Question about Sony NWDB105FB MP3 Player
My sony nwz-b105f shuts down imediately after i power it up,as soon as it says power on it cuts off and if you format the player using your computer i cannot transfer files to my player
  • Sony Master
  • 497 Answers
Posted on Sep 12, 2009
Probably its not the same thing, but my windows couldnt recognize the player it said usb malfunction, i coudnt turn it on either (it just flashed lcd on and of). So i ran the firmware updater connected the usb and pressed reset button on the player and the firmware updater finally recognized the player.
hope it helps some1 ty gl hf
Posted on Mar 02, 2010
  • asd8587 Mar 02, 2010
    not sure if it was clear...
    u have to press the reset while the player is connected to the pc and with the firmware updater running...
Found the problem, well sorta. my NWZB105F wont show in my computer, and the firmware updater wont find it either. iv always had to use winamp to transfer files, no drag and drop for me. but back to the problem, all i did to fix it was delete all files from it using winamp. so im guessing it was a corrupt file.
Posted on Jan 24, 2010
NWZ-B105F - unit is fully charged per the display. I go to power on the player and nothing. I've tried he reset button and still nothing. Any suggestions? Thanks,
Make sure that HOLD function isn't on.
Connect it to the computer and reset it again, leaving it connected.
Check the Sony Support Web site to see if there are any available firmware updates for your model.
If possible, instead of connecting the USB cable to the computer, connect it to a USB AC adapter (if available) and try to charge it.
2GB Walkman MP3 Player
Feb 01, 2014 | Sony Walkman NWZ-B105F MP3 Player
I have a Sony Walkman NWD-B105F MP3 PlayeR. It worked good until yesterday when I wanted to turn it on , the sreen of database/malkman did not changed. Therefore I formated the mp3 player and the result...
Hello every body,
I had the same problem and fixed it using a simple logic.
First Step: Format the Player using the PC. (click with right button on "Internal Device" and select "Format".
Second Step: On the "Internal Device", create this folders: "Music", "FM", "Record" and "Voice".
Third Step: Copy your music into the Music folder.
That`s it!! Go play
Jul 21, 2011 | Sony NWZ-B103FBLK MP3 Player
Sony walkman 9 mos old
donde se encuentran links para descargar los drivers del NWZ-B105F por favor ayundenme, solo muestra "wallkman" al encenderlo
Aug 05, 2008 | Sony Walkman NWZ-B105F MP3 Player
The Sony NWZ B105F Music player
download the nwd-b105 firmware 1.1 (google it) and once you have it connect your mp3 player to an usb port of your pc. run the firmware file you downloaded and check the "delete files" option and run the firmware. you will lose all your files but your mp3 should be functional again. remember that when you do a firmware update you must keep your mp3 connected to the pc, also a if there is for some reason a power failure you may brick your mp3 player. my mp3 player had teh same problem as yours and i fixed it this way. the reason this happens is that sometimes the antivirus delete some system files from your mp3 and thus it cant access its database causing an error and shutting down the mp3 unit. hope this helps!!
Apr 01, 2008 | Sony Walkman NWZ-B105F MP3 Player
Sony NWZ-B105F - trouble shooting
My Sony NWZ-103F, same as the 105F, was doing the same thing “CREATING DATABASE” and then the message “BOOT ERROR, SHUTTING DOWN”. The PC did not recognize the player plugged into the USB port except in the device manager field. I tried all of the other solutions to no avail. This is what fixed it for me.
1. Open CONTROL PANEL
2. Select SYSTEM
3. HARDWARE
4. Click on DEVICE MANAGER
5. Scroll to the bottom of the Manager window and you should see WALKMAN
6. Right click on WALKMAN and select UPDATE DRIVER
7. Choose NO on the first page of the HARDWARE UPDATE WIZARD, Next
8. Choose INSTALL FROM A LIST, Next
9. Choose DON’T SEARCH, I WILL CHOOSE, Next
10. Click on USB DEVICE rather than MTP and let the PC update the driver
11. At this point I rebooted the pc…..don’t know if that was needed, but I won’t hurt.
12. Go to the Sony website and get the latest firmware (1.2) and save it to you desktop
13. Here is the link for the 103F: http://esupport.sony.com/perl/swu-download.pl?upd_id=4177&mdl=NWZB103F
14. Select the format option in the update window when you run it.
That made the MP3 player functional but Windows Media Player 10 still did not see it, so I upgraded to WMP 11 and that did it………all is good!
Hope this works for you……good luck.
Jan 16, 2008 | Audio Players & Recorders
Sony NWDB105FB MP3 Player Logo
713 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
