Question about Epson Stylus Photo 1290 InkJet Printer
Paper jam on Epsonstyles Photo 1290. How do I clear it?
    President:
  • 2,185 Answers
Open your printers cover and remove any paper that got stuck. If they are stuck between the rollers, gently pull them out. Look for any tiny paper shreds that might be blocking a sensor or might as well stuck between rollers.
Posted on Sep 12, 2009
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Red light on
Red light comes from two cases
1. paper jam
2 ink cartridge life end
please check your printer
Feb 22, 2014 | Epson Stylus Photo 1290 InkJet Printer
The green power light and the red warning light are flashing alternately E_Mail colin_hoyle@yahoo.co.uk
Check the printer properly, if there is any paper jam, or any thing that is preventing the print head moving . also check if there is any message showing on PC. Write in details.
Thanks.
Jan 16, 2011 | Epson Stylus Photo 1290 InkJet Printer
My Epson 1290 (some years old) doesn't grab paper, especially good inkjet paper) properly. It passes straight through, prints on the roller, and/or I get messages saying the paper isn't loaded properly or...
That could be from the rubber rollers not being able to grip the paper. They get polished or shiney over time with use and age. Then they slip or pull incorrectly and you get your problems. There are other things that can cause this but nothing worth fixing.
Fixing the rubber rollers is easy. You need some ispropyl rubbing alcohol and a paper towel. Make sure it is isopropyl type as this won;t attack other parts. Simpley wet the paper towel and wipe down the rubber rollers. You will see the rubber go from a dull shine to dull flat rubber. This takes off the buildup on the rubber and lets it grip again. Eventually the rubber will age harden and this trick won;t work but this can give you years more service.
Apr 20, 2010 | Epson Stylus Photo 1290 InkJet Printer
Epson photo 1290 red light on all the time - will not work
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Apr 03, 2010 | Epson Stylus Photo 1290S InkJet Printer
Paper jam indicated. Unable to clear.
please your printer toner is out of printer and
so in paper ? check the aply paper tray in fixed paper ?
and out print roller behind paper fixef ?
and aply power is on and aply print test?
Sep 22, 2009 | Epson Stylus Photo 1290 InkJet Printer
My epson stylus photo 1290 sounds like its printing but theres no ink on the paper, there is ink in the cartridges
HAVE YOU TRYED WIPEING OFF THE PRINTER HEAD WITH A DAMP CLOTH TO CLEAN OFF ANY DRY INK OFF THE HEAD ?
Apr 14, 2009 | Epson Stylus Photo 1290 InkJet Printer
Epson 1290 paper feed problem
wow..springs that are weakened...unfortunately, that's one key weakness in these sort of printers. When I do a repair, if the springs are shot(not unlike a car, eh?), it's time to replace em. Not much can be done to restore the tensile strength of something like that.
Got Backup?
Feb 07, 2008 | Epson Stylus Photo 1290 InkJet Printer
Epson Stylus Photo 1290 InkJet Printer Logo
93 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
