Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
Lawnmower throttles up and down
Lawnboy mower throttles up and down
    President:
  • 1,129 Answers
Locate the carberator the unscrew the 1/2' bolt under the float bowl to remove the bowl empty and clean out the bowl reinstall making sure the o-ring is centered for the bowl it acts as a sealing ring for the bowl screw the bolt back in and tighten, this should solve the surging problem.
Posted on Sep 12, 2009
How do I reinstall the manual pull cord on a 20 inch lawnboy lawn mower?
I think you need to replace the whole rewind unit as the dawgs must have engaged the starter cup if it was running !
Sep 21, 2014 | Garden
My lawnmower starts but has no power
Make sure the bolt holding the mower blade hasn't loosened and check to be sure the blade is properly centered on the crankshaft end plate.
Feb 24, 2012 | Briggs & Stratton LawnBoy 20Inch 65 HP Gas...
Hi - I have a really old very basic lawnboy - Says it requires 1/2 pint lawn boy lubricant per 2 gallons of gas!! Or 1/2 pint regular oil per gallon. Cannot find lawnboy lubricant, so which kind of...
You need to use a quality 2-Stroke oil in the fuel mix. Do not use engine motor oil. They sell the small (like 2.6 oz) bottles of 2 stroke oil at the Home Depot and Lowes garden centers. Small lawnmower repair shops have it also. It may say Echo or Homelite or even a store brand on the little bottle, but please,again, don't use oil that you use in the engine of your car....use 2-stroke only.
Apr 23, 2011 | Garden
I have a lawnboy self propeled mower model #10533. the serial number is 6907889. i do not know where the spring-choke return spring goes. if i had a picture of it installed i could do it becuase i am not...
For getting big view of picture please click on the link below http://www.ask.com/bar?q=lawnboy+self+propelled+mower+model+%2310533&page=1&qsrc=19&dm=all&ab=5&u=http://www.partsandservice.com/html/Lawnboy/Lawnmower/10533.html&sg=jTUCMw17SUPaA/y4FH3G/QzzCbOKvHGnvkxGP%2Bp36m4%3D&tsp=1276102809824 Part number 5 is what you want to see in the fig and fit. 1 1 Housing, Deck (Incl. Ref. #2 & 40)
2 1 Decal, Danger
3 1 Decal, Deck
4 1 Shield, Trailing
5 1 Spring, Extension
7 2 Screw, Hex Hd.
8 1 Ramp, Discharge
9 2 Screw, Shoulder
10 2 Clamp, Hinge
11 2 Bolt, Wheel
12 2 Knob, Arm
13 2 Washer, Flat
14 1 Seal, Door
15 2 Screw, Thread Form.
16 1 Brace, Door
17 2 Pin, Hinge
18 4 Nut, Lock
19 1 Decal, Warning
20 1 Door, Discharge
21 1 Panel, Vertical
22 2 Spring Arm ***'y, Front
23 2 Bushing, Door
24 1 Cover, Access
25 2 Hanger, Shield
26 1 Cable, Door
27 1 Handle, Hood
28 2 Screw, Tapping
29 3 Screw, Tapping
30 2 Seal, Door Side
31 1 Seal, Door End
32 2 Tire & Wheel Assembly, 8"
33 4 Washer
34 2 Arm, Pivot
35 1 Bracket, Discharge Ramp
37 1 Panel, Screen
38 1 Screw, Thread Form.
39 2 Bolt, Shoulder
40 1 Decal, Warning
41 1 Decal, Instructions
42 2 Cap, Hub
43 1 Decal, AppliqueThis are the parts in your mower.Thanks. keep updated for any morequery.you can rate this solution and show your appreciation.
Jun 09, 2010 | Garden
Lawnboy mower will not idle up under load
the lawnmower is not designed to idle with a load on the engine, it needs to be operated at full throttle
Apr 10, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Lawnboy model 10360 lawnmower. only 1 rear wheel pulls, why? This problem makes it very difficult to use especially on a bank.
Probably a stripped gear or failed rachet component inside the 'lazy' wheel. Not difficult or edxpensive to repair.
Oct 05, 2009 | Garden
Rough low throttle on Lawnboy Dura Force Pro 6.5
IT HAS A WEAK SPRING THATS ALL IT IS
Sep 28, 2009 | Garden
What is the 2 cycle oil to gas mixture for a 2 cycle lawnboy
20:1 gas to oil is a good place to start. Some mowers thin down to 80:1. If you can tell me the model of the mower I can be more specific, but starting at 20:1 will assure you have adequate protection for the engine. If it's exhausting lots of oil smoke after it has warmed up; you can cut back a little each time until you have minor oil smoke.
at 20:1 you need to add 6.4 ounces of oil to one gallon of gas.
Here's a nifty calculator for various ratios:
http://www.csgnetwork.com/oilfuelcalc.html
Enter 1 gallon of gas, then change the ratio number and then press calculate and the number of ounces per gallon will be displayed.
Mar 29, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
759 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
lnbn1975
itsman
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
