Question about Baby Gear
I need to get a Bugaboo main hinge fixed as it is not lockinng into place. I live in Yorkshire - where can I get this done?
Where can I buy (online) a pair of metal domes that cover the main hinge, in the middle of the chassis?
www.starlock.nl/Products/Dome_capped.php You need the number 8 Check local industrial fastener suppliers to see if they can help. www.buggypitstop.co.uk/Bugaboo-spares.html These guys sell them for 10 pound a set of two in the UK! I sell them $2 each but shipping from New Zealand is $15 economy air post or $33 insured air courier! All the info is here www.fixya.com/support/r7805199-fix_bugaboo_handle_lock
If anyone finds this helpful please tick the box to say so! That last link to my How To Fix a Bugaboo Handle Lock has had over 400 views add the almost 500 help answers I've posted so far and all the hits on my other Bugaboo How To' on my Tips page I don't feel the viewers of this work show enough appreciation for the work I and the 1000s of other experts put into Fixya. Rant over have a nice day, tick the box and good luck with your Bugaboo
Nov 01, 2011 | Bugaboo Cameleon Jogger
I need a replacement door for my Hoover Easy Logic 1100 aa Washing machine. I beleive that the model is discontinued but my machine is in perfectly good working order. Could you advise anywhere where I...
I searched for quite some time without success and I am Pretty good at finding things.
Contact Hoover using this link:
http://service.hoover.co.uk/spares
To order Hoover Genuine Spares & Accessories please call 08443 712758
Opening hours: Mon-Fri 8.30am - 5pm.
I could not even come up with the part number for the door. I did find the following:
1. Door Seal
2. Door Glass
3. Door Handle
4. Door Hinges
No luck on finding the complete door assembly.
Another alternative... if the Yorkshire area has an appliance recycling venter you may be able to find one there or in the classified ads "for parts only" But then your faced with disposing of the "junk."
I recommend you contact Hoover using the number or Lonk above and see what they can do for you.
I wish I could have done more for you but the whole door assembly just does not seem to be readily available.
Thanks for choosing FixYa,
Kelly
Sep 03, 2011 | Washing Machines
Broken Bugaboo
TAKE IT TO WWW.BUGGYPITSTOP.CO.UK THEY DO SERVICING TO BUGABOOS AND THE WORK IN NORTH LONDON
Dec 07, 2009 | Bugaboo Cameleon Jogger
I need to buy a front wheel for a Bugaboo Cameleon. Where can I get one from ? I live in London. Is there a shop? thanks
The quickest thing to do is to contact www.bugaboo.com. I believe that the price will be around £29.95 for this spare.
I hope this helps.
Oct 08, 2009 | Bugaboo Cameleon Jogger
Cannot fix the angle of the seat (Frog), the large white buttons at the hinge get stuck once pressed, tried lubricating, but still would not become unstuck.
Email to bugaboo to describe your problem they will ask for the serial number of the pram and your address & send you a repair kit (new white buttons) - for free!
Aug 30, 2009 | Bugaboo Baby Gear
Need to fix a Bugaboo Frog wheel
just order new wheels from bugaboo. They cost about $30 bucks each or contact a local retailer to order you some wheels.
Mar 30, 2009 | Bugaboo Frog Stroller
Bugaboo Frog Handle Bars Not Locking into place
Try to contact Bugaboo Service 1-800-460-2922 or serviceus@bugaboo.com
Jan 07, 2009 | Bugaboo Frog Stroller
The frame tilt seized on Bugaboo Cameleon
bUGABOO will send out free replacemnt buttons even if your pram is out of warranty you need to contact them. They will fix the problem but i had to put them in the oposite sides to what their instructions suggested for them to work so def a fiddly job but does fix problem.
Dec 12, 2008 | Bugaboo Cameleon Jogger
Main Chassis bar won't lock on one side
We had a similar problem, the right-hand hinge of the frame would not lock and the button was permanently down. What had happened was the handle extension switch housing had come unscrewed and slipped up the frame, causing a small spring to fall out. The lock switches each have a spring which pushes down on a rod inside the frame to lock the hinge. To access the spring, unscrew the handle extension housing and slide it up the aluminum frame. I replaced the missing spring and the frame works perfectly. If the problem is with the spring, this should work. Alternatively the problem may lie inside the lock switch housing, which contains a very simple mechanism which slides the lock rod up and down. This can be unscrewed as well. As far as I can tell, the actual hinge assembly itself is a sealed unit and can't be opened, but hopefully, you won't have to.
Good luck,
Ben
Aug 28, 2007 | Bugaboo Cameleon Jogger
Baby Gear Logo
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
