008 | Brother MFC-9440CN Laser Printer
Brother MFC-9440CN Laser Printer Logo
69 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
