Question about Corel AE CorelDRAW Graphics Suite 12 for PC
Out Of memory error
When i publish cdr to pdf it gives me out of memory error.
there is no any other open applications or virtual memory is also set high level. phisycal memory is upto 2 gb & cpu is Pentium 2.2 core2duo. so why this problem is happening?????
    President:
  • 1,653 Answers
In short you need a lot of memory for doing such things in Corel and many other applications. Operating systems are not what they used to be and every driver and every option enabled uses more and more of the precious RAM capacity so the only option is to get more RAM into your system. You should try to get 4Gb and this operation will go ahead with no problems.
Posted on Sep 12, 2009
  • Mukesh Das Jan 04, 2013
    had tryied same plz give me a other solution.....thanks
How do I fix a big .cdr file?
Try to download the hotfix on the Microsoft website and fix this error. Look in more detail here.
https://support.microsoft.com/en-us/kb/884538
If this does not work then you can check the file in the online service and see whether really to recover the file. https://onlinefilerepair.com/en/coreldraw-repair-online.html If there is hope, then to open this buggy file, you must either manually delve into binary code or to have a special app to open damaged cdr files...I from my experience can recommend a good program CDR Repair Kit for this. Hope I helped you!) http://www.cdr.repair/
Oct 26, 2015 | Corel DRAW Graphics Suite 12
0x80000003 occurred in the application 0x7c90120e
This error may occur if the virtual memory is set too high.
You may check the virtual memory settings.
Set it at 1 to 1 ½ times the size of RAM installed.
Aug 19, 2014 | Microsoft Windows XP Professional SP3 Full...
Ok, if try to open my Contacts I'm getting an error message saying "Not enough memory to perform operation. Delete some data first." I am getting this same error message on virtually every...
since you tried everything..let me give yu the ultimate solution
1.go to file manager and backup phone on memory card and remove it
2.go to settings<phone managment<factory settings
3.enter password and reset the phone
4.after resetting insert memory card and restore
Mar 05, 2011 | Cell Phones
I have picture publish 7 cd but it will not load on windows 7
right click>properties>compatibility>change to another version of windows and run as admin. or rightclick the setup file on the disk and hit run as admin.
Dec 10, 2009 | Micrografx Webtricity 2.0 Full Version for...
Windows XP Sp2. Publisher98.
HI,
ITS A PROBLEM OF WINDOWS VIRTUAL MEMORY,INCREASE VIRTUAL MEMORY. MANAGE PROPERTIES..
TNKS
RABBANEES
Nov 05, 2009 | Microsoft Computers & Internet
Virtual memory is low computer is very slow
hello frnd, you can increse your virtual memory manually...
1.go to properties of my computer
2.go to advance tab...
3. there is option to change virtual memory.
4.click on it and change virtual memory accordingly..
hope this will help you
Jun 30, 2009 | Dell Dimension 2400 PC Desktop
Microtek Scan Master 5900 hrdware error -3
Code 3 The driver for this device might be corrupted, or your system may be running low on memory or other resources. (Code 3)
Here are some things that you can try to resolve this problem.
Close some open applications
If the computer has insufficient memory to run the device, you can close some applications to make memory available. You can also check memory and system resources, and the virtual memory settings.
  • To check memory and system resources, open Task Manager. To open Task Manager, press CTRL+ALT+DELETE, and then click Task Manager.
  • To check virtual memory settings, right-click My Computer, click Properties, click the Advanced tab, and then click Settings in the Performance area.
Uninstall and reinstall the driver
The device driver may have become corrupted. If the driver is corrupted, uninstall the driver from Device Manager and scan for new hardware to install the driver again.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. However, sometimes, it will open the New Hardware Wizard which may ask for the driver. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
  1. On the device Properties dialog box, click the Driver tab, and then click Uninstall. Follow the instructions.
  2. Restart your computer.
  3. Open Device Manager, click Action, and then click Scan for hardware changes. Follow the instructions.
Install additional RAM
You may have to install additional random access memory (RAM).
May 21, 2009 | Microtek SCANMAKER 5900 Flatbed Scanner
ZDplus.exe application error
You are either running out of virtual memory or Zeon DocuCom PDF Plus needs to be reinstalled to fix the error.
Feb 05, 2009 | ScanSoft PDF Converter Professional 3 for...
I need to increase virtual memory
I don't wish to sound rude but if you don't know how to do this, you prolly should just let windows continue managing it. A few wrong keystrokes can have major repurcussions
Jul 15, 2008 | Computers & Internet
Corel AE CorelDRAW Graphics Suite 12 for PC Logo
901 people viewed this question
Top Corel Computers & Internet Experts
photoshop serial
Dan Shibata
Dan Shibata
Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
