Question about Nokia N91 Cellular Phone
My menu button has broken and I cant access my menu. Is there any other way to access it?Also how do I format my hard drive from computer?
Windows cannot see external HDD
Which operating system ???...
Install a My Book External Hard Drive
Installing a My Book external hard drive will add additional hard drive storage to your computer. The My Book external hard drive is easy to install and can be moved between computers so that you always have your information at your fingertips.
If you are thinking about an external hard drive, the My Book is a great choice because of how easy it is to install and transport, if necessary.
Meet the requirements for using the My Book external hard drive on your computer.
It is adaptable with Windows Vista, XP and 2000. For a Mac, it is adaptable with Mac OS X 10.4.8 or later.
Take the external hard drive out of the box and inspect it.
It should be in good condition with no flaws in the exterior.
Plug the AC adapter into an outlet. Connect the other end into the external drive.
Plug in the USB connection to the My Book external hard drive on the back in the USB port.
Plug in the other end of the USB connection to the open USB port on your laptop or desktop.
The computer will recognize the My Book hard drive right away.
Access the hard drive by clicking the "Start" button at the bottom of your screen.
When the window opens, click on "My Computer."
Under "Devices With Removal Storage" you will see the external hard drive.
Double-click the icon to open a window to display any contents stored on this hard drive.
http://www.westerndigital.com/en/products/products.asp?driveid=353
http://www.tech-faq.com/external-hard-drive.html
Access an Inaccessible Drive
You can gain access to a working hard drive that is inaccessible when the system starts and assign it a drive letter under the Windows Explorer interface.
Or, you can import foreign disks into Windows or create a partition and format them.
You can scan a drive for bad sectors or lost clusters and repair the system files to allow access to a corrupted drive.
In short, you can utilize the drives as they were intended to be used by completing some operating-system configuration steps that are occasionally required for some drive installations.
Click "Start" (the Windows Orb) and "Computer" to access the Windows Explorer screen. Right-click on the inaccessible drive and choose "Properties" from the context menu.
Click the "Tools" tab and click "Check Now" under the Error-Checking section.
Select both check boxes to allow the system to automatically fix file-system errors and to scan for and attempt recovery of bad sectors.
Allow the system to run the scan the next time the system is booted.
Restart the computer to complete the scan and check for access after the scan completes.
Click "Start" (Windows Orb) and "Computer" to access the Windows Explorer screen.
Click the "Security" tab and click "Edit" to change permissions for the drive.
Click "Users" from the Group or User Names section.
Check the "Allow" box for full control and check for access after the settings are saved.
Click "Start" and "Control Panel" and then click "Administrative Tools" and double-click "Computer Management" to launch the utility.
Click "Disk Management" to display a list of all detected drives in the system.
Right-click in the left column of the inaccessible drive and click "Import Foreign Disk" to allow the system to convert the disk signature to a local disk.
Check for access after the settings are saved.
Right-click in the right column of the inaccessible disk and choose "Change Drive Letters and Path."
If no letter exists, click "Add" and assign a drive letter from the list of available letters.
If a drive letter is listed, click "Change" and select a new letter to eliminate any conflicts with other devices in the system.
Check for access after these settings are in place, which may require a restart of the system.
Click "Start" and "Control Panel" and then click "Administrative Tools" and double-click "Computer Management" to launch the utility. Click "Disk Management" to display a list of all detected drives in the system. Right-click in the right column of the inaccessible disk and choose "New Simple Volume" to create a partition and format it for use.
Click "Next" when the New Simple Volume Wizard appears.
Click "Next" to accept the maximum size for the drive.
Click "Next" to accept the suggested drive letter assignment.
Click "Next" to format the volume with the suggested defaults or change them if desired.
Click "Finish" to format the drive and make it accessible to the operating system.
Restore a Drive That Is Not Accessible
Microsoft Windows operating systems support a large number of file system formats including FAT12, FAT16, FAT32 and NTFS.
Hard drives are typically formatted with either FAT32 or NTFS, both of which can be used for years without issues.
Damage can occur to the file system through a sudden power outage, malicious software or lack of maintenance, rendering the drive unreadable or inaccessible.
Run the Chkdsk utility in Windows to resolve file system corruption and restore access to the hard drive.
Select the "Start" or "Globe" button and then click "Programs." Click "Accessories" and then right-click the command line icon in the menu that appears.
