Question about Sony BRAVIA KDL-40V3000 Television
Sony kdl-40v3000 standby light blinks 10 times. anyone got an idea what this means?
  • Sony Master
  • 497 Answers
Follow these steps and check if help to resolve the issue:
1. Disconnect all the attached external device (if any) and then try turning ON the TV.
2. Remove the surge protector or power strap (in any), directly connect the TV to a working Power outlet and check.
3. Try changing the power cable (if possible).
4. If the issue persists then Service may require to resolve it.
Good Luck!!!!!!!!!!!!!!!!!
Posted on Sep 12, 2009
Sony bravia kdl-40v4100 . The standby light is flashing red 2 times an television and there is no picture or sound . Relay dls1u an power supply board is clicking on/off .
Two blinks denotes an over-current protection. If you wish to get more details about the blinking codes to Sony TVs, check this site. Details are there. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 19, 2013 | Sony BRAVIA KDL-40V3000 Television
My Sony Bravia, model KDL-46XBR4's standby light is flashing 6 times. We have reset it 3 times but after several days it shuts down and continues to flash the standby...always 6 times. Can anyone tell...
I am experiencing exactly the same problem. TV turns on but within 60 seconds the screen goes black and the red standby light blinks six times. Were you able to resolve this problem on your TV?
Oct 17, 2010 | Sony KDL-46XBR4 46 in. LCD Television
T.v on standby, red light flashing 3 times, wont switch on
Shutdown with a 3x blink pattern occurs if the 12v from the power supply (GF1 or GF2 depending on model) is lost at CN6153/pin 6 to the AU Board Q1224 to Sub Micro IC1205. The suspects, in order of likelihood, are (1) Power supply and (2) the AU board.
Aug 11, 2009 | Sony BRAVIA KDL-40V3000 Television
When turning on the screen comes on for 2 seconds, then red blinking light flashes 13 times and repeats flashing.
Standard blinking codes for Bravia sets for US only goes to 10 blinks which points to faulty or short circuited components inside whereas the Australian range of KDL's goes to 13 blinks of the LED which points to a faulty balancer and must be taken into a service department.
Aug 02, 2009 | Sony BRAVIA KDL-40V3000 Television
Sony fb3 boad kdl40v3000 Our tv would not turn on except the flashing standby light. Technician told us we need to replace the fb3 board. The cost is $395 for the board and $185 labor. Is this reasonable?...
This is not a unusual amount for repair. Most repair facilities do not like using used parts on sets they have to warranty after a repair. They would then be liable if were to fail and then they would be replacing it at a greater cost to them. You could check with Sony and see what their retail cost is on the part. Their Customer Service Line is 1800-222-SONY.
I hope this helps,
skyassoc
Jul 24, 2009 | Sony BRAVIA KDL-40V3000 Television
Sony Bravia KDL-40V3000 standby light blinking
I just worked on this last week 13 blinks means there is a problem with the backlights.So it can be 1 of 2 things bad inverter board( which costs less than $200) or the panel in which case you can thow the TV away as it will probably cost as much for a new TV.Unfortunately the set I worked on ended up being panel. If you try the inverter board just take your time removing it its plugged in rather tight I gently tapped it out with a screwdriver to get it started.
Rustym62
The TV Dude
Apr 27, 2009 | Sony BRAVIA KDL-40V3000 Television
Sony KDL-40V3000 standby blinks 13 times.
A service technician arrived at my home this morning and infromed me that 13 blinks indicates a bad LCD panel. His quote to repair it was approximately $500 more than the TV initially cost. I contacted Sony support directly, and they have agreed to replace the TV, since it is less than 30 days out of warranty. The KDL40V3000 has apparently been dicontinued so they are replacing with a KDL40V4100(factory reconditioned). I know this won't necessarily help others with the same problem, but if your warranty ended recently enough they will probably work with you to mitigate the expense.
Feb 20, 2009 | Sony BRAVIA KDL-40V3000 Television
Sony Bravia KDL-46Z4100 Standby light flashing 13 times
This sounds like a power source problem! (faulty transformer) I would pack it up and take it back for a new one!
This is a problem you can not fix yourself unless your a pro!
Please rate my response!
Jan 15, 2009 | Sony BRAVIA KDL-40V3000 Television
Sony KV34XBR800 Red Flashing Standby Light No Power
The red light should be blinking a code. For example it will blink 4 times pause then 4 times pause or 5times pause 5 times pause, whatever the error might be. Let me know what it is and then we can help more.
Tim
Experttv@comcast.net
Sep 07, 2008 | Sony BRAVIA KDL-40V3000 Television
Sony BRAVIA KDL-40V3000 Television Logo
597 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
