Question about HP LaserJet 3050 All-In-One Printer
Unable scan documents from any of the PC's - HP LaserJet 3050 All-In-One Printer
The document i scaned did not appear on my computer
Are you using HP Printer to scan ?
Does the scanned document disappear ( unable to find in your PC ) after you have scanned successfully ?
There is a patch available for this issue.
Click on this link below to download the patch and resolve the issue
Download
Once you have downloaded and installed the patch, Restart your PC and Printer and try to scan. It will resolve the issue
Oct 13, 2010 | Office Equipment & Supplies
I am trying to get my dell v305w printer to scan and it keeps telling me downloading application list and then it says after 2 mins unable to download apps
The printer is trying to connect to your pc to download a list of programs to send the scanned document and/or picture to when you use your scanner.
The printer will only scan to certain software and there are separate choices for handling pictures and text documents.
When it tries to communicate with your pc to find software that it can scan to, its not finding any installed that will work with your printer. Its telling you that it is unable to get the list of applications after attempting to connect with your pc.
So, what does that mean?
It means that either "bi directional support" is not enabled in your printing preference so your printer is limited to sending info one way oly (to the computer). If this is the case you can go to your control panel and then choose printers and check the preferences listed there.
OR
You don't have applications installed in your pc that your printer can send scanned documents to.
If this is the case then you need to install software that your printer will work with and then set the options on your printer to pick the default you want to use with both pictures and text documents.
Printers usually accept microsoft word, word pad, microsoft works and any other word processing software to scan text documents to.
Printers usually accept just about any picture editing software installed on your pc to send scanned pictures to.
You can avoid all of the above by checking to make sure that your printers software is 100% installed including the scanning features. Go to the Dell website and update the drivers on your printer to make sure you have the full version that is most current.
The printer will always use its own program to scan both documents and text to regardless of the other software applications you might have installed on your pc.
Sep 27, 2010 | Dell V305w All-In-One R840635AU InkJet...
Webworks 7 wizard unable to scan document: While trying to generate a *.CHM file using the Microsoft HTML help template and FrameMaker 7.0 sourcefile, WW throws the following error: Wizard was unable to...
you need to add following entry to maker.ini file present in C:\Program Files\Adobe\FrameMaker7.0 location
Under section API Client add following line
WWPPE7=Standard,WebWorks Professional Edition Plugin,C:\Program Files\Quadralay\WebWorks Publisher Professional Edition 7.0\bin\wwpfm7.dll,all
Please note that path given to wwpfm7.dll may defer depending upon your webworks installation directory
Thanks
Rohit
May 07, 2010 | Quadralay WebWorks Publisher Professional...
When attempting to scan document or copy a document on Photosmart all in one seriers I receive an error message "Scanner failure unable to scan or copy"
try to remove and re install driver, and look into device manager if scanner detected. if not restart you pc and when found new hardware popup browse driver manually.
Apr 10, 2010 | HP Photosmart 3310 Printer
HP OJ 6500 with windows7..Scan button on scanner is not working.
The reason that you are unable to scan through the printer is, you are missing HP full feature software and driver.
Please download and install it from the below link
DOWNLOAD
Regards
Rizwan
Feb 13, 2010 | HP Officejet 6500 Wireless All-in-One...
Unable to download scanned documents from KM350
this model does not support sub addressing for scanning so all the computers would have to be in the same subnet to scan.
Jul 13, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Unable to copy from scanning bed
There is probably a little switch that gets tripped when the document feeder is in correctly. This is preventing you from scanning from the glass.
Jun 02, 2009 | HP Officejet 7310 All-In-One Printer
Trying to scan document on HP Deskjet F4200 all in one series. When scanning small document from TIFF Image this is scanning through as 25.5 MB so I am unable to send this as an attachement to an email as...
Try lowering your scan resolution settings. Magazine quality is 300dpi. If you don't want to lose too much quality, open the file is a image editor and crop only the area you wish to send.
Nov 06, 2008 | HP Computers & Internet
HP LaserJet 3050 All-In-One Printer Logo
78 people viewed this question
Seeker5211
Seeker5211