Click "Run as Administrator" in the drop down menu that appears.
The command prompt will display.
Enter "chkdsk C: /F" substituting the "C:" with the letter assigned to the drive that cannot be accessed, and then tap the "Enter" key.
Enter "Y" and tap the "Enter" key if a message appears that states "Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)."
Let the disk scan run and fix the drive, or if the scan does not start, reboot and let the scan run and repair the drive.
http://technet.microsoft.com/en-us/library/cc730714%28WS.10%29.aspx
Enable Drive Letter View
Click the "Start" button and choose "Control Panel" from the start menu.
Click "Folder Options" and navigate to the "View" tab.
Scroll down and place a mark next to "Show drive letters," then click "OK."
Configuring Drive Manager
Click the "Start" button to launch the start menu.
Right-click "Computer" and choose "Manage" from the menu.
Click "Storage" in the menu on the right side to extend the section.
Click "Disk Management" under the "Storage" header.
This will show you a list of drives and removable storage on your computer.
It will also report the status of the drives, such as "Healthy."
If the removable storage does not have a drive letter or has a drive letter in conflict with another drive, you can assign it a new letter.
Right-click the icon of your removable storage drive and click "Change Drive Letter and Paths."
Click the "Change" button, then choose a drive letter from the drop-down menu.
Select a letter that is near to the end of the alphabet to prevent drive overlap issues.
Click "OK" to allow the changes to take place.
You should now see the removable storage listed with your other drives on the "My Computer" screen.
Sep 06, 2013 | Western Digital My Book Essential Edition...
External hard drive cant format into ntfs but only exfat
The propriety NTFS file format is used by the Windows operating system to format internal as well as external hard drives. You can format an external hard drive with the NTFS format using the built-in program included with the Windows operating system. The procedure is straightforward and does not require any additional software. An NTFS-formatted external hard drive can then be used with any PC running a version of Windows that is later than Windows 3.
Plug the cable attached to the external hard drive into a USB port on the PC. Right-click on the "My Computer" icon on the desktop. Select "Manage" from the drop-down menu. Click on "Device Manager" in the left column of the window that appears. Click on the "+" icon next to "Disk drives" that is in the column to the right of "Device Manager." Right-click on the icon of the external hard drive. Select "Properties" from the pop-up window. Click the "Polices" tab at the top of the window that has replaced the pop-up window. Click the "Optimize for performance" button below "Policies." Click "OK" to close the window. Right-click on the icon of the external hard drive in the center column of the window that is still open. Select "Format" from the pop-up menu. Select "NTFS from the "File system" drop-down menu in the new window that appears. Click the "Start" button at the bottom of the window. Wait as a progress bar appears at the bottom of the window and fills in from left to right. Click the red "X" at the right corner of the window once the progress bar has completely filled in. format usb memory stick to ntfs http://www.online-tech-tips.com/computer-tips/format-usb-ntfs/
Overview and history of ntfs format http://www.pcguide.com/ref/hdd/file/ntfs/over-c.html
Apr 02, 2013 | Maxtor OneTouch III Mini Edition 120GB...
External hard drive not accessible
A Hitachi USB external hard drive is a device that acts as portable, removable storage for your personal computer. If you need additional space to house files on your computer but don't want to go to the trouble of installing an internal drive inside the case, a USB external hard drive is your best option. These drives are "plug and play" devices, which means that very little can actually go wrong. If you're having problems, fixing them shouldn't take more than a minute or two.
Check your connections. A USB cable needs to be connecting your Hitachi external hard drive to your computer. Your external hard drive's power cable also needs to be plugged into a functional wall outlet, surge protector, extension cord or power strip. Make sure your Hitachi USB external hard drive is turned to "On." An "On/Off" button is present on the front of the unit. If the indicator light around said button is not illuminated, the drive is "Off" and your computer won't be able to recognize it. Press it to turn it on and then try to access your drive again. Format your hard drive. If your Hitachi USB external hard drive doesn't currently have a file system on it, you won't be able to use it to store data. Open up the "Computer" icon in the "Start" menu. Right-click on your USB external hard drive's icon and click "Format." Click "Start." This will install a file system on your Hitachi USB external hard drive. After this process is finished, you will now be able to use your drive. Restart your computer. Certain models of computers (especially older models) won't recognize new hardware unless your computer boots with the hardware already connected. Leave your USB drive plugged in and restart your computer. Once you do this, your Hitachi USB external hard drive should appear as normal in the "Computer" folder with all of your other drives. Hope this helps.
