Hi We have just bought a 40
Hi We have just bought a 40" lcd tv, and we are looking for a mounting solution. However we are in an old rental property with lath plater walls and are concerned that the plaster will crack. We would like to mount the tv onto an old brick chimney breast. The brick is now covererd by lath plaster as well, with the brick underneith. We're just wondering what's the best way to do this without cracking the plaster. The tv ways approx 40 pounds.
Otherwise we also considered creating/buying some kind of freestanding mount that could sit on the chimney mantle. However the mantle is only 16 centremetres deep. (out from the chimney breast) I haven't been able to find anything with a small enough base that would be able to sit on the mantle and hold the tv up. Any assistance would be much appreciated.
Louise
Tv won't come on tried all the trouble shooting ideas in book but nada
hi if you brought the tv in november might best to get in contact where you got it from ask them to send a tech out, you won't have to pay as it should be covered by the warranty good luck
regards
shaun
Jan 23, 2014 | Universal 40-42 Inch Flat Screen Panel...
Looking for a table top mount for my Sony Bravia 40" TV (KDL 40V3000). It's no longer available from the manufacterer. Is there a universal mount that will fit?
I would check with MCM electronics who sells nearly 100 different universal mounts for many sets. They have a online catalog.
Dec 02, 2012 | Sony Bravia KDL-40S4100 40 in. LCD TV
Hi I have a digimate tv model modl lt321c2m1 and I am wondering if I can mount it on the wall. Can I?
Please look on the back, there should be 4 mounting holes (for Metric screws) Iin what is called VESA mounting pattern. Just measure the pattern.
http://en.wikipedia.org/wiki/Flat_Display_Mounting_Interface
When you buy the mounting bracket, it will come with a bag of Metric mounting screws to attach your TV to the bracket.
Jun 13, 2011 | Digimate DGL32 32 in. LCD Television
I just bought a sony kdl40ex400, 40" lcd tv and when i first turned it on the picture quality was poor and there are 2 vertical blue bars running down the screen at all times how do i fix this
The tv Tuner signal board is bad,must be replaced.This tv is new,bought it,under a year old?So this tv is still under warrenty.Call Sony for a warrenty repair.
Oct 16, 2010 | Sony KDL40EX400 40 in. HD-Ready TV
No screws to mount AKAI LCT3701AD LCD TV.
Hi i bought mine at home depot for a few dollars they were very helpfull there and they worked great...
Feb 03, 2010 | Akai LCT3701AD 37 in. LCD Television
I have recently bought a Samsung SM2033HD TV and want to wall mount it. I can remove the base but how do I remove the collar that joins the base to the TV.
Your tv is not fully VESA compliant. You cannot remove the collar. There are mounts available that grip the screen instead of screwing into the back. This type will look better.
Jan 10, 2010 | Samsung LE40R74BDX 40 in. LCD Television
My SOny Bravia 40 inch LCD TV has a vertical line
It could be 1 of 4 things:
1. One of the ribbon cables has worked itself loose (Simple Fix)
2. One of the assembly boards maybe faulty
3. The driver board which feeds the panel maybe faulty
4. The panel is faulty
The driver board in the UK costs approx £70 and approx £35-70 to fit it if this is the fault.
All other parts are between £80-160 and approx £35-70 to fit it if this is the fault.
The panel will cost approx 50-75% of what the TV was worth when you bought it - "Repair versus Replacement"
Thanks
Oct 01, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony Bravia 40" LCD TV Stand
There is a slotted area on the bottom of the unit and the bracket on the stand slides over top of it. There should have been four screws that came with the packaging that fit in the four locations in the lower center of the cabinet back that secures the unit to the Stand.
I hope this helps,
Skyassoc
Aug 25, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Samsung lcd tv le40r8
if the unit is under warranty call samsung for the nearest authorized repair place. the problem is a bad main board.
Feb 24, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Electro Med Services...
