Question about Electrical Supplies
A hager b6 fuse has blown - normally the switch flips off and you push the switch back to on and power is restored - here the switch is limp and wont stay in the on position - i cannot see how you remove the fuse unit to replace it with a new fuse unit
I have just done this myself and without blowing myself up.
1. Tools needed will be a torch and a philips screwdriver
2. Switch off your mains.
3. Check your mains are off
4. On the fuse itself they are two screws. One above the hager sign and one below. Unscrew these. The top screw keeps the wire in from the mains and bottom screw is to keep fuse screwed to the actual fuse box
5. You should be able to remove your fuse now
6. On your new fuse there will be a white piece at the back. Pull that down
7. When the fuse is removed you will see the wire which is now free and on the bottom a plug which is where your new fuse slots in.
8. Slot your new fuse on the plug and tighten the bottom screw.
9. Put your wire in place on the top of the fuse and tighten the top screw.
10. Switch your new fuse on the "on" position.
11. Put back your cover on your fuse box
12. Switch your mains back on.
WHO NEEDS A MAN! PS ONLY ATTEMPT IF COMPETENT OR GET A QUALIFIED ELECTRICIAN!
Posted on Nov 14, 2009
    Scholar:
  • 68 Answers
If this is a B6 circuit breaker you are talking about then put the power off and remove the live wire from the top of the b6 fuse. Switch power back on and try to reset the breaker.If breaker now resets then you have a fault in your installation served by that breaker.P.S. a breaker will not reset under fault conditions.
If you have to remove to replace. then SWITCH OF MAINS.
Remove db lid and guard protecting busbar from bottom of breaker,you will now see a screw attaching breaker to busbar.Loosen sc rew and use screwdriver to pull down locking pin protuding from bottom of breaker ,tilt breaker forward and lift of busbar. ONLY ATTEMPT IF COMPETENT OR GET A QUALIFIED ELECTRICIAN.
Posted on Oct 06, 2009
Hager fuse box
by fuse box I assume you mean breaker panel. sometimes when a breaker goes bad, it can trip and you wont be able to tell until you go to reset it. if you are positive the dishwasher is getting power, then check the back of the dishwasher where the wires going in. there is probably a terminal block where the wires are connected. check there with a multi meter. be careful. use rubber gloves if you are going to do it.
Jan 05, 2014 | Electrical Supplies
Our Belling Touchtronic hob wont now turn on. Have checked wiring on the mains and fuses but make no difference. Any ideas? Was fine yesterday and had shown no signs of intermittent working
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times: I offer free advice bcuz God is so good!
1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
2.Power cord plugged in?Grab the plug and wiggle to determine a good connection.
3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
5.
6.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
Dec 27, 2012 | Belling Ovens
Windows wont work with switch, but will work with modus
Hello lets start by checking the fuse panel marked power windows remove the fuse check the view wind in the fuse if blown replace with the same amp fuse this should restore power to your switch
Jan 03, 2011 | 2001 Pontiac Aztek
Good Morning. The downstairs lights are not working.I checked the fuse box[Hager]and the fuse swich was off for the lights,i flicked this back on thinking lights would come back on [apart from supposed...
I assume you mean circuit breaker when you say fuse. If you reset the breaker to "on" and the lights still don't work, look for a GFI outlet somewhere in the circuit. It could be tripped which will shut off the current downstream from it if it is set up to guard the downstream circuit.
May 26, 2010 | Electrical Supplies
I cannot boot up the computer. When I push the front power button, nothing happens. When I flip the switch on the back, or unplug it for 30 secs and plug it back in, the fan starts up and a yellow light...
I had this happen to my emachines T1842 about a year ago. I replaced the power supply and it worked fine. It was about 25 bucks but fixed my problem. Make sure the red switch on the back hasnt been messed with. it should be on 115. If you have moved it, it may have blown a fuse inside the power supply.
Feb 04, 2010 | E-Machines eMachines Desktop PC
I am not getting any power to my injectors on Audi A4 TDi 2003 (B6 model) Glow plug relay working and no fuses blown could it be the ECU /ECM
try checking the resistances between the injectors and the head if one is high that will back feed and stop power to the injectors
Jan 18, 2010 | 2003 Audi A4 Cabriolet
What is a thermal overload switch? We had a storm and lost power in the house. The fuse did not blow but the next day the pump would not work. We changed the fuse as a precaution. I believe the thermal...
A TOC is a bi-metal strip in a canister , they are normally placed on the motor windings and in most cases are auto-resetting.
All they do is sense the temperature of the windings and when they exceed the limit of the TOC (Which is set by the motor maker) they flip the Bi-Metal strip and open circuit the supply.
Normally once the motor has cooled down the strip relaxes back to the original position and the supply is restored.
It is not a standard practice to have a push button re-set however on that will depend on the makers whims
What you may have is a Thermal Fuse which melts if the motor gets too hot and you then need to strip the unit down to both check it and if possible replace it.
By looking at the rating plate on the motor you may find the manufacturer and approach them for a data sheet
Aug 23, 2009 | Kitchen Appliances - Others
Dryer wont turn on
it sounds like the door switch or main fuse has blown,check the door switch,click it in and out to see if it has the clicking sound,if not replace,you can check the main fuse by removing the back panel,it is located on the blower box,let me know-mike
Mar 02, 2009 | Whirlpool LER4634J Electric Dryer
I found the fix a year ago but now cant remember how to fix this. My Medion desk top wont recognize the photo card drives. It was something like turn off CPU, turn off switch in back, hold down front...
Problem fixed. Shut down the CPU, then flip the switch on the back tothe off position. While in the off position, push in on the power button on the front as if you wanted to start it up. Leave it pushed in for several seconds. Then release, turn back switch back to on, and THEN fire up the CPU. Icons for card reader should be restored.
Dec 26, 2008 | Computers & Internet
Amana dryer
Check your fuses or breaker. An electric dryer requires 240 volts to operate. In a fuse box system, 2-30 amp fuses are required for an electric dryer to operate. If 1 fuse is blown it will not start or heat depending on which fuse is blown.
In a breaker system the breaker can trip and sometimes look ok. Find your 30 amp dryer breaker and reset it by flipping the lever to off, then back on.
If this doesn't help, you may have a faulty door switch or maybe your door has loosened from the hinges and has sagged a bit, breaking contact with the door switch plunger.
If you can locate the door switch, push on the plunger... you should hear an audible click...if you do then the door switch is normally ok, but not always, it is just a simple test to rule a bad switch which is normally silent if it is faulty.
You may want to inspect for a burned wire or wire termination.
Make sure dryer is unplugged from the power source before inspecting!!!
Other than the previous instructions, it is difficult for a novice to diagnose the problem...call a technician in to fix your dryer.
1 more thing, Just because a breaker appears to be on, and/or you flipped it off then on, doesn't mean the breaker is ok. Fuses also can look good and be bad. A small volt-ohm meter($10.00) is a good investment for testing voltage, and to save time and money.
Hope this gets you up and running.
May 26, 2008 | Amana ALE643RB Electric Dryer
Electrical Supplies Logo
3,782 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
