Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Whrilpool refrig, smells hot, so i cleaned the coils and turned it off for a few hours, seems cooling fine
    Sergeant:
    Champion:
  • 214 Answers
Sir, your refrigerator need a servicing. so please call the nearby service engineed to checkup the compressor condition, refrigerant pressure, etc.
thanks for contacting fixya
Posted on Sep 12, 2009
Subzero 532 refrig fan(& compressor) doesn't shut off
the higher the number on a fridge the warmer it is so setting it to 1 is close to 0C
when working on a fridge or freezer always turn it off at the wall
if the fridge is keep cold but not cold enough set it back to say 3
if the compressor is running and the back fins / wall is hot then the fridge is working
use a piece of paper between the door seal and the fridge edge to ensure that it is sticking to the fridge and sealing off properly
Jul 16, 2017 | APW Wyott SubZero Refrigerator Freezer...
The strip between freezer and refrig become hot then cools off. It's like it is going thru a cycle. We cleaned the coils underneath, but it is still getting hot and then in about 15 minutes, it's...
When you cleaned the coil underneath did ya notice that their was air being blown out their by a fan,having clened the coil was a good start but if the fan by the compressor isn't running that divider between the ref/freezer will be hotter than normal( its normally warm and thats ok),so check that the condenser fan is running and that it seems to running at a good speed.
GENE
Sep 23, 2011 | Whirlpool GC5SHEXNS Side by Side...
I have a Kitchenaid S x S KSCS25INSS00 refrig/freezer. We lost power for 30 hours, it worked fine before the outage, now it won't cool the fridge below 48 degrees, or the freezer below 43 degrees. ...
Try replacing the circulating fan first. If it's not turning, it's more than likely bad. However, the fan might not be your only problem. The problem may lie with the icemaker. The icemaker is essentially the brain of the unit. It tells when to cool, when to defrost and when to maintain temp. Your icemaker may be stuck in defrost mode.
Sep 04, 2011 | KitchenAid Superba Architect KSCS25INSS...
My kenmore side by side/ model 55771/ is having the same problem.
Is the fan running by the compressor and are your coils clean under refrig ? also make sure the cardboard panel is on the back of the refrig .
Jul 22, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Whirlpool Refrigerator metal between doors hot; fan ok
You have either a bad compressor cooling fan or dirty coils under refrig .
Jul 17, 2009 | Kenmore Refrigerators
Rattling noises from ac
If you are careful unplug it, tilt it 45 degrees back and use a hose spray sideways to remove the debris from the coils. It worked for me. Be careful not to get any of the electrical parts wet.Low pressure from hose
Jul 03, 2009 | Maytag Portable Air Conditioner M6P09S2A
No air coming into refrig to cool
We pulled the back panel in the freezer and found the coils frozen. We defrosted the coils and the fridge started working. We will be getting a new timer. Thanks
May 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
DOOR JAM BETWEEN FREEZER AND FRIDGE IS GETTING HOT
This usually means that your condenser fan has stopped. That's the fan outisde (under or in back of) the fridge. It should be running whenever the compressor runs. Heavy accumulation of dust or anything that obstructs airflow could also cause it. But the most likely culprit is the fan.
Nov 05, 2008 | Frigidaire Refrigerators
GE side by side Refrig. with evaporator iced up solid.
Yes ill be glad to help John. Your refrigerant level is fine. Remove the motherboard axcess panel on rear of refrig. Locate 3 wire blue plastic connector on bottom of board. Wires are labeled Comp, Line, Def. Jump Line to Def and see if heater gets hot. If nothing happens than replace the heater. Let me know what happens.
Dec 04, 2007 | Kenmore 91365 Compact Refrigerator
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
46 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