Jan 08, 2013 | Hitachi Travelstar 7K60 (DK23FA60) Hard...
I want to turn a memory stick into hard drive. How can i do that?
you will need usb data drive at least 4 - 8 gb
Download the GParted Live utility and the HP USB Format Tool via the links in Resources.
http://www.majorgeeks.com/downloadget.php?id=5757&file=15&evp=fb0a8fee133295405b5af3205e8d2424
Insert your USB stick into the computer. Run HP USB Format Tool. Select your USB stick and then choose the FAT or FAT32 format options. Click "Start."
Extract the files from the GParted Live zip file. Select the USB stick as the destination.
Open a file browser and navigate to the USB stick. Select "utils" > "win32" > "makeboot.bat." Double click on "makeboot.bat." Enter "Y" when prompted.
Power off your computer leaving the USB stick inserted.
Connect your portable hard drive to another USB port.
Power on the computer and quickly press "F8" through "F12" to access your boot menu.
Check your computer or motherboard manual for the exact keystroke.
Select the USB stick as your boot source and press "Enter." Allow the Gparted GUI to start.
Select the external portable hard disk drive. Click "Partition" on the menu bar.
Hover over "Format to" and select "NTSF."
If you are unable to create or format the partition, select delete partition.
This will erase all data on the external hard drive. Confirm partition deletion. Select the external drive again. Click "Partition" and hover over "Format to" then select "NTSF."
Select the external hard disk drive again. Click "Partition" on the menu bar and then "Manage Flags." Check the box next to "Boot." Save and apply changes to the drive.
Power off your computer and remove the USB stick.
Install the OS
Insert or plug your OS installer, usually a DVD, CD or USB thumb drive, into the computer. Power on the computer and access the boot manager again.
Select the source containing your OS installer and press "Enter."
Enter your personalization and registration information if required.
When prompted, specify the portable hard drive as the install directory.
Begin the installation normally.
Restart the computer when prompted and access the boot menu again. Select the external hard drive as your boot source and press "Enter" to ensure the installation succeeded.
Use this process to boot from your portable drive on any computer.
hope this helps
Oct 02, 2012 | Sony Vaio VGNBX196SP
Cannot format hard drive message appears : hard disk cannot be formated" all 20 hard drives on different computers giving me same problem
lets get all of the details first you say you cant access the hard drive then the message cant be formatted how are you trying to format the hard drives what procedure??? will need more imformation a hard drive must be formatted from a ""third party disc""
Apr 09, 2011 | Seagate Barracuda 7200.7 40 GB Hard Drive
Hard disc is curropt and needs to be repaired but does not repair and will not allow navigation
How to Access Playstation Recovery Menu
1. Turn off Playstation®3.
2. Hold The power button down; The system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be promted to plug in your controller via usb and then hit the PS button
6. The Recovery menu will pop up.
have you tried options available in this menu?
Dec 19, 2010 | Sony Playstation 3 (PS3) Console
I cant format my hard drive, its asking me to enter password
Use a bootable cd. do the format from that menu. alternatively, use third party bootable softwares to format the hdd.
Mar 29, 2010 | Acer TravelMate 4220AWLMi Notebook
Drive is detected by computer but when tried to access it, computer freezes up and cannot access external hard drive
First attempt to format it. If that doesn't works, restart your computer and acces the BIOS SETUP menu, and check if the drive is well read by the BIOS. If that doesn't work, then you may have to call the warranty.
Nov 20, 2009 | Western Digital External USB 2.0 80 GB...
I cant access the d partition on my hard drive
Hi...
Do you want to access the drive d and get your files. You can not access it when you double click the drive. The drive will says access denied. To access the drive d open My Computer you can see there a address, there is and arrow there just click. Chose the drive d to open i am sure that you can open it.
Regards
PCmania
Aug 27, 2009 | Computers & Internet
Help Me
first insert your pendrive.Now right click on my computer.Go to manage option . select disk management. From that you must select your drive letter for your pen drive.Go to Action menu near to File menu.Fromthat select all tasks and select formatting.Then again goto all tasks and select change drive letter and paths.select the drive letter and your problem is solved. thanks for asking your problem.
Aug 25, 2008 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Nokia N91 Cellular Phone Logo
93 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
