Question about HP Compaq 6720s Notebook
Upgrading My hp530 laptop
Hi guys i have 1 year old laptop HP 530 Business notebook....working fine....i thinking of upgrading it.
Current configuration is: Intel 945 GME Express Chipset Intel Core Duo(1.8GHz)Processor. 512mb DDR2 ram(2 SODIMM Slots)
80 GB HDD
My question Are: Can i upgrade its RAM to 4gb or atleast to 3gb? Can i upgrade Its HardDisk to 320 gb....? will it Affect my system performance....?
Kindly Help.. Thanks in advance
  • Prathamesh Patkar Sep 12, 2009
    thx...i found some Hp530 laptop having ram 3gb.....i also found out on one site that max supported is 4gb
    the site: http://www.memory-up.com/memory_Finders/...
    Thank u alot......the advise was really helpful.....i will surely go for it and u u a feedback....
It is working.
Tested first with one new module with 2GB RAM, then with 2 modules, 2GB (new) + 1GB (original). Post and Windows are showing 3GB.
The HP 530 notebook is working OK.
Posted on Mar 12, 2010
  • HP Master
  • 13,433 Answers
Hi
RAM installed 512 MB Max supported RAM 2 GB RAM technology DDR2 - for laptops
so 3 and 4gb are out of the question.
The hard drive is a SATA - 2.5" laptop hard drive, the 320 should work in my opinion but I can't guarantee it 100%, you may want to take it to a local professional that can first test the 320 drive on the laptop before you purchase it. if it doesn't work buy a smaller drive.
the 320gb drive wont affect performance much, it will give you more room for your files.
the memory upgrade to 2GB will help ALOT.
Posted on Sep 12, 2009
Testimonial: "Thx alot...."
  • Ekse Sep 12, 2009
    To make sure I told you the right stuff I wen't and got the service manual for the laptop, I see that the Intel Core Solo T1400 1.83-GHz processor which I assume your laptop now has is the best available, but since this document is few years old(2007) a newer cpu may work.
    Also what it says on memory it says:
    Memory modules (667-MHz, PC2-5300, 1-DIMM) maximum for 1 slot - 1024-MB
    Hard drive part lists 120GB hard drive has bigest available well again as a old document there may not have been bigger ones available, will probably work with a bigger one.
    if you need help in replacing the hard drive or memory yourself this service document will help you
    http://bizsupport2.austin.hp.com/bc/docs...
    page number 36 on pdf reader tells about memory replacement.
    HP website does offer a BIOS update that may help the laptop to work with newer CPU's, Hard drives. But I think its unlikely to help on the memory.
    http://h20000.www2.hp.com/bizsupport/Tec...
  • Ekse Sep 12, 2009
    I also went and looked up the Mobile Intel® 945 Express Chipset
    System Memory Support
    • Supports single-/dual-channel DDR2 SDRAM
    • Maximum Memory supported: up to 4 GB at 400, 533 and 667 MHz
    • 64-bit wide per channel
    • Three Memory Channel Configurations supported:
    — Single-Channel
    — Dual-Channel Symmetric
    — Dual-Channel Asymmetric
    At this point I don't know who to trust, Try a 2GB module see if it works, if it doesn't then go with 1GB modules.
My hp530 wont charge morethan 60% what can i do to fix it
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 10, 2012 | HP Business Notebook 530
How do I reset HP530 notebook bios password?
call HP tech support and work with them to get BIOS master password. System BIOS password maintained in non-volital RAM cannot be reset without original password or Master generated by HP
Oct 11, 2010 | HP Business Notebook 530
Wnnt to upgrade my memory on my HP530 laptop but can only fine one memory slot under the bottom of the computer where is the other one?
They are both on the bottom and stacked on top of each other. It comes with only 1 512MB normally. You should be able to add another one or replace both with 1gb. You tube has a good guide to doing his search youtube for
Installing notebook RAM - HP 530 - IT247.com
Apr 02, 2010 | Computers & Internet
Hp530 turn off suddenly
Get a power charging adaptor from HP (if a smart adaptor) or a generic anywhere that matches your spec. Your device is doing what mine did, but in addition mine beeped softly as a warning of failure. Being a smart adaptor, I had to order one from HP, a generic won't work.
Sep 05, 2009 | HP 530 Notebook
My laptop is hp530 notebook i formated it but the
Hi.
Go here to HP support, download and install the audio drivers and anymore drivers you think you may need. >>>>>>>>>
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=uk&prodNameId=3375995&prodTypeId=321957&prodSeriesId=3375953&swLang=8&taskId=135&swEnvOID=1093
Good luck and thanks for choosing FixYa!!
Jun 05, 2009 | HP 530 NoteBook Intel Core 2 Duo T5200&
Please send me a code for upgrading hp 530
you mean a windows code
what are you upgrading to and how old is the system
Jan 20, 2009 | HP 530 Notebook PC
Can not install XP
Why not? What happens when you try? Please, we need more detail.
Oct 31, 2008 | HP Business Notebook 530
Upgradeable?!
RAM - 512 MB (installed) upgradable upto 2 GB (max)DDR 2 SDRAM ( 1 x 512 MB ) that means your laptop has only 1 slot for memory.. ____________________________________________________
Was this solution helpful .Show your appreciation by rating it.
dilipbagdi - Technical Associate
Jun 09, 2008 | HP Business Notebook 530
HP Compaq 6720s Notebook Logo
2,577 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
