Question about HP Pavilion dv9000z Notebook
Scrambled screen at startup
I cannot start my computer normally it loads up and then the screen scambles i can only start in safe mode
  • 77 Answers
Have you tried to run system restore?
Posted on Sep 12, 2009
  • leahlyn olaivar
    leahlyn olaivar Sep 12, 2009
    have you tried to run system restore?
Scrambled screen
could be any number of things... Bad cable, intermittent connection, bad video card. . . not enough info here to diagnose the problem
Aug 31, 2014 | Dell OptiPlex GX620 PC Desktop
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
Aspire 5475 freezes on startup
It is most certainly a driver, but if you cant access the safe mode also that could be a hardware issue.. Try to troubleshoot with a windows installation cd. Put it in and boot the pc. It will start the windows instalation, you choose repair computer and not install windows. The command prompt will open, try to troubleshoot from there.. Thanks!
Mar 19, 2013 | Computers & Internet
Running in safe mode as normal start up is really slow or does not load.
Follow this trick to fix infected Laptop:
Disable Unwanted Programs from Running at Windows Startup
Running too many programs at the Windows startup reduces the system performance. To speed up Windows 7, you have to disable the unwanted third-party programs from running at Windows startup.
  • Click Start ' Type MsConfig and press ENTER
  • Click Startup tab.
  • Uncheck the entries of the programs that you do not wish to run at system startup.
  • Click Apply.
  • Do the same for the entries in the Services tab.
  • Click Apply ' OK.
  • Restart the computer when prompted.
To fix this problem instantly use PCFresher system utility.
Jan 17, 2013 | Dell Inspiron 1545 Notebook
I have a presario cq61 and have forgot my password can u help
Try starting the computer in safe mode. Turn on the computer and once the COMPAQ screen clears press F8 a few times - don't hold down the key however. Winodws stops loading at teh Startup Options screen (black, text only). From that menu use the cursor keys and ENTER to select "Safe Mode". Once Windows loads (it may look humungous!), login as the Administrator (which should now be visible). Use this account to reset your forgotten user password. Restart once complete - the computer will automatically start normally.
Apr 14, 2011 | HP Compaq Presario CQ61420us Notebook
I cannot get passed the loading screen. Doesn't boot up. Just seems to go in a loop.
Hi, try go to safe mode ( before loading screen, press F8 and select safe mode, ) if it goes on to safe mode, goto; Start ->Run..->type msconfig ->goto stratup startup.
uncheck all the entrys, and boot the machine normally, if it boots normally, start adding the entrys one by one, until it failes to start. report back.
Apr 06, 2011 | Computers & Internet
How do you put windows into safe mode?
Power on or Restart your computer, keep tapping F8 on the keyboard while it boots up. After few seconds, you'll be taken to the "Advanced Boot Options" with "Safe Mode" in the lists. Use the Up-Down arrow keys to highlight the "Safe Mode" and press enter on the keyboard to confirm the selected boot options. Black Screen with white texts will be displayed on the display, wait for few seconds until you see the windows logon Screen. You'll also see a confirmation message box asking you to confirm to boot into Safe Mode, click "yes" or "Ok" and proceed forward. There now you are in the Safe Mode.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 26, 2010 | Computers & Internet
My cumpaq laptop is powred on . The screen is on but no icons
before windows loads up...
hold F8 key.. will show menu for windows
select safe mode
once in safe mode if icons show up.. restart and let it
load as normal.
If no icons in safe modeyou will have to do a restore from
windows.. what version is it?
if icons in safe mode but no icons in normal windows then
you have something in startup causing the problem
we can check this from registry or msconfig..
keep me posted
May 21, 2009 | Star Logic 17" LCD Monitor
Gateway laptop mx3414-black screen cannot load windows
Try going into safe mode upon startup by hitting the F8 button. If it does then hit safe mode to get into your computer. Go to start>accessories>system tools>system restore. Follow the wizard to restore your computer to a date earlier than when you started having problems. Let me know if you have any problems or questions.
Mar 19, 2009 | Gateway MX3414 Notebook
HP Pavilion dv9000z Notebook Logo
470 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
