Question about Motorola XTN and Spirit Pro Replacement 10-hour Plug-In Wall Charger 2-Way Radio
Charger port not working
I have the Motorola L7 disassembled to replace the charger port and don't know how to take the old port off to put in the new port. Thank you.
  • 1640 Answers
SOURCE: removal of charger jack on Motorola sp10 radio
The schematics of this radio are not posted online anywhere to my knowledge. However, I can tell you how to remove the radio from the housing.
First, carefully remove the battery tray by slipping a screwdriver or car key into the slot at the bottom of the battery area. Gently pry up. This will remove the battery frame.
Then, either use a Motorola frame removal tool, or substitute 2 small screwdrivers. Slipping the device under the tabs in the side channels to release the little ears which hold the component board in the housing. (This are about 1/2 way up inside the radio, on both sides. You will see they slide in a channel or groove.)
Once you have gently moved the "ears" inward, you will be able to push on your small screwdrivers (or frame removal tool) and slide the component board out the top of the radio.
At this point you will have access to the accessory jack.
Sidenote: If you want to forego the above, you can simply send the radio in for a flat rate repair, which is approx. $69 at most servicers, during which time the accessory jack would be replaced.
Posted on Dec 23, 2008
0 characters
1 Points
Battery and charger tips
The M series Motorola radios such as the MU21CV, come equipped with a NiCD rechargeable battery. This battery when fully charged should operate the radio a full 8-10 hour business day. The batteries have a life expectancy of 18-24 months.
The original Motorola battery has a date code in the white box above the stop sign on the back of the battery. The first digit is the year, and the next two are the week of the year. Example: 919 would be 2009, the 19th week. (Unless very old and it could be 1999)
When replacing the battery it is important to install the battery correctly. Put the top of the battery into the radio first, then slide the bottom into place. This method will cause the least pressure on the internal battery contacts.
If you battery's contacts are dirty or filmed, simply clean them with a pencil eraser. Do not use solvents or a knife blade on the contacts. The radio's contacts can also be cleaned with a pencil eraser.
The wall adapter style charger which came with the M series radio can burn out over time (much like a lightbulb). Replacement chargers are available. If your charger light is flashing, you most likely have a bad battery. If your charger light does not illuminate, you have a bad charger.
Replacement batteries and chargers are available, as is repair of this style unit.
Best regards,
on May 08, 2009 | Motorola MU21CV (1 Channel) 2-Way Radio
The battery is flashing red when charging
You do not mention which model of Motorola radio you are charging, so this will be basic information: Typically if a charger blinks red when the battery is initially put on the charger, you either have:
1) Dirt contacts. Solution: Clean with pencil eraser, both radio and charger contacts.
2) Shorted or bad battery. Solution: Replace the battery.
3) A bad charger. Replace charger.
Some simple troubleshooting might determine your problem. Try the battery on a different charger and see if you get the same blinking light. If so, you have a battery issue. If the problem disappears when you place it on the known good charger, then you know you have a charger issue.
Best regards.
May 17, 2011 | Motorola Walkie Talkie 2-Way Radio
Brand new battery flashes fault when put in charger
Clean the contacts with a pencil eraser, both on the battery and the charger. Then despite the flashing let the battery sit on the charger for a good 12 hours to see if it will clear. It is possible the battery has gotten too low to charge. In the shop we sometimes have to "jump start" a new battery by placing it on the charger two to three consecutive times for a few hours. If this does not clear the issue, contact the place of purchase and request a replacement. Motorola brand batteries have a one year warranty.
Best regards.
Oct 14, 2010 | Motorola CLS1410 Two Way Radio
Motorola CP040 charging time
The rapid rate charger WPLN41__ will typically charge a battery in 90-120 minutes. Your battery should be depleted or nearly depleted when you place it in the charging stand. Be certain your radio is always turned off, when charging an attached battery. The NiMH battery will generally go 12-16 hours on a charge when new. If you work an eight hour shift, you might see if the radio will go 2 days on a charge. Later as the battery ages, you will need to charge it nightly. (Think of putting it in the charger as putting it to bed at night.)
Rapid charging is necessary on NiMH and Li-Ion batteries. They require a "hotter" charger, a fast rate, to completely charge the battery. It will not harm this chemistry of battery. It is safe to leave the battery on the charger overnight, or for a weekend. We would not recommend leaving the battery on the charger longer periods of time, as that will age the battery and reduce its life.
(Sidenote: Frequent rapid charging will however reduce the life of a NiCD battery.)
Aug 12, 2009 | Motorola Two-Way Radios
I work for a hotel and we have about 6 2 way
Here are some things to check:
1) Clean your battery contacts with a pencil eraser. (Both on the radio and charger)
2) Check the date code of the "new" batteries and see if they are less than 2 years old. (3-digit number usually with the first number being the year, the next two the week of the year. ex: 927 would be 2009 the 27th week)
3) The radios must be turned off when on the charger.
4) If using drop-in chargers try charging the battery alone in the charger.
5) Are all the chargers lights blinking? This can be a sign of a bad charger, shorted battery or wrong battery. You mentioned recently replacing them, are they the same chemistry as the previous batteries?
You did not mention the type of radio, so we cannot be more specific in our troubleshooting, but this should get you started. The beeping you are experiencing is most-likely the low battery beep. Your batteries are not getting charged. The above questions should help you narrow down the problem. If you need more assistance post another question and we'll try to help further.
Jul 28, 2009 | Motorola Two-Way Radios
Motorola t5000
I'm assuming you're using the NiCd batteries. NiCd batteries do not last forever and need to be replaced when they show a resistance to beign charged. To optimize the life of these batteries you need to let them fully discharge before attempting to charge them. This is impractical most of the time.
You have two choices:
1. Purchase a NiMH charger and AA batteries and use that INSTEAD of the CHARGER STAND and NiCd batteries. This type of battery can be recharged without the problems discussed earlier and will last longer... or
2. Purchase another NiCd battery pack.
Oct 24, 2008 | Motorola T5000 Two Pack 2-Way Radios with...
Batteries not charging
Are the batteries the original power pack? this charger are disigned for work just for this batery packs only.
Check if the conctas on the battery lead for dust or corrotion.
Oct 08, 2007 | Motorola Talkabout T5700 AA (22 Channels)...
Motorola XTN and Spirit Pro Replacement 10-hour Plug-In Wall Charger 2-Way Radio Logo
16 people viewed this question
Top Motorola Two-Way Radios Experts
bill tarkulich
Level 1 Expert
Are you a Motorola Two-Way Radio Expert? Answer questions, earn points and help others
