Question about Hannspree 19" Widescreen LCD Flat Panel Monitor
Monitor speakers How do i set up my monitor speakers? Ive been using desktop ones but nowe i want to use the mpnitor speakers
    President:
  • 987 Answers
You have to connect the Audio cable from audio out the back of your CPU ...into the back of the monitor ...
Posted on Sep 12, 2009
Ho do i connect external monitor to my mt 3422
Most laptops have a 15pin video connector to allow an external monitor to be attached to the laptop. Power up the external monitor first and then boot up the laptop, the video information will automatically switch to the external mpnitor.
Mar 04, 2012 | Gateway MT3422 RTL Notebook
The Sound of the Monitor is not working.
Check cable connections between the monitor and the sound card/motherboard output, you could unadventedly dislodged it, check the monitor speaker volume control on the monitor menu. If all else fails connect the headphone input directly to the PC case front or back sound output - much better than via the monitor anyway - shorter pathway makes better sound, last but not least: use a better set of speakers - monitor speakers ****
Mar 06, 2010 | Computers & Internet
Cant use my rad 5 with a desktop Dell computer with Vista
Temporarily connect another monitor to your computer.
Set the screen-resolution to 800 by 600 at 60 Hertz.
Disconnect the other monitor, and connect your RAD.
It should display.
Try changing the screen-resolution to 1024 by 768, and "test" it.
Jan 04, 2010 | KDS Radius RAD-5 15 in. Flat Panel LCD...
I cannot hook up the sound to my computer
The W2053TQ does not have built-in speakers. You will have to use a separate set of desktop speakers. The quality of the speakers built-in to any monitor is generally poor so you will probably be happier with desktop speakers anyway.
Oct 19, 2009 | LG W2053TQ Monitor
How do I turn the monitor volume on for a norcent
Please try to go to Control Panel > select Sound, Speech and Audio Devices > select Sound abd Audio Devices > then at Speaker Set-up select Monitor Stereo speakers. Best regards
May 12, 2009 | Norcent Technologies Computers & Internet
No place to plug in my speakers
Monitor plugs in 3 times?
1] power 2] video 3] sound???
use audio cable from desired speakers rather than for the monitor.
Mar 21, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Bypass hdmi to get sound to PC speakers
does your tv not have an audio out, if so, you could turn the tv's internal speakers off and just use the audio out jacks instead.
Feb 26, 2009 | Westinghouse 25.5" Widescreen Flat Panel...
Trying to add speakers
The only way i can see of feeding two sets of speakers from the one pc would be to buy or make up a "splitter" audio lead .....i.e a 3.5mm stereo jack on one end connected to the pc with two lots of wiring going to 2 3.5 mm jacks. I don't know whether a store like Maplins would sell such a lead. Are you any good with a soldering iron??
Dec 31, 2008 | Gateway GT5468 Desktop PC
Compaq wf 1907 monitor speakers--no sound
No sound from monitor speakers
If the built-in speakers on the monitor do not produce sound, perform each step that follows, testing for sound after each step, until you can hear sound:
  1. Close the software program you are using that is experiencing the sound problems. Test for audio using another software program.
    If the volume is adequate using another software program, the issue is with the computer, not the monitor. If the volume is still low, continue with this procedure.
  2. Check the cable connection. If the monitor-to-computer connection is a VGA cable (usually blue on both ends), an additional audio cable is needed between the monitor and the computer. Check that the audio cable is connected properly.
  3. Try to adjust the volume higher using the monitor front-panel volume button.
  4. Using the buttons on the monitor, navigate through the onscreen display (OSD) menu to find audio or speaker settings and enable the speakers.
  5. Click Start c01292216.gif , Control Panel , and then click Sounds and Audio Devices .
  6. From the Volume tab, check the Device volume, and make sure it is not muted.
  7. From the Audio tab, in the Sound playback field, click the Volume button. Make sure the audio device is not muted and the volume outputs are at adequate levels.
  8. If the monitor-to-computer connection is an HDMI cable, an additional audio cable might be needed, depending on the setup and configuration of the system. To find out whether an additional audio cable is needed, go to
HP and Compaq Desktop PCs - Using HDMI Audio with a Desktop Computer
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector.
HDMI sends both audio and video through the same connection. If you want to hear audio from an HDMI connection, HDMI audio must be set through Windows . For example, if a computer is connected via HDMI to a monitor or TV and the proper HDMI audio settings are made, both audio and video will be sent to the display device.
Use the following steps to activate HDMI audio on your computer:
    NOTE: If you are setting up your computer for the first time, it may be easier to use a DVI connection or DVI-to-VGA adapter connection for the initial setup. Then, if you want to use an HDMI connection to connect a TV or monitor, activate sound for the HDMI connector using the steps that follow before connecting the HDMI cable to the TV or monitor.
    NOTE: After recovering the computer using the Recovery Manager, repeat this procedure to activate sound for the HDMI connector.
Step 1: Enabling HDMI sound in the BIOS
To hear audio through the HDMI connector to a monitor or display, enable the Onboard Audio setting in the computer BIOS settings by completing the following steps.
    NOTE: If you choose the default BIOS Setup options or upgrade the BIOS, you must repeat this procedure to enable audio for the HDMI connector.
  1. Turn off the computer.
  2. To enter the BIOS, turn on the computer and press the F10 key repeatedly until a BIOS Setup screen opens.
    A BIOS Setup screen opens.
  3. Press the right arrow key on the keyboard to select the Advanced tab.
  4. Press the down arrow key to select Onboard Audio , and then press the Enter key.
    Figure 1: Example of Onboard Audio menu
    An option window opens.
  5. Press the down arrow key to select Enabled , and then press the Enter key.
    Figure 2: Onboard Audio Enabled
  6. Press the F10 key. Select Yes to save the default settings, and then press the Enter key.
  7. The computer restarts. HDMI sound is now enabled.
Jan 03, 2008 | HP Compaq WF1907 Monitor
Hannspree 19" Widescreen LCD Flat Panel Monitor Logo
56 people viewed this question
Top Hannspree Computers & Internet Experts
richie46
 Chuck N
Chuck N
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
