VCR problem - the tape gets caught inside the machine every time I try to play a cassette. It's an LG combination VCR and DVD player
    Brigadier General:
  • 4,090 Answers
To costly to fix, it needs new guides. Cheaper to replace this as its now old technology. Find a good second hand one
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Posted on Sep 12, 2009
My VCR/DVD combo wont play a VHS tape when inserted. Each time I insert a VHS tape, it shoots it right back out and sometimes unravels the tape around the apparatuses inside the VCR. It won't reco
the tape coming back out and unravels the tape means the loading mechanism is the problem----when a tape goes in it loads the tape down, then it pulls the tape out of the cassette and puts it up against the drum with the video heads-----many of these are belt driven and a bad belt or belts will cause this----it is called the loading and or transport mechanism.......when it fails the arms come back but the tape does not get rewound back into the cassette so it mangles it when the cassette door on the tape closes----most likely a belt or the drive idler which also rewinds and fast forwards the tape.
Oct 16, 2012 | Philips Magnavox DVD/VCR Dual Player
When I put a VCR tape into my LG V271 DVD/VCR to record, it plays and when I push record, it ejects.
Hi,this is a normal reaction of the recorder..in order to protect the pre-recorded VHS tapes there is a "Breakable tiny plastic part" on the back of cassette..You cassette might have that part broke and missing ..to correct the problem ,pls apply a scotch tape to cover that area (hole ) and than try to record again.. Hope this helps! Take care and please Remember to rate/vote and
give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Aug 26, 2011 | LG V271 Player
LG dvd player/vcr combo' dvd works fine. vcr records/play, has sound has NO PICTURE? PLEASE HELP
Possible that the VIDEO HEAD is dirty , could be clogged with ferrite dust or fungus from an old cassette. If you have a cleaning tape please try it ON the set for sometime.
If not a manual cleaning can help but with great caution as the tiny ferrite heads on the Head drum is very fragile. So use a piece of paper to carefully rub along the drum using soft action , DO NOT ATTEMPT HARD ACTION GET THE FERRITE CAUGHT INTO.
If there is no result the head can be faulty but it can be confirmed after a close check up or a continuity test after removing. Require good experience to attempt.
Feb 22, 2011 | LG V271 DVD Player/VCR
FUNAI DVD/VCR COMBO
You need to replace all rubber bands inside the VHS.Vary difficult to find rubber band kit.If you use the TV in the heat, u must place a fan of some kind in the back blowing IN to cool the insides of TV. [AFTER U REPLACE rubber bands]
Jul 30, 2008 | Funai PY90VG DVD Player/VCR
Tape Problem
When a VCR eats a tape, it can be cause by a couple things.
1. There is a rubber wheel called a "pincher wheel" that compresses the tape against the "capstan". The capstan is a shiny metal spindle connected to a motor. The pincher wheel can become worn and/or dirty (slick) from the oxide coating off of the tape. You can try cleaning the pincher wheel and capstan with alcohol or try using a re-grip solution on the pincher wheel. Last thing to do is replace the pincher wheel. Look to see that the pincher wheel is doing its job by pulling the tape through. The pincher wheel & capstan are not used during a fast forward or fast rewind, so if your tape is getting caught during the FF or RW and not Play, it's probably not related to capstan & pincher wheel.
2. There is a small tire wheel called an idler tire. This tire pivots between the sending and pickup reels of the player. Its also used during fast forward & rewind as well as play. If the tire is worn, the tape won't be wound up as fast on the take-up reel as the sending reel during play. This means more tape is coming out of the cassette than can be wound up on the takeup reel. You can try using a re-grip solution on the idler tire or replace it.
3. There's also a brake pad that is designed to grab and stop the tape wheels from spinning when you hit stop. If those pads are worn, the wheels will not stop fast enough and the tape will continue to feed (spool) out of the cassette and not be taken up by the other wheel.
So when when you hit eject, the excess tape that should have been wound up tight in the cassette before the eject sequence, is getting caught inside the player.
Let me know if I can be of further assistance to you.
- Jim
Jun 27, 2008 | Mitsubishi HS-U776 VCR
Lg v181 combo problem with vcr keeps ejecting tapes when I want to record.
The tape load carriage is defective or there is something in the way inside the machine....accordianman
Feb 21, 2008 | LG V181 DVD Player/VCR
Video tape problem
get a dvd player u cheap skate
Feb 18, 2008 | LG XBR446 DVD Recorder/VCR
VCR kicks out cassettes
Sounds as if something got bent in the loading mechanism when you freed the stuck tape. Careful examination of the loading operation with the cover off may reveal the problem, but you may require a service shop, as there are hazardous voltages present inside, even when switched off.
Jul 13, 2007 | Toshiba MW24F52 24" TV/VCR/DVD Combo
Eats tapes
3. You didn't say if the unit played ok. There's also a brake pad that is designed to grab and stop the tape wheels from spinning when you hit stop. If those pads are worn, the wheels will not stop fast enough and the tape will continue to feed (spool) out of the cassette and not be taken up by the other wheel.
- Jim
Feb 20, 2007 | Symphonic WF803 DVD Player/VCR
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
Electro Med Services...
