Question about Mitsubishi VS-50707 50" Rear Projection Television
Mitsu. VS-50707 problems
When I press the power button, the tv turns on, then turns off immediately. Just after it turns off, the green led on front (by power button) blinks three times. I did the Error Code Op. Check and it came back "12", or "no error". What could be the problem?
  • 1 more comment
  • stevenssg1 Dec 12, 2007
    TV fuses, or general fuses? Any ideas if this doesn't work?
    I do not have a volt meter. Short of paying someone to look at it, I can't think of anything to do. Reset switch...is there one? I bought this from a friend a year-and-a-half ago, but I don't have a book.
    Yeah, its been unplugged for longer than that at times, and still nothing. Time to call in an expert I think. Thanks for the input, I appreciate it.
    President:
  • 4,402 Answers
12 = No error detected, check power supply.
check all your voltage coming out of the power supply and check the fuses.
Posted on Dec 11, 2007
  • 1 more comment
  • Cary Farah
    Cary Farah Dec 12, 2007
    well there is voltage that would be need to check, do you have a volt meter?
    the other thing that some of the forums say is to replace some capacitors however it's not for this model.
  • Cary Farah
    no reset only unplug for a day
  • Cary Farah
    Cary Farah Dec 13, 2007
    can you please add ratings thank you
TV won't turn on
try pressing in both the menu and the input/device buttons together on the front of the set and hold for five seconds to see if the led blinks a two digit code. Then let me know the blink code.
Dec 27, 2008 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi VS-50707 50 in....
of course..you might want to remove the back panel, and see if all the connections are still secure..
Mar 21, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi VS-50707 shuts down sporadically
you can do a self-diagnosis test by pressing the menu and input/device button on set for 5 sec and see what error code it gives you. Count the blinks followed by a short pause then more blinks. This is the error code.
Mar 10, 2008 | Mitsubishi VS-50707 50" Rear Projection...
VS 50707 turns on, then off immediately
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Dec 10, 2007 | Mitsubishi VS-50707 50" Rear Projection...
TV will not power-on
Nov 14, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi
Please verify Model # and mo/yr built on back of TV........T.
Nov 10, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Flashing Green Light on Front of 73" Projection TV
Oct 12, 2007 | Mitsubishi VS-50707 50" Rear Projection...
50707 does not turn on, goes off immediately code 24, relay clicks
1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB.
Aug 27, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Mitsu dead, help appeciated
ya this tv needs stk packs there are a lot of people inthis area that will fix it for you ie abt
Dec 04, 2006 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi VS-50707 50" Rear Projection Television Logo
116 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
