Question about Samsung SyncMaster 540N 15" LCD Monitor
Samsung 540N monitor. Takes more time to start the display
Display will be blank for more than 5min and then the display comes. This happens even if I've not connected monitor to the computer. I could see that the blue light slightly flickers every 3-4 secs.
Please help
  • 525 Answers
This is capacitors problems inside the monitor. If you have some tools , screwdrivers, soldering iron and some experience, open carefull the back of your monitor after to unplug from the outlet.
you will see in power supply board a capacitor who which the top has changed . replace that capacitor.
Posted on Sep 12, 2009
    President:
  • 1,653 Answers
This could be down to a faulty interface cable between the PC and Monitor.
  1. Check for any bent or receding pins in the plugs at both ends of the cable.
  2. Also make sure that when the cable is plugged in that you use the securing screws / posts to secure it to the sockets.
  3. Check that the cable has not been physically damaged, cut, crushed or bent over very tightly as all of these can degrade the signals between PC and monitor.
If all else fails then replace the cable. They are freely available from PC dealers and from eBay.
Lenovo g470 vga display issue
fn + f3 change display
fn + f5 wifi on/off
May 03, 2017 | Lenovo G470 Core I5-2410m 2.9ghz 4gb 500gb...
Dell laptop not detecting external display
Usually the external monitor and laptop screen toggles in one of three states.
LCD only
External monitor only
Both LCD and external monitor
Wait a couple of seconds between when you press Fn F8
This model laptop may not allow ectended display.
May 29, 2012 | Dell Latitude D830 Laptop Computer PC...
Compaq Presario SR1750NX wouldnt come on, installed dynex 400 watt atx power supply now it comes on & fan runs but monitor is still blank. Installed ATI RADEON 7000 GRAPHICS CARD, still nothing, the...
After adding new graphics card monitor display will not work with motherboard display connector.
So, connect your monitor VGA cable with your graphics card display port.
Thanks for using FixYa.
May 22, 2011 | Computers & Internet
Display coming for 2 sec and then it goes off
Does it work well with other computers?
If you are connecting to a laptop, try switching display modes (like you would do for a projector)
Sep 03, 2009 | Acer AL1916W 19" LCD Monitor
Dell s2209w with a GeForce fx5200 blinks black
Make sure your refresh rate is not set too high. for the 192N it should probably be not much higher than 60Hertz
Jul 31, 2009 | XFX GeForce FX 5200, Graphic Card
Benq FP92G Display couple of seconds then blank. LED still green.
budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Jun 01, 2009 | BenQ FP92G+S (Black,Sylver) (Silver,...
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
My HP monitor (f50) has malfunctioned
Try these 2 steps if they don't work get back to me :)
Step 1. Connect the video cable and turn on the computer. What happens?
  • If the monitor screen remains blank (no startup screens or onscreen display messages), the monitor must be connected to another computer using a different cable to determine if the monitor is bad. Skip to the Step to connect the monitor to another computer.
  • If the monitor is capable of displaying boot screens but is unable to display Windows, use the following steps to set the computer to a compatible resolution:
    NOTE: Find the native display resolution for your monitor in the User Manual or in the product specifications for the monitor model. If you are unable to find the native display resolution for your monitor model, temporarily use 1024x768 for troubleshooting purposes.
    1. Turn on the computer and press the F8 key repeatedly when the first startup screen appears.
    2. If you are using Windows Vista, select Enable low resolution video (640 x 480) , press Enter , and wait until Windows opens. To set display settings that match the monitor, use the steps in the HP support document, Changing Display Settings, Background Image, and Screen Saver in Windows Vista . If you are using Windows XP, select Enable VGA Mode , press Enter , and wait until Windows opens. Continue using these steps to set display resolution. If you are using Windows 98 or ME, select Safe Mode and perform the following steps to enter into a standard VGA mode:
      1. Once Windows opens to the desktop in Safe Mode, click Start , and Run .
      2. In the Open field type msconfig and press Enter . The MS Configuration Utility window appears.
      3. Click the Advanced button, and select VGA 640 x 480 x 16 if it is available.
      4. Click OK and restart the computer.
      5. After Windows opens, click Start , and then click Run .
      6. In the Open field type msconfig and press Enter .
      7. Click the Advanced button, and remove the checkmark next to VGA 640 x 480 x 16 .
      8. Click OK . Do NOT restart the computer.
    3. After Windows opens, right-click on an open area of the desktop and select Properties (Windows XP, 98/Me) or Personalize (Windows Vista).
    4. In Windows Vista, Scroll down and click Display Properties . In Windows XP, 98, or Me, click the Settings tab.
    5. In Windows Vista, select the native display resolution size using the Resolution slider. Set Colors to Highest (32 bit) . In Windows XP, select the native display resolution size using the Screen resolution slider. Set Color Quality to Highest (32 bit) . In Windows 98 or Me, select the native display resolution size using the Screen Area slider. Set Colors to True Color .
    6. Click Apply after you have made your adjustment. The screen should blank out temporarily and come back.
    7. If you are satisfied with the new display settings, click Yes on the Monitor Settings windows. If you are not satisfied or if the screen just goes black, wait: Windows sets the screen back to the way it was before. Try another setting until you find a display configuration that is compatible with the monitor and meets your needs.
      NOTE: If the native resolution is not available, download and install updated video driver software for your computer. Updating the video driver software can add more resolutions (graphics modes).
    8. Restart the computer. The monitor should now display a full screen image in high quality. You are done.
Step 2: Connect to another monitor
Using a different cable, connect the monitor to another computer that has video. Turn on the monitor and the newly connected computer. What happens?
  • If the monitor works, the video hardware on the original computer is likely to be the source of the problems. You can try connecting the original computer to another monitor that works to update its video drivers.
  • If the monitor remains blank, repair or replace the monitor.
Dec 27, 2008 | HP Pavilion F50 17" Flat Panel LCD Monitor
No Display on Monitor (Princeton VL1917)
Try leave it for some time and try it again to the PC, when you connected it to the laptop it must have auto configs it selfself too suit the laptops resolution.
Nov 24, 2008 | Princeton Digital VL1918 Monitor
My monitor goes blank repeatedly
1. First u can check any dry points in power supply board and controlling circuit.
2. check all connectors (connected properly)
3.To replace front pannle Micro switches.
Oct 04, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung SyncMaster 540N 15" LCD Monitor Logo
572 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
