Question about Packard Bell Compasseo 820 GPS Reciever Sat Nav GPS Receiver
I need to get panasonic lithium ion rechargeable battery cgr18650c the one i have no longer takes a charge..
    President:
  • 1,653 Answers
Try searching on eBay using "cgr18650c" as the search item and you will get a few hits. I am not sure which country you are in but there are a few business sellers showing in various counties. They also seem to be relatively cheap - typically around $5, £3, E4 etc.
Posted on Sep 12, 2009
Toshiba PDR-3300 Digital Camera
Hi this is common problem if your sure that these batterys are new and you have used that make and type of battery before than the problem will be on the board of the camera itself.
If these batterys are ones you have not used in your camera before then the chances are these batterys are just not powerfull enough so you can by a recharge pack for your camera ok so let me know if its new batterys and if you have used this type before.
Also insted of using the lcd can you turn the screen of then try taking picture using normal view finder as you would on a none digital cam
It could just be that the batterys you brought are faulty and might be worth trying another set before giving up.
These camera usuall wont switch on with normal batterys so just try another set or if you have let me know.
If the battery says low bat then goes off then these batterys will not work if tryed again but if you can get camera on turn off the screen then try taking picture ok get back to me and let me know ok
Apr 06, 2008 | Toshiba PDR-3300 Digital Camera
I have a nextbook 7 or 8 tablet. it no longer charges in any way, and it gets extremely warm when connected to a charger no mattet how short a time it is plugged in for.
Lithium ION batteries are usually rechargeable. The use mode for these batteries is that there are a set number of recharges that equate to the life of the battery. Usually that life is approximately 1,000 charges.
If you use your battery to 50% then recharge, you can do this ~2,000 times. As the life of the battery is used up, the maximum charge lessens which means where you may have had 8 hours of play time when the battery was new, you will only have 6 hours as the battery life is used up.
In order for a Lithium ION battery to recharge there must be at least a small amount of charge left as a "seed" for that recharge. If you drain a L-ION battery down to zero, it may never recharge again or the max charge will be reduced to an insignificant amount of the original full charge. eg instead of 8 hours you may only get 15 minutes, or 5 minutes, or no minutes.
You are much better off recharging when 50% depleted than using it up til your product stops.
L-ION batteries cannot be repaired only replaced. Most cheap products using L-ION batteries cannot have their batteries replaced.
Jun 07, 2014 | Tablets & eReaders
18 v lithium-ion battery will not charge
The batteries were discharged too low. A lithium battery should be recharged as soon as you see a loss of power.
Jan 12, 2013 | Ryobi Two 18V Lithium-Ion Batteries +...
Is there a lithium-ion battery for Canon Powershot a570?
No. You can use disposable alkaline or lithium batteries, or rechargeable NiMH batteries, but AFAIK there are no rechargeable Li-ion batteries in that size.
Feb 20, 2011 | Canon Cameras
Can I use an ordinary button cell in a seiko kinetic
I have been trained by a Master watch maker and I have worked on many Seiko Kinetic watches. Yes the original watches came with a capacitor that is charged by your arm movement. But unfortunately, they seem to only last a few years. All replacements are now done with a Lithium Ion battery that is much better and lasts longer than the original capacitor. This is the correct solution and don't try to use a battery type that is used in other quartz watches.
Oct 01, 2009 | Seiko Kinetic watch
In camera ,which will be better lithum battery or alkalide battery.and what is the benifits?
Alkaline batteries are available *everywhere* for relatively short money. When they die, you probably won't have to go very far for replacements. A lithium battery usually lasts significantly longer than traditional alkaline batteries.
When a lithium ion type dies - you'll have to find a place to plug a charger in to recharge before using again. Since it's not always easy to find a place to do this - and due to the time it takes to recharge - it's wise to have at least two sets of lithium batteries. One can charge while the other is in use in the camera.
Lastly, at anywhere from $20 to $80 a pop, lithium batteries can be cost prohibitive.
Sep 16, 2009 | Cameras
Vupoint camcorder battery
This camera is designed to use a rechargeable Lithium Ion battery.
(1050mAH) NP60 Lithium Ion Battery
Available from many websites, including:
http://www.nextag.com/np60-lithium-ion-battery-3.7v-1050mah/search-html
Also available from many stores including Wal-Mart, Best Buy, Circuit City, and Radio Shack
Mar 19, 2008 | VuPoint DV-DV1-VP Camcorder
Konica Minolta Lithium-Ion Battery Recommendation (warning against the use of non-genuine or counterfeit batteries)
We have received a number of inquiries regarding the usage of Konica Minolta digital cameras with non-genuine or counterfeit Konica Minolta lithium-ion batteries. Please be advised that genuine Konica Minolta lithium-ion batteries are equipped with security system to prevent the camera from damages. It has been reported that some counterfeit batteries are NOT equipped with a security system. The use of such batteries will cause damage to your Konica Minolta digital camera and may cause fire. Further, every Konica Minolta digital camera has been designed to fulfill its nominal value in performance with a corresponding genuine Konica Minolta lithium-ion battery. For safety and optimum performance, we recommend that you only use genuine Konica Minolta lithium-ion batteries with Konica Minolta digital cameras. Genuine Konica Minolta lithium-ion batteries will include the Konica Minolta model # (NP-200, NP-400, etc) and are only available through authorized Konica Minolta dealers and the Konica Minolta on-line store. Please note that Konica Minolta is not responsible for damages or troubles caused by the use of lithium batteries which are not specified in the instruction manuals or not produced/distributed by Konica Minolta Camera Inc. (Updated 01/29/04) Genuine Konica Minolta lithium-ion batteries are listed below: Konica Lithium-ion Battery DR-LB4 for Konica Digital Revio KD-510Z/410Z/500Z/400Z/310Z Minolta Lithium-ion Battery NP-200 for Minolta DiMAGE Xt/Xi/X Minolta Lithium-ion Battery NP-400 for Minolta DiMAGE A1 Minolta Lithium-ion Battery NP-600 for Minolta DiMAGE G400 Minolta Lithium-ion Battery NP-500 for Minolta DiMAGE G500 Minolta External High-Power Battery EBP-100* is available for the following models: Minolta DiMAGE A1/Z1/7Hi/7i/7/5/S414/S404/S304 * EBP-100 is consisted of 2pcs. Lithium-ion Battery NP-100, 1pc. Battery Holder BH-100, and 1pc. Lithium-ion Battery Charger BC-100
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
Is the battery that comes with the camera rechargeable?
Yes, the battery that comes with the C-7000 can be recharged. This battery is the Olympus LI-12B Lithium Ion battery and it can be recharged using the LI-10C battery charger. Both the battery and charger are included with the camera.
Sep 04, 2005 | Olympus C-7000 Zoom Digital Camera
Packard Bell Compasseo 820 GPS Reciever Sat Nav GPS Receiver Logo
140 people viewed this question
Top Packard Bell GPS Experts
Are you a Packard Bell GPS Expert? Answer questions, earn points and help others
